  3. Error While Start Conformance Test With Gurux.DLMS.AMI
Error while start conformance test with Gurux.DLMS.AMI
Profile picture for user riahtu
By riahtu , 18 February, 2022
Known problems
I am using DLMSDirector with Gurux.DLMS.AMI
When start a conformance test, I get the popup error message:
Unable to cast object of type 'Gurux.DLMS.GXDLMSMeter' to type 'GXDLMSDirector.GXDLMSDevice'.
What could be the bug? Thanks in advance for your help.
Best regards,
Uthai
4 years 8 months ago
Hi Uthai,
Hi Uthai,
Conformance tests are not planned to work with Gurux.DLMS.AMI. Conformance tests are for meter developers when they are using a direct connection for the meter.
riahtu
4 years 7 months ago
In reply to Hi Uthai, by Kurumi
Thank you.
Thank you.
Best Regards,
Uthai
  • hezhangnihao@163.com
  • ZilvinasN
  • Yosr
  • albino.ramon
  • JosepM
