  3. Landis+Gyr E850 - High Level Security - Invalid Password. Server To Client Challenge Do Not Match.
Landis+Gyr E850 - High level security - Invalid password. Server to Client challenge do not match.
By andrewje , 18 October, 2022
I'm trying to get a Landis & Gyr E850 to work using high level security with the Gurux.DLMS library (.Net). I am able to get it to work fine in GXDLMSDirector but when I attempt to do the same with my implementation, I am getting "Invalid password. Server to Client challenge do not match." Obviously, I am missing an important step or haven't configured the library correctly, but I just can't spot it.
Here is the comms stream from my application:
S -> 7E A0 07 03 61 93 69 47 7E
R <- 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
S -> 7E A8 47 03 61 10 6D BD E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 47 16 0E 53 2C 54 05 46 68 07 56 5D 5D 28 09 45 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 93 FA 7E
R <- 7E A0 07 61 03 31 61 27 7E
S -> 7E A0 0E 03 61 12 8B 2B 1C 03 20 FF FF 4E 99 7E
R <- 7E A0 50 61 03 50 D9 D7 E6 E7 00 61 41 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 0E 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 0A 80 08 35 44 31 42 30 30 30 30 BE 0F 04 0D 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 81 42 7E
S -> 7E A0 24 03 61 34 42 3C E6 E6 00 06 01 02 FA 58 01 09 10 40 43 1E 7D 09 15 65 E2 34 19 8F 6C EF F4 DD C3 AE 2B 7E
R <- 7E A0 10 61 03 72 7E C3 E6 E7 00 0D 01 01 0D 1E 46 7E
The password for the meter at level 2 is 2222222 (client id = 48)
The code is as follows:
private GXDLMSSecureClient _client = new GXDLMSSecureClient();
_client.ClientAddress = 0x30;
_client.Authentication = Authentication.High;
_client.UseLogicalNameReferencing = false;
_client.InterfaceType = InterfaceType.HDLC;
_client.ServerAddress = 1;
_client.Password = DLMSLib.DLMS.ToByteArray(password); // byte[0x07] {0x32,0x32,0x32,0x32,0x32,0x32,0x32}
byte[] data;
data = dlms.Client.SNRMRequest();
int response = dlms.ReadDLMSPacket(data, 3, reply); // (data to send, retires, reply)
if (rf != 0)
// Comms failed & exit
_client.ParseUAResponse(data);
reply.Clear();
rf = dlms.ReadDataBlock(_client.AARQRequest(), 3, reply);
if (rf != 0)
_client.ParseAAREResponse(reply.Data);
if (_client.IsAuthenticationRequired)
reply.Clear();
rf = dlms.ReadDataBlock(_client.GetApplicationAssociationRequest(), 3, reply);
if (rf != 0)
_client.ParseApplicationAssociationResponse(reply.Data); // <-- throws exception - "Invalid password. Server to Client challenge do not match."
//reply.ErrorMessage = "Access Error : Device reports scope of access violated."
The dlms.ReadDLMSPacket and dlms.ReadDataBlock are our comm port send and receive functions and work with all other request on the meter.
The code works fine on Low security but it's just high level security I'm struggling with.
Any help would be much appreciated.
Andrew
3 years 11 months ago
Hi Andrew,
Hi Andrew,
DLMS standard doesn't define how High-level password is used and Landis+Gyr is using a custom way to count the password. You can find more information about the High Authentication:
For this reason, you need to set ManufacturerId to "LGZ" like this:
dlms.ManufacturerId = "LGZ";
andrewje
Thanks Mikko,
Thanks Mikko,
Works perfectly now!
