  3. Attribute Type
Attribute type
By Ivan23 , 7 January, 2022
When we configuring an external test, can it be set in .xml file to expect a response e.g. octetString of 8 bytes (octetString [8]), or octetString of 6 (octetString [6]), or Gurux can only expect octetString no matter what length is the value? In other words, can I add some range of bytes for octetString as expected response?
Thank you
Ivan23
4 years 9 months ago
Can you give me any kind of
Can you give me any kind of answer please?
This is not possible at the moment. You can compare only bytes, not the length of the octet string.
Ivan23
Thank you for the answer
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
