  3. DLMS COSEM - Water Meter Example
By m.hammuda , 2 August, 2022
Hi all,
Does anyone have a DLMS COSEM for water meters implemented anywhere to use as a guideline/example for our new project?
Mohammad
3 years 12 months ago
It doesn't matter if you are implementing water, gas, or electric meter, the idea is the same. Only the measurable quantity changes.
You can use this as a template.
https://github.com/Gurux/GuruxDLMS.c/tree/master/Arduino_IDE/server
m.hammuda
3 years 8 months ago
Sorry , I do not fully
Sorry , I do not fully understand. As I know , there should be some guidelines for the meter manufacturer to follow so the meter can comply to the DLMS standards and there also should be a more specific guideline on how to transmit the data and under which format, correct?
You can find the standards where DLMS meters are based from here:
You will find an example meter for DLMS here:
  • cWYHszETmudslY…
  • Aij
  • vondamc1
  • JosephNok
  • IUJbutxeSTSNcNRN
