  3. How To Set Up Landis Gyr Cu-l52 Lte Meter Module For Remote Communication
How to set up landis gyr cu-l52 lte meter module for remote communication
By Noahmaf15 , 8 February, 2020
Hello
I’m a student at a University and I was picked by this electricity company to find a way for them to communicate with the landis gyr cu-l52 lte module remotely via sim card data, it’s my first time working with this hardware and software, if anyone can, please kindly assist me
6 years 8 months ago
You can use GXDLMSDirector to read data from your meter. Download it and select Landis+Gyr for the manufacturer. Then set the correct IP address and start reading your meters.
Abdulsalam
4 years 2 months ago
Please I would be grateful to
Please I would be grateful to know how to configure cu-XE and CU-L52 communications modules using MAP 120
Make sure that you are using static IP addresses with the SIM card. The meter must start the communication if you are using a dynamic IP address.
There are so many settings that must be correct or your communication fails. I propose you contact your meter vendor and ask for the correct settings.
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
