By ichsan05 , 31 March, 2022 Forums DLMSDirector Hello I'm trying to connect to my EDMI MK7MI using RS-232 but it always give me invalid wirelessMbus frame response and cannot connect to the meter, i'll attach the following response from notification side on DLMSDirector 31/03/2022 15:02:08 <WirelessMBus len="17" > <TargetAddress Value="44" /> <SourceAddress Value="33" /> <PDU> <Data="334433443344" /> </PDU> </WirelessMBus> Invalid WirelessMBus Thank you. Hi, Hi, Can you add raw data so I can check what framing your meter is using? BR, Mikko Thank you for fast response, Thank you for fast response, this is the raw data : 1. A9 3A A0 23 21 0 2 0 47 73 C3 C7 81 80 14 5 2 1 60 6 2 1 60 7 4 0 0 0 1 8 4 0 0 0 1 DE 89 7E 2. 0 37 1A A0 23 21 0 2 0 47 73 C3 C7 81 80 14 5 2 1 60 6 2 1 60 7 4 0 0 0 1 8 4 0 0 0 1 DE 89 7E Hi, Hi, This frame doesn't look correct. There is UA reply, but the frame is invalid. Check your serial port settings. Try to connect with GXDLMSDirector. BR, Mikko
