  3. Gurux.DLMS Python Decryption
Gurux.DLMS python decryption
By ravichandra99 , 14 June, 2022
Hi Mikko
Im using gurux python, Im able to get data and its encrypted and in xml format
im unable to decrypt
rawdata is in
https://pastebin.com/W2XtWtR4
and the code im using is
from gurux_dlms import GXDLMSTranslator
from gurux_dlms import GXByteBuffer
data = "data here"
t = GXDLMSTranslator()
t.comments = True
t.systemTitle = "TRI00000".encode()
t.blockCipherKey = bytearray((0x54, 0x72, 0x69, 0x5F, 0x5F, 0x5F, 0x55, 0x6E, 0x69, 0x63, 0x61, 0x73, 0x74, 0x41, 0x73, 0x63))
t.authenticationKey = bytearray((0x54, 0x72, 0x69, 0x5F, 0x5F, 0x5F, 0x55, 0x6E, 0x69, 0x63, 0x61, 0x73, 0x74, 0x41, 0x73, 0x63))
t.serverSystemTitle = GXByteBuffer.hexToBytes("4142434445464748")
print(t.messageToXml(data))
4 years 1 month ago
Can you give the raw data in hex so I can check this from the bytes?
ravichandra99
4 years 1 month ago
This is rawdata
This is rawdata
https://pastebin.com/feNYWbnm
cipherkey, kindly check with this too - 52 45 53 5F 55 6E 69 63 61 73 74 41 73 73 63 30
ravichandra99
4 years 1 month ago
Cipher key and Authentication key are same
pls try from gurux_dlms import GXDLMSTranslator
data = "00 01 00 01 00 10 00 58 DB 08 41 42 43 44 45 46 47 48 4D 30 00 00 00 00 11 98 4B 30 35 F0 35 51 06 72 DA 54 93 70 8E 70 9B 3D BD 31 02 14 CE 10 A9 89 81 92 53 80 42 A9 19 D7 52 62 7B E6 70 B3 13 30 E1 53 B6 9D 0B 6D 14 8D 86 F9 D4 6F 6B C3 09 24 A8 4C 50 03 82 FF 05 77 A5 9B F1 1F CD 78"
t.comments = True
t.blockCipherKey = bytearray(0x52, 0x45, 0x53, 0x5F, 0x55, 0x6E, 0x69, 0x63, 0x61, 0x73, 0x74, 0x41, 0x73, 0x73, 0x63, 0x30))
t.authenticationKey = bytearray((0x52, 0x45, 0x53, 0x5F, 0x55, 0x6E, 0x69, 0x63, 0x61, 0x73, 0x74, 0x41, 0x73, 0x73, 0x63, 0x30))
or 52 45 53 5F 55 6E 69 63 61 73 74 41 73 73 63 30 as cipher key and auth key
4 years 1 month ago
Get the latest version (1.0.126). There was an issue with GXDLMSTranslator and ciphering.
ravichandra99
4 years 1 month ago
Hi Mikko Ihad tried with the
Hi Mikko Ihad tried with the lastest version , still im not getting decrypted data
its working with Director GUI, but not working using python,
One more thing is earlier python client command used to work , but now its also not working
im using ipv6 to connect to meter ..
ravichandra99
4 years 1 month ago
t.comments = True
t.blockCipherKey = bytearray((0x52, 0x45, 0x53, 0x5F, 0x55, 0x6E, 0x69, 0x63, 0x61, 0x73, 0x74, 0x41, 0x73, 0x73, 0x63, 0x30))
The above is code i had used
xml: https://pastebin.com/W2XtWtR4
encrypted: https://pastebin.com/feNYWbnm
Im stuck from last 2 weeks
4 years 1 month ago
Your block and authentication keys are wrong. Use 54 72 69 5F 5F 5F 55 6E 69 63 61 73 74 41 73 63
  • cWYHszETmudslY…
  • Aij
  • vondamc1
  • JosephNok
  • IUJbutxeSTSNcNRN
