  3. Changing Server Address
Changing server address
By kristupas , 11 February, 2022
I have few questions:
1) Is it possible to change meter's server address using gurux cpp library?
2) How does 5-pass authentication works? I am reading Shenzhen CLOU electronics meter documentation and they state that they use HLS-5 pass authentication with challenge mechanism. Is that GMAC authentication? If so, what kind of data do we need to know in order to connect to establish secured connection. Authentication, blockCipherKeys?
4 years 5 months ago
1. It depends on the meter and communication channel. If you are using HDLC you can try changing the Device address.
http://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSIecHdlcSetup
2. HLS-5 is using GMAC. You need to know authentication and block cipher keys to establish the connection.
kristupas
Thanks for the answers. These
Thanks for the answers. These keys should be provided by the manufacturer, right?
Yes, The manufacturer is the only one who knows those keys.
  • BaEdhlfwwvUqFMkOYk
  • CrzONrPdvkWUif…
  • kra4026
  • HilipLot
  • NithnCXPiBJHVG…
