  3. HDLC 4 Byte Server Address Error With C Library
HDLC 4 byte server address error with C library
By Zappa , 17 March, 2022
I´m connecting with AC6000 meter. Client address:0x01 Phy server:0x11 Logical address:0x01
Those are the frames:
Sending SNRM...
TX: 7E A0 08 02 23 03 93 3E 74 7E
RX: 7E A0 23 03 00 02 00 23 73 C0 48 81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01 CE 6A 7E
Server address bytes are: 00 02 00 23 ,is a 4 byte HDLC address.
Gurux Director is working properly, but when I try with C library I get DLMS_ERROR_CODE_FALSE with server address.
Any clue about how to solve this in C library?
Thank you.
4 years 4 months ago
The meter's server address can be expressed in two bytes, but the AC6000 requires four bytes.
You can count it like this:
settings.serverAddress = cl_getServerAddress(1, 17, 4);
Zappa
Thank you very much for your
Thank you very much for your quick answer....I´ll try this.
Best regards
fon Luck
4 years 3 months ago
Hello!
Hello!
In file dlms.c function dlms_check Hdlc Address() save target address into setting->server Address.
But, target address converted to uint16_t, therefore hi address is lost and is Target() can't check it.
I find this closed issue: http://www.gurux.fi/node/15797
In reply to Hello! by fon Luck
Hello fon Luck,
Hello fon Luck,
Please, create a new topic if you have a new question. It's impossible to keep track what was the original question.
I believe that you are right. I need to verify why this is cast to uint16_t. I'll get back to this as soon as I have more info.
  • BaEdhlfwwvUqFMkOYk
  • CrzONrPdvkWUif…
  • kra4026
  • HilipLot
  • NithnCXPiBJHVG…
