  3. DLMSDirector Does Not Send Any Read Requests.
DLMSDirector does not send any read requests.
By Ondrej_Pokorny , 26 July, 2022
Dear Sir,
I use GXDLMSDirector 8.2.2206.2301. When I connect to DLMS server from DLMS director as a ManagementClient (with pre-established association using authenticated encryption Suite0), there is a hdlc-level communication, but since then the client does not send any request (whether I click on Read button on the toolbar or Read in context menu of different objects).
The only thing that client does is periodic sending of "Keep Alive" packets (which are correctly decoded and answered by server).
The DLMS server is in early development so that our knowledge of DLMS, so most probably there is a bug there.
Could You advise me, why the Director does not send read requests?
log:
10:23:37 Initializing serial connection.
10:23:38 Send SNRM request.
7E A0 07 03 03 93 8C 11 7E
10:23:38
7E A0 1E 03 03 73 40 CC 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
10:23:38 Parsing UA reply succeeded.
10:25:30 Send Keep Alive
7E A0 35 03 03 10 9B D2 E6 E6 00 DB 08 53 41 43 53 41 43 53 41 1E 30 00 00 00 00 B6 3A 72 99 D3 7C 36 05 92 81 F2 71 7B 9D DC E1 C5 EE C3 D6 96 FE A3 FE 98 BB CF 7E
10:25:30
7E A0 34 03 03 30 22 EF E6 E7 00 DB 08 45 4C 47 30 31 32 33 34 1D 30 00 00 00 00 0F E4 04 3B 9E E4 02 45 5B 46 C6 48 00 AA 57 5A C5 98 DF 45 32 94 83 91 50 EE 7E
10:27:20 Send Keep Alive
7E A0 35 03 03 32 8B D0 E6 E6 00 DB 08 53 41 43 53 41 43 53 41 1E 30 00 00 00 01 F1 99 03 46 7F 14 A0 19 8D 7B AB 32 F2 C7 E4 64 6A D6 6F 4B 70 12 CD 8B 20 A4 4B 7E
10:27:20
7E A0 34 03 03 52 36 AF E6 E7 00 DB 08 45 4C 47 30 31 32 33 34 1D 30 00 00 00 01 6A 19 C9 D1 A4 17 C0 B3 12 FF F4 B7 64 82 46 A8 B7 9E 53 3A 9B 72 9E DF 4B F7 7E
When trying the same with Director as Public Client, it works fine.
Thank You.
Best Regards
Ondrej Pokorny
4 years ago
Can you check what are the access rights? You can see them when you select example the clock object and select "Access rights". They should be Read or ReadWrite or attribute is not read.
Ondrej_Pokorny
4 years ago
Hello and thank You for
Hello and thank You for answer.
They are AuthenticatedRead/AuthenticatedReadWrite (screenshot attached).
Ondrej_Pokorny
3 years 12 months ago
Hello Kurumi,
Hello Kurumi,
do You see something wrong in the Acess rights?
Best Regards
Ondrej
Hi Ondrej,
Hi Ondrej,
AuthenticatedRead is causing the problem with GXDLMSDirector. It's now fixed and the new version is released on Monday.
Get the latest version and let me know if you have problems.
Ondrej_Pokorny
3 years 11 months ago
Hello Mikko,
Hello Mikko,
I have updated the Director:
.NET Framework 3.5SP1 3.5.30729.4926
.NET Framework 4.0 4.8.04084
GXDLMSDirector 8.2.2208.101
Gurux.Common 8.1.2109.2401
Gurux.MQTT 8.1.2109.2401
Gurux.DLMS.AMI.UI 8.1.2208.103
Gurux.DLMS 9.0.2208.101
Gurux.DLMS.UI 9.0.2208.101
Gurux.Net 8.1.2109.2401
Gurux.Serial 8.1.2109.2401
Gurux.Terminal 8.1.2109.2401
but the behaviour is the same.
Best Regards
Ondrej
Hi Ondrej,
Hi Ondrej,
You are right. Only AuthenticatedRead was checked and not AuthenticatedReadWrite.
Get the latest version and let me know if you still have problems.
Ondrej_Pokorny
Hello Mikko,
Hello Mikko,
could You estimate when a new version is going to be released?
Best Regards
Ondrej
Hi Ondrej,
Hi Ondrej,
It's released. Get the version 9.0.2208.0801.
Ondrej_Pokorny
Hello Mikko,
Hello Mikko,
I am confused. Director says that there are no updates. I have also tried to uninstall/install it (Download Gurux DLMS Director for .Net 4.6.), but in the Libraries list there is still Gurux.DLMS 9.0.2208.101.
Is there some other way how to get 9.0.2008.0801 ?
Thank You.
BR
Ondrej
Hi Ondrej,
Hi Ondrej,
That is strange. Update worked for me without problems.
I did remove my installation and re-installed it. The version is 9.0.2008.0801.
Did you install the version from the Gurux downloads?
http://gurux.fi/Download
If you can build it, you can get it from GitHub.
https://github.com/Gurux/GXDLMSDirector
Ondrej_Pokorny
Hello Mikko,
Hello Mikko,
for sure I have tried to reinstall once more (from Gurux downloads, i cannot build Director).
Result is the same (picture attached).
Update to the latest version. It should be 9.0.2208.1201. The version number was different in Community Edition and private edition. It's now updated to the same.
Let me know if you have any problems.
Ondrej_Pokorny
Hello Mikko,
Hello Mikko,
regret to say- the situation is the same (see picture attached).
Ondrej_Pokorny
Hello Mikko,
Hello Mikko,
since it is not possible to get latest version of Director from Your pages, we have succesfully build version from Git Hub:
.NET Framework 3.5SP1 3.5.30729.4926 C:\Windows\Microsoft.NET\Framework64\v3.5\
.NET Framework 4.0 4.8.04084 C:\Windows\Microsoft.NET\Framework64\v4.0.30319\
GXDLMSDirector 0.0.0.0 \\DataServer\ProNekoho\PokornyO\Gurux\GXDLMSDirector.exe
Gurux.Common 8.4.2206.201 \\DataServer\ProNekoho\PokornyO\Gurux\Gurux.Common.dll
Gurux.DLMS.UI 9.0.2208.1201 \\DataServer\ProNekoho\PokornyO\Gurux\Gurux.DLMS.UI.dll
Gurux.DLMS 9.0.2208.1203 \\DataServer\ProNekoho\PokornyO\Gurux\Gurux.DLMS.dll
Gurux.Net 8.4.2206.201 \\DataServer\ProNekoho\PokornyO\Gurux\Gurux.Net.dll
Gurux.Serial 8.4.2206.201 \\DataServer\ProNekoho\PokornyO\Gurux\Gurux.Serial.dll
Gurux.Terminal 8.4.2206.201 \\DataServer\ProNekoho\PokornyO\Gurux\Gurux.Terminal.dll
The behaviour is all the same- no data are send upon read requests from Director.
Best Regards
Ondrej
Hi Ondrej,
Hi Ondrej,
The new version is released today. Because we don't have your meter and actually no one is not using association version #2, there was one check that caused that read is not done when AuthenticatedReadWrite was used.
I'll inform you as soon as the new version is released.
Hello Ondrej,
Hello Ondrej,
Get the latest version. A meter that is using Association View object version #2 was made and this is tested with that.
Ondrej_Pokorny
Hello Mikko,
Hello Mikko,
great, it works!
Thank You very much!
Best Regards
Ondrej
Hi Ondrej,
Hi Ondrej,
Thanks for the information. Have a nice week.
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
