  3. Read Meter Data With RS-232 From GXDLMSDirector
Read Meter data with RS-232 from GXDLMSDirector
By ichsan05 , 31 March, 2022
Hello
I'm trying to connect to my EDMI MK7MI using RS-232
but it always give me invalid wirelessMbus frame response and cannot connect to the meter, i'll attach the following response from notification side on DLMSDirector
31/03/2022 15:02:08
<WirelessMBus len="17" >
<TargetAddress Value="44" />
<SourceAddress Value="33" />
<PDU>
<Data="334433443344" />
</PDU>
</WirelessMBus>
Invalid WirelessMBus
Thank you.
4 years 2 months ago
Can you add raw data so I can check what framing your meter is using?
ichsan05
Thank you for fast response,
this is the raw data :
1. A9 3A A0 23 21 0 2 0 47 73 C3 C7 81 80 14 5 2 1 60 6 2 1 60 7 4 0 0 0 1 8 4 0 0 0 1 DE 89 7E
2. 0 37 1A A0 23 21 0 2 0 47 73 C3 C7 81 80 14 5 2 1 60 6 2 1 60 7 4 0 0 0 1 8 4 0 0 0 1 DE 89 7E
This frame doesn't look correct. There is UA reply, but the frame is invalid. Check your serial port settings. Try to connect with GXDLMSDirector.
