  3. GXDateTime and Convetring Date Time (Python)
GXDateTime and convetring Date Time (Python)
By Lotusv , 5 May, 2022
When using the functions GXDateTime and GXDLMSClient.changeType
at some time, I began to have a discrepancy of 1 hour. When forward, when backward.
2022-03-27 03:00:00 in my zone (UTC+2) there was a change of time 1 hour ahead (to UTC+3).
Now in system:
Therefore TZ='Europe/Kiev' will be used.
Selected time is now: Thu May 5 18:14:26 EEST 2022.
Universal Time is now: Thu May 5 15:14:26 UTC 2022.
So...
Cdatetime: 2022-03-27 00:00:00
After:
GfromDate = GXDateTime(Cdatetime.replace(hour = 0, minute = 0, second = 0, microsecond = 0))
GtoDate = GXDateTime(datetime.datetime.now().replace(hour = 0, minute = 0, second = 0, microsecond = 0))
print(GfromDate, " ||| ", GtoDate, " ||| D Cdatetime: ", Cdatetime)
03/26/22 23:00:00 ||| 05/05/22 00:00:00 ||| D Cdatetime: 2022-03-27 00:00:00
After using GXDateTime I get -1 hour
In the same time:
print(Cdatetime1)
GfromDate1 = GXDateTime(Cdatetime1.replace(hour = 0, minute = 0, second = 0, microsecond = 0))
print(GfromDate1, " ||| D1 Cdatetime1: ", Cdatetime1)
2022-04-06 00:00:00
04/06/22 00:00:00 ||| D1 Cdatetime1: 2022-04-06 00:00:00
and...
Here I read the normal date-time from the counter, but I get an hour more.
GXDT = GXDLMSClient.changeType(Daydata[0][4], DataType.DATETIME)
DT = GXDT.toUnixTime(GXDT)
DayCurrent = datetime.datetime.fromtimestamp(time.mktime(DT))
print(type(GXDT), "|", type(DT), "|", type(DayCurrent), "|", type(time.mktime(DT)))
print(GXDT, "||", DT, "||", DayCurrent, time.mktime(DT))
<class 'gurux_dlms.GXDateTime.GXDateTime'> | <class 'time.struct_time'> | <class 'datetime.datetime'> | <class 'float'>
04/18/22 00:00:00 || time.struct_time(tm_year=2022, tm_mon=4, tm_mday=18, tm_hour=0, tm_min=0, tm_sec=0,
tm_wday=0, tm_yday=108, tm_isdst=0) || 2022-04-18 01:00:00 | 1650232800.0
I get time.struct_time with tm_isdst=0. I want to get tm_isdst=1. Maybe using timezone information solved the problem.
I trying
GXDT = GXDLMSClient.changeType(Daydata[0][4], DataType.DATETIME, useUtc=True)
but nothing changed.
At the same time:
UnixTime: 1650232800
GMT: Sun, 17 Apr 2022 22:00:00 GMT
Your time zone (UTC+3): 18.04.2022, 01:00:00
Looks like an error is happening in time.mktime(DT)
I can not understand what is the matter and where did I go wrong?
Lotusv
4 years 6 months ago
I shink that in
I shink that in GXDateTime.py
@classmethod
def fromUnixTime(cls, unixTime):
return GXDateTime(datetime.datetime(unixTime * 1000))
@classmethod
def fromHighResolutionTime(cls, unixTime):
return GXDateTime(datetime.datetime(unixTime))
looks like
@classmethod
return GXDateTime(datetime.datetime.fromtimestamp(unixTime * 1000))
and
@classmethod
return GXDateTime(datetime.datetime.fromtimestamp(unixTime))
because there are mistakes (in fromUnixTime):
"integer argument expected, got float"
if I convert to int:
"signed integer is greater than maximum"
if I Unix timestamp devide by 1000 :
"function missing required argument 'month' (pos 2)"
i use fromHighResolutionTime for 10 digits unixtime
Lotusv
my second problem I decide:
DayCurrent = datetime.datetime(*DT[:6])
04/19/22 00:00:00 || time.struct_time(tm_year=2022, tm_mon=4, tm_mday=19, tm_hour=0, tm_min=0, tm_sec=0, tm_wday=1, tm_yday=109, tm_isdst=0) || 2022-04-19 00:00:00
Lotusv
But why use GXDateTime in
But why use GXDateTime in Reader.readRowsByRange ?
when you can use standart datetime !!! That's right?
It might be that your meter is not using DST. It might also be that your meter is not using a different deviation than you. There are several reasons why this might occur.
http://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSClock
Can you add a hex trace here from Daydata[0][4] so I can check the values and tell why this is happening.
