Check also the video. I hope it will help you to generate the private key for the meter and then import the public key for the meter.
Note! ECDSA and keys are complicated. If you generate a new private key, you are not allowed to establish the connection for the meter with the old certificate.
3. This is not possible. A digital signature is generated every time when you establish the connection for the meter.
1. ECDSA is using asymmetric keys. If you want to use symmetric keys you use block cipher and authentication keys as with security suite zero.
2. Check this link:
http://www.gurux.fi/PublicKeyCryptography
Thanks for your kindness.
I have one more question related #3.
(It's for non-repudiation purposes.)
Is there any way to verify non-repudiation of message signed by ECDSA later?
For example, how to validate lp data received older than one month ago.
Is there any good way?
If you have the public key you can verify the signed message later. The signature is part of the DLMS message. I'll add an example below.
7E A0 84 03 31 54 8E 2E E6 E6 00 DF 00 08 47 58 43 6C 69 65 6E 74 08 41 42 43 44 45 46 47 48 00 00 20 C8 1E 31 00 00 00 70 4B A5 0B 37 48 4E 91 9F B1 CC FE 55 AD 58 3F C5 FA 2E 04 0D BD DD FC 81 E2 40 5F 63 68 1D 77 D9 B0 8C CA 0C 1C 6B A2 11 EB DA 44 CA ED 72 B8 1F 9A 43 6E 92 9D F1 CC 7C F3 10 BB 3E CC 4A D9 3A 05 9C 9B C0 83 D5 F5 3E 43 5B E1 10 D7 4B 0A 62 F6 37 CD 14 D1 1B 89 29 15 4E 9F 9F 7E
<HDLC len="83" >
<TargetAddress Value="1" />
<SourceAddress Value="18" />
<FrameType Value="54" />
<PDU>
<GeneralSigning>
<TransactionId Value="0000000000000000" />
<OriginatorSystemTitle Value="4758436C69656E74" />
<RecipientSystemTitle Value="4142434445464748" />
<DateTime Value="" />
<OtherInformation Value="" />
<!-- Security : AuthenticationEncryption -->
<!-- Security Suite: Suite1 -->
<!-- Invocation Counter: 112 -->
<!-- Decrypt data: C0 01 C1 00 0F 00 00 28 00 00 FF 02 00
<GetRequest>
<GetRequestNormal>
# Priority: High, ServiceClass: Confirmed, Invoke ID: 1
<AttributeDescriptor>
# AssociationLogicalName
<ClassId Value="000F" />
# 0.0.40.0.0.255
<InstanceId Value="0000280000FF" />
# Object List
<AttributeId Value="02" />
</AttributeDescriptor>
</GetRequestNormal>
</GetRequest>
<Content Value="C81E31000000704BA50B37484E919FB1CCFE55AD583FC5FA2E040DBDDDFC81E2" />
<Signature Value="5F63681D77D9B08CCA0C1C6BA211EBDA44CAED72B81F9A436E929DF1CC7CF310BB3ECC4AD93A059C9BC083D5F53E435BE110D74B0A62F637CD14D11B8929154E" />
</GeneralSigning>
</PDU>
</HDLC>
