  3. Pre-Established In Gxdlmsdirector Software
Pre-Established in Gxdlmsdirector software
By dlmsDeveloper , 21 December, 2022
I'm using Gxdlmsdirector for set/get my electric meter, first of all thanks for your free software , its great.
now i want use Pre-Established client to set clock in GxdlmDirector
but i cant set parameters in Gxdlmsdirector , i can use Public/Reading and Management , But i cant use Pre-Established client , how should i do the settings?
thank you.
3 years 9 months ago
Select the "Secured connections" tab from the meter settings. Then set the pre-established system title. Pre-established system title is the system title of the meter.
dlmsDeveloper
thank you.
thank you.
thats work , awsome.
another question
in Pre-Established client for unicast message , Should the meter answer or not?
thank you.
There is usually an own association view for pre-established connections. Client address defines what association view is accessed.
