  3. DLMS COSEM - Water Meter Example
By m.hammuda , 2 August, 2022
Hi all,
Does anyone have a DLMS COSEM for water meters implemented anywhere to use as a guideline/example for our new project?
Mohammad
4 years 1 month ago
It doesn't matter if you are implementing water, gas, or electric meter, the idea is the same. Only the measurable quantity changes.
You can use this as a template.
https://github.com/Gurux/GuruxDLMS.c/tree/master/Arduino_IDE/server
m.hammuda
3 years 10 months ago
Sorry , I do not fully
Sorry , I do not fully understand. As I know , there should be some guidelines for the meter manufacturer to follow so the meter can comply to the DLMS standards and there also should be a more specific guideline on how to transmit the data and under which format, correct?
You can find the standards where DLMS meters are based from here:
You will find an example meter for DLMS here:
