By mekam srilatha , 16 February, 2023 Forums DLMSDirector hi sir iam unable to read data in gurux dlms director for L&T EM101+ meter settings are 9600 none 8 bit one stop bit authentication Low, password: lnt1 16:47:18 Initializing serial connection. 16:47:19 Send SNRM request. 7E A0 07 03 23 93 BF 32 7E 16:47:19 7F BF 7E A0 1E 23 03 73 7B CF 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E 16:47:19 Parsing UA reply succeeded. 16:47:19 Send AARQ request. 7E A0 40 03 23 10 BA C5 E6 E6 00 60 32 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 06 80 04 6C 6E 74 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF 74 95 7E 16:47:24 Data send failed. Try to resend 1/3 16:47:29 Data send failed. Try to resend 2/3 16:47:34 Failed to receive reply from the device in given time. 16:47:34 Disconnect request 16:47:34 7F FF FF FF FF FF F7 F7 FF BB FF FF FD FF FF FF 7F FF FF FF FF FF FD FF 7E A0 07 23 03 1F D3 5C 7E Gurux.DLMS.GXDLMSException: Disconnect mode. at GXDLMSDirector.GXDLMSCommunicator.ReadDLMSPacket(Byte[] data, Int32 tryCount, GXReplyData reply) at GXDLMSDirector.GXDLMSCommunicator.InitializeConnection(Boolean force) at GXDLMSDirector.GXDLMSDevice.InitializeConnection() at GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters) this is the log which iam getting Hi, Your data is correct and… Hi, Your data is correct and the meter replies for the first time. Select "Supported services" tab and un-check "Delta value Encoding". BR, Mikko hi sir, i have un-checked … hi sir, i have un-checked "Delta value encoding", but no use. this is the log. 14:55:10 Initializing serial connection. 14:55:11 Send SNRM request. 7E A0 07 03 23 93 BF 32 7E 14:55:11 7E A0 1E 23 03 73 7B CF 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E 14:55:11 Parsing UA reply succeeded. 14:55:11 Send AARQ request. 7E A0 40 03 23 10 BA C5 E6 E6 00 60 32 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 06 80 04 6C 6E 74 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF 74 95 7E 14:55:16 Data send failed. Try to resend 1/3 14:55:21 Data send failed. Try to resend 2/3 14:55:26 Failed to receive reply from the device in given time. 14:55:26 Disconnect request 14:55:26 AF FF FF FD FF BF 5F 7F 7E A0 07 23 03 1F D3 5C 7E Gurux.DLMS.GXDLMSException: Disconnect mode. at GXDLMSDirector.GXDLMSCommunicator.ReadDLMSPacket(Byte[] data, Int32 tryCount, GXReplyData reply) at GXDLMSDirector.GXDLMSCommunicator.InitializeConnection(Boolean force) at GXDLMSDirector.GXDLMSDevice.InitializeConnection() at GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters)
hi sir,
this is the log.
14:55:11
14:55:26
