but when I want to read load profile, gurux does not respect to this setting , and sent ack for different received packet counts. this cause a lot of duplicate packets receiving from meter. and sometimes cause parsing error.
in one of load profile reading that I have it's packets, gurux sent ack, after 5 packets receiving, but it should sent ack after 7th packet. this cause parsing error.
I couldn't find any place to upload packets.but if it's needed ,I can email it
This should work without problems. What programming language you are using?
Can you add a hex trace from profile generic reading here so I can check what is happening?
I use GxDlmsCommunicator from gxdlmsDirector on my client side :
so I use this code:
internal void ReadDataBlock(byte[] data, string text, int multiplier, int tryCount, GXReplyData reply)
lastTransaction = DateTime.Now;
if (Parent.OnTrace != null)
Parent.OnTrace(lastTransaction, Parent, text + "\r\nTX:\t", data, 0, LogFile, 0);
//Synchronous lock is needed because GBT might cause that there are multiple replies and
//we don't want to handle them as notifications.
lock (Media.Synchronous)
ReadDLMSPacket(data, tryCount, reply);
if (OnDataReceived != null)
OnDataReceived(this, reply);
if (reply.IsMoreData)
if (reply.TotalCount != 1)
NotifyProgress(text, 1, multiplier * reply.TotalCount);
while (reply.IsMoreData)
if (!reply.IsStreaming())
data = Client.ReceiverReady(reply);
Parent.OnTrace(DateTime.Now, Parent, "\r\nTX:\t", data, 0, LogFile, 0);
else
data = null;
ReadDLMSPacket(data, reply);
NotifyProgress(text, reply.Count, multiplier * reply.TotalCount);
hi, are you working on this problem or it's Ok with you ?
if you want to check if this happen or not and if u have ace6000 meter, you can use GXDLMSDirector and change "window size in receive" to 7 in "frame" tab, and try to read profile generic like '0.0.99.2.0.255'
I checked again but the problem is not solved.nothing should change in "ReadDataBlock" method or in IsStreaming ?
I checked the packets and the RR ready sent on third packet received for Window receive size =7.
TX: 1/29/2022 7:43:31 AM 7EA04F00020E6B03105B8EE6E600C001C100070000630100FF0201010204020412000809060000010000FF0F02120000090C07E60119FF000000FFFF2E00090C07E6011AFF000000FFFF2E000100C0BF7E
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
I checked command line parameter that you used , and notice that you use -W that is "General Block Transfer window size" and it's not "Window Size in Receive" that I mean.
I checked packets with -W parameter and noticed that, in this case ack sent for each received packet and not for 7 that is supposed.
This is interesting. In the trace that you have given in #21 Your meter sets the Final flag for the 3rd message. That indicates that the client must ask for the next frames. So in this scenario, the client is working correctly and there is something wrong with the meter. Ask if there is a firmware update available for the meter.
it's Ok with meter own software and every thing work correctly. if it can help,I can send it's packets also.
sorry I'm asking again, but did you notice "General Block Transfer window size" and "Window Size in Receive" ?
when we set "GBT" to 7 , there is not difference in SNRM frame and <WindowSizeRX Value="1" /> does not change and every thing works ok, because ack sent for each packet separately.
but when setting WindowSizeRX = 7 in snrm packet, this component does not work correctly for first paket. (it sent ack after 5 instead of 7 packets). but in later packets it works correctly. and at end , it can't parse received packets correctly and generate error in this line :
Client.UpdateValue(CurrentProfileGeneric, 2, reply.Value);
Your meter is sending invalid frames in your hex trace. I don't know if the connection is bad and that is causing the issue or if there are problems with the meter. In the trace file, the client application just ignores invalid frames and reads profile generic again.
I would say that try to use Window size 3 or one. There is a problem, but I can't say for sure what is causing it.
The meter is in local lan and there is no connection issue.
With window size 1, it's Ok and I can read without any problem.
With window size 2 , some packets sent and received more than once.
With any value other than 1 and 2, gurux can't translate received packets and generate "Invalid cast exception".
you said the client app , ignores invalid frames, How can I add this to my code ?
Reading again does not solve the problem, I want mechanism to ignore only invalid frames like what meter own software does.
there is no problem with meter own software ,that I can ask for firmware update.
the problem relies on your code. I think there is special case that you didn't handle .
I'll appreciate deeply if you can check meter own software packets agian, to see if you can understand difference with gurux generated packets.
thank you very much
The other application is using frame size 128 which is the default. You are using Tx value 117 and RX 114. Change them to default values and try to read again.
There are several different parameters in DLMS and each affects communication. If one of your settings is different from the meter expect the communication might fail.
Set UseFrameSize to false. Then read the meter and add hex trace here so I can check from the bytes what is happening.
Your other application is reading only 0.0.99.128.1.255 and 0.0.99.129.1.255. Profile generic buffers are so small that all data is fit to one frame. Can you read 0.0.99.1.0.255 with other application and add hex trace here so I can verify this?
is there any progress in this matter ?
for hint, if you use GXDLMSDirector to read sl7000 or ace6000 meters with attach setting,
you will receive "invalid frame type" or "unable to cast object type system.int32 to type system.collection.generic.ienumerable`1[system.object]" errors in this meters respectively.
Those errors are coming because the content of the data is not valid.
When client reads 0.0.99.129.1.255 the meter reply this.
7E A8 8C 03 00 22 8A...
This is correct and the client waits for the next reply from the meter. The next reply is this that tells that all the frames are received:
7E A0 15 03 00 22 8A 7F 76 78 1B 08 FF 0F 2D 00 FF 80 00 00 42 E2 7E
Next your client ask next frame and this is wrong because all the frames are already received. Window size is 7 so meter should send all the frames and not stop after sending two frames.
7E A0 0A 00 22 8A 7F 03 91 98 F5 7E
This meter is working differently than the standard says and I propose that you use Windows size 1 to read the meter.
Hi, thank you for your reply.
But I think there is a missing part in your code. When we use meter own software to read it, it's send A8 after 7th packet and correctly does it.
But when we use gurux, this happens
I added meter own software packets also.
we are using c#. and the
we are using c#. and the meter is ace6000.
7ea02100020e6b03936c1a81801205017506017207040000000108040000000750e17e
7ea0230300020e6b737dd0818014050200720602007507040000000708040000000128367e
7ea04700020e6b0310b750e6e6006036a1090607608574050801018a0207808b0760857405080201ac0a80084142434445464748be10040e01000000065f1f0400ffffffffff6be37e
7ea0530300020e6b30aeb1e6e7006142a109060760857405080101a203020100a305a10302010088020780890760857405080201aa0a80084142434445464748be10040e0800065f1f040000301d21340007fa427e
7ea01c00020e6b0332ea56e6e600c001c100080000010000ff0300b8037e
7ea0140300020e6b52a4f1e6e700c401c1010373827e
7ea01c00020e6b0354da50e6e600c001c100080000010000ff0200601a7e
7ea0210300020e6b747993e6e700c401c100090c07e60108060e2324ff800000a38f7e
7ea01c00020e6b0376ca52e6e600c001c100030101000805ff030043847e
7ea0190300020e6b96c35fe6e700c401c10002020f001606a8487e
7ea01c00020e6b0398ba5ce6e600c001c100030101000805ff02009b9d7e
7ea0160300020e6bb84b8ee6e700c401c10012000ff4497e
7ea01c00020e6b03baaa5ee6e600c001c100070000638101ff0300dd877e
7ea87e0300020e6bca0b89e6e700c401c100010a020412000309060101011d00ff0f01120000020412000309060101011d00ff0f03120000020412000309060101021d00ff0f01120000020412000309060101021d00ff0f03120000020412000309060101031d00ff0f01120000020412000309060101031d00ff0f03638e7e
7ea0570300020e6bdcbaf3120000020412000309060101041d00ff0f01120000020412000309060101041d00ff0f03120000020412000409060000603805ff0f05120000020412000409060000603806ff0f051200003dd27e
7ea01c00020e6b03dc9a58e6e600c001c100070000638101ff0200059e7e
7ea06b0300020e6bfe7a96e6e700c401c1000101020a09060101011d00ff02020f03161e09060101021d00ff02020f03161e09060101031d00ff02020f03162009060101041d00ff02020f031620090c07e50c0dffffffffff8000ff090c07e60108ffffffffff8000fff6f17e
7ea01c00020e6b03fe8a5ae6e600c001c100070000630200ff0300ff0c7e
7ea87e0300020e6b005de0e6e700c401c1000108020412000109060000603801ff0f02120000020412000109060000603802ff0f02120000020412000109060000603803ff0f02120000020412000109060000603804ff0f02120000020412000309060101011d00ff0f02120000020412000309060101021d00ff0f028b087e7ea0330300020e6b123b17120000020412000309060101031d00ff0f02120000020412000309060101041d00ff0f02120000e7ad7e
7ea04f00020e6b03105b8ee6e600c001c100070000630200ff0201010204020412000809060000010000ff0f02120000090c07e60108ff000000ffff2e00090c07e60109ff000000ffff2e000100d8bb7e
7ea87e0300020e6b247b87e6e700c402c10000000001008203ce013a02080202090c07e60108ffffffffff8000ff04060000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010b3687e
7ea87e0300020e6b2669a4000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010c9cf7e
7ea87e0300020e6b28174d0000100000020800000000100000100000100000100000020800000000100000100000100000100000020800000000100000100000100000100000020800000000100000100000100000100000020800000000100000100000100000100000020800000000100000100000100000100000028f377e
7ea87e0300020e6b2a056e080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010d9647e
7ea87e0300020e6b3cb21b000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010c9cf7e
7ea00a00020e6b033175897e
7ea87e0300020e6b224de2e6e700c402c10000000001008203ce013a02080202090c07e60108ffffffffff8000ff04060000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010b3687e
7ea87e0300020e6b247b87000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010c9cf7e
7ea87e0300020e6b2669a40000100000020800000000100000100000100000100000020800000000100000100000100000100000020800000000100000100000100000100000020800000000100000100000100000100000020800000000100000100000100000100000020800000000100000100000100000100000028f377e
7ea87e0300020e6b28174d080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010d9647e
7ea87e0300020e6b2a056e000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010c9cf7e
7ea87e0300020e6b2c330b0000100000020800000000100000100000100000100000020800000000100000100000100000100000020800000000100000100000100000100000020800000000100000100000100000100000020800000000100000100000100000100000020800000000100000100000100000100000028f377e
7ea87e0300020e6b3ea038080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010d9647e
7ea00a00020e6b035173ea7e
7ea87e0300020e6b2e2128080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010d9647e
7ea87e0300020e6b30ded1000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010c9cf7e
7ea00a00020e6b037171cb7e
7ea87e0300020e6b205fc1000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010c9cf7e
7ea0590300020e6b32eb7b000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000094247e
7ea01600020e6b0392b71ae6e600c002c10000000151be7e
7ea0730300020e6b540ff7e6e700c402c10100000002005a02080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000099427e
7ea00a00020e6b035361c97e
7ea00a0300020e6b73c7f27e
for hint , the problem is in
for hint , the problem is in this RR :
Can you verify that you are using the latest version?
Yes I updated to latest
Yes I updated to latest version Saturday
Check that you are checking IsStreaming in your client code. Like in the client example:
https://github.com/Gurux/Gurux.DLMS.Net/blob/7998645cf941d2d938c77cbd1b…
Try to read your meter with client example using command line parameters:
-h YOUR_METER_IP_ADDRESS -p YOUR_METER_PORT_NUMBER -c 1 -s 17333 -a Low -P 12345678 -W 7 -f 117 -t Verbose
If it fails add hex output here and I check the problem.
so I use this code:
else
data = null;
I checked it again and this
I checked it again and this line of code
else
data = null;
never hits. it's always return false for streaming
Reading profile generic data
TX: 1/11/2022 4:11:56 PM 7EA04F00020E6B03105B8EE6E600C001C100070000630200FF0201010204020412000809060000010000FF0F02120000090C07E60108FF000000FFFF2E00090C07E60109FF000000FFFF2E000100D8BB7E
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
TX: 1/11/2022 4:11:57 PM 7EA00A00020E6B033175897E
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
TX: 1/11/2022 4:11:58 PM 7EA00A00020E6B035173EA7E
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
TX: 1/11/2022 4:11:59 PM 7EA00A00020E6B037171CB7E
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
TX: 1/11/2022 4:12:00 PM 7EA01600020E6B0392B71AE6E600C002C10000000151BE7E
RX: 1/11/2022 4:12:01 PM 7EA87E0300020E6B54FCF4E6E700C402C101000000020082030602080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000009047E
TX: 1/11/2022 4:12:01 PM 7EA00A00020E6B03B17D0D7E
RX: 1/11/2022 4:12:02 PM 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
If you are using GXDLMSDirector and it seems that you have the source codes
update Gurux.DLMS.dll for version 9.0.2201.1002.
I believe it will solve your problems.
No I don't use GXDLMSDirector
No I don't use GXDLMSDirector,
But I updated dlms. Net to latest version in my code
hi, I checked "Gurux.DLMS.dll
hi, I checked "Gurux.DLMS.dll" to be the latest version and I also debugged my code again,
but "reply.IsStreaming()" is always returns false.
I can set static Ip/port on
I can set static Ip/port on meter for you to check this problem. do you think it's useful ?
This is checked and it worked like expected. You can try this with GXDLMSDirector. Select "Frame" tab and set Window Receive in transmit to 7.
Good news. This can be repeated. One of the settings was different in your ACE 6000 than the test meter and this issue was hidden because of that.
The tests are started and the new version is released next week.
Thank you very much for
Thank you very much for retesing this issue. I'll appreciate if you inform me about new version release in this thread.
The new version from Gurux.DLMS.Net is released. Let me know if you have any problems.
TX: 1/29/2022 7:43:32 AM 7EA00A00020E6B033175897E
please also check my reply
please also check my reply for your comment #8.
I mean this one :
Can you add your own software packets? I'll verify them and let you know after that.
Your meter is not using General Block Transfer and those features are ignored.
You mean, meter own software
You mean, meter own software packets or our software packets?
The meter software packets.
here is the meter packets. if
here is the meter packets. if you want to check snrm packets,they are available at the end of packets.
7ea01c00020e6b0354da50e6e600c0018100010000880002ff0200f5fc7e
7ea88c0300020e6b649565e6e700c40181000108020711380fff11230300110011001120020711390fff112303001100110011340207113a0fff11230300110011001148020711350ffd1121030011001100111f020711360ffd1121030011001100113302071137
0ffd11210300110011001147020711ff0f0011ff0300110111ff11ff020711ff0f001148bc7e7ea0150300020e6b765709ff0300110111ff11ff32ee7e
7ea01c00020e6b0396c4b5e6e600c0018100010000880102ff0200b1f77e
7ea88c0300020e6b88f748e6e700c40181000108020711000f03111e0300110111001101020711010f03111e0300110111001102020711020f0311200300110111001103020711030f0311200300110111001104020711ff0f0011ff0300110111ff11ff020711ff0f0011ff0300110111ff11ff020711ff0f0011ff0300110111ff11ff020711ff0f0011ab727e7ea0150300020e6b9a3524ff0300110111ff11ff32ee7e
7ea01c00020e6b03d8be1ee6e600c00181000100008e0002ff02000fe47e
7ea01b0300020e6bbc20e6e6e700c40181000906000400000104d2287e
7ea01c00020e6b03faae1ce6e600c0018100010000940101ff020038a17e
7ea0170300020e6bdeae17e6e700c40181000201110493937e
7ea00a00020e6b031177a87e
7ea00a0300020e6bd1df747e
7ea02100220e6b0393fd7a818012050180060180070400000001080400000007655e7e
7ea0230300220e6b732e5f818014050200800602008007040000000708040000000103327e
7ea04700220e6b03102630e6e6006036a1090607608574050801018a0207808b0760857405080201ac0a80084142434445464748be10040e01000000065f1f04001c1c3d00009c0b7e
7ea0530300220e6b30fd3ee6e7006142a109060760857405080101a203020100a305a10302010088020780890760857405080201aa0a80084142434445464748be10040e0800065f1f040000101d213400079ac77e
7ea01c00220e6b03327b36e6e600c0018100070000638001ff020044587e
7ea0870300220e6b524de5e6e700c40181000101020e09060101201b00ff02020fff162309060101341b00ff02020fff162309060101481b00ff02020fff1623090601011f1b00ff02020ffd162109060101331b00ff02020ffd162109060101471b00ff02020ffd1621090c07e50c0dffffffffff8000ff090c07e60108ffffffffff8000ffb5d17e
7ea01c00220e6b03544b30e6e600c0018100070000638101ff020000537e
7ea06b0300220e6b747b32e6e700c40181000101020a09060101011d00ff02020f03161e09060101021d00ff02020f03161e09060101031d00ff02020f03162009060101041d00ff02020f031620090c07e50c0dffffffffff8000ff090c07e60108ffffffffff8000ff29617e
7ea00a00220e6b0371e0ab7e
7ea00a0300220e6b71865e7e
7ea01c00220e6b03765b32e6e600c0018100070000638101ff020000537e
7ea06b0300220e6b9667f6e6e700c40181000101020a09060101011d00ff02020f03161e09060101021d00ff02020f03161e09060101031d00ff02020f03162009060101041d00ff02020f031620090c07e50c0dffffffffff8000ff090c07e60108ffffffffff8000ff29617e
7ea88c00220e6b03984322e6e600c0018100070000630200ff020101020400090c07e60108ffffffffffffffff090cffffffffffffffffffffffff0108020412000109060000603801ff0f02120000020412000109060000603802ff0f02120000020412000109060000603803ff0f02120000020412000109060000603804ff0f02120000020412000309760a7e
7ea00a0300220e6bb18a987e
7ea04e00220e6b039a4d5a060101011d00ff0f02120000020412000309060101021d00ff0f02120000020412000309060101031d00ff0f02120000020412000309060101041d00ff0f0212000005fe7e
7ea88c0300220e6bc8a085e6e700c4018100013102080202090c07e60108ffffffffff8000ff04060000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000c6e7e
7ea88c0300220e6bcab2a6001000001000000208000000001000001000001000001000000208000000001000001000001000001000000208000000001000001000001000001000000208000000001000001000001000001000000208000000001000001000001000001000000208000000001000001000001000001000000208000000001000001000001061187e
7ea88c0300220e6bcc84c30000100000020800000000100000100000100000100000020800000000100000100000100000100000020800000000100000100000100000100000020800000000100000100000100000100000020800000000100000100000100000100000020800000000100000100000100000100000020800000000100000100000100000b1907e
7ea88c0300220e6bce96e01000000208000000001000001000001000001000000208000000001000001000001000001000000208000000001000001000001000001000000208000000001000001000001000001000000208000000001000001000001000001000000208000000001000001000001000001000000208000000001000001000001000001000becd7e
7ea88c0300220e6bc0e8090002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002a9c17e
7ea88c0300220e6bc2fa2a080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080000000010000010000010000010000002080044387e
7ea88c0300220e6bd44d5f0000001000001000001000001000000208000000001000001000001000001000000208000000001000001000001000001000000208000000001000001000001000001000000208000000001000001000001000001000000208000000001000001000001000001000000208000000001000001000001000001000000208000000c32b7e
7ea0190300220e6bd6949200100000100000100000100000e4117e
7ea01c00220e6b039c0f7ae6e600c0018100010000880101ff02007cd27e
7ea01e0300220e6bf8f09de6e700c4018100020412000f110111011100635d7e
7ea00a00220e6b03b1ec6d7e
7ea00a0300220e6bf18eda7e
7ea00a00220e6b0353f0a97e
7ea00a0300220e6b73947d7e
7ea02100020e6b03936c1a818012050180060180070400000001080400000007655e7e
7ea0230300020e6b737dd0818014050200800602008007040000000708040000000103327e
7ea04700020e6b0310b750e6e6006036a1090607608574050801018a0207808b0760857405080201ac0a80084142434445464748be10040e01000000065f1f04001c1c3d00009c0b7e
7ea0530300020e6b30aeb1e6e7006142a109060760857405080101a203020100a305a10302010088020780890760857405080201aa0a80084142434445464748be10040e0800065f1f040000101d213400079ac77e
7ea00a0300020e6b31d1937e
Can you get a useful
Can you get a useful understanding from this packets ?
did you find anything new ?
You can try to catch the exception and read the meter again. Ask also if there is a firmware update available for the meter that fixes this.
thank you very much
it's because I use
it's because I use "UseFrameSize = true," in my setting. I tested without it, and nothing changed.
still the same error
Send SNRM request.
Send SNRM request.
TX: 7EA02100028A7F03931AA3818012050180060180070400000001080400000007655E7E
RX: 7EA0230300028A7F73014D818014050200800602008007040000000708040000000103327E
Send AARQ request.
TX: 7EA04700028A7F0310C1E9E6E6006036A1090607608574050801018A0207808B0760857405080201AC0A80084142434445464748BE10040E01000000065F1F0400FFFFFFFFFF6BE37E
RX: 7EA0530300028A7F30D22CE6E7006142A109060760857405080101A203020100A305A10302010088020780890760857405080201AA0A80084142434445464748BE10040E0800065F1F040000301D21340007FA427E
Read object type Clock index: 3
TX: 7EA01C00028A7F03329CEFE6E600C001C100080000010000FF0300B8037E
RX: 7EA0140300028A7F52D86CE6E700C401C1010373827E
Read object type Clock index: 2
TX: 7EA01C00028A7F0354ACE9E6E600C001C100080000010000FF0200601A7E
RX: 7EA0210300028A7F74050EE6E700C401C100090C07E60208020D2D29FF800000AC007E
Read object type Register index: 3
TX: 7EA01C00028A7F0376BCEBE6E600C001C100030101000804FF0300F8987E
RX: 7EA0190300028A7F96BFC2E6E700C401C10002020F001606A8487E
Read object type Register index: 2
TX: 7EA01C00028A7F0398CCE5E6E600C001C100030101000804FF020020817E
RX: 7EA0160300028A7FB83713E6E700C401C10012000FF4497E
Read object type ProfileGeneric index: 3
TX: 7EA01C00028A7F03BADCE7E6E600C001C100070000638001FF0300998C7E
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
Reading profile generic data 0.0.99.128.1.255
TX: 7EA01C00028A7F03DCECE1E6E600C001C100070000638001FF020041957E
RX: 7EA0870300028A7FF07A71E6E700C401C1000101020E09060101201B00FF02020FFE162309060101341B00FF02020FFE162309060101481B00FF02020FFE1623090601011F1B00FF02020FFD162109060101331B00FF02020FFD162109060101471B00FF02020FFD1621090C07E60112FF101E00FF800000090C07E60208FF0D2D00FF800000937C7E
TX: 7EA01C00028A7F03FEFCE3E6E600C001C100070000630100FF030033117E
RX: 7EA88C0300028A7F02D9FEE6E700C401C100010A020412000109060000603701FF0F02120000020412000109060000603702FF0F02120000020412000109060000603703FF0F02120000020412000109060000603704FF0F02120000020412000309060101201B00FF0F02120000020412000309060101341B00FF0F02120000020412000309060101481BA5827E7EA0490300028A7F146A1700FF0F021200000204120003090601011F1B00FF0F02120000020412000309060101331B00FF0F02120000020412000309060101471B00FF0F0212000067937E
TX: 7EA04F00028A7F03102D37E6E600C001C100070000630100FF0201010204020412000809060000010000FF0F02120000090C07E60206FF000000FFFF2E00090C07E60209FF000000FFFF2E00010030917E
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
TX: 7EA00A00028A7F033103307E
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
TX: 7EA00A00028A7F035105537E
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
TX: 7EA00A00028A7F037107727E
RX: 7EA88C0300028A7F26FF990000000500005795050000579F050000579A050000000005000000000500000004020A0000000005000057BE05000057C805000057C3050000000005000000000500000003020A000000000500005782050000578C0500005787050000000005000000000500000003020A0000000005000057A405000057AE05000057AA0500A9477E7EA88C0300028A7F28817000000005000000000500000004020A0000000005000057DA05000057E405000057DF050000000005000000000500000004020A0000000005000057D105000057DC05000057D7050000000005000000000500000003020A0000000005000057CE05000057D805000057D3050000000005000000000500000003020A0000000005BDCA7E7EA88C0300028A7F2A93530000580C05000058170500005812050000000005000000000500000003020A000000000500005805050000580F050000580B050000000005000000000500000004020A0000000005000057DA05000057E405000057DF050000000005000000000500000004020A0000000005000057E605000057F005000057EB0500000000056BF57E7EA88C0300028A7F2CA536000000000500000004020A00000000050000580F05000058190500005814050000000005000000000500000004020A0000000005000057F6050000580105000057FC050000000005000000000500000004020A0000000005000058060500005811050000580C050000000005000000000500000004020A0000000005000057FFC7D37E7EA88C0300028A7F2EB71505000058090500005805050000000005000000000500000004020A0000000005000057BE05000057C905000057C4050000000005000000000500000004020A000000000500005770050000577A0500005775050000000005000000000500000004020A00000000050000575A050000576405000057600500000000050000000016D07E7EA88C0300028A7F20C9FC0500000004020A0000000005000056DF05000056E905000056E4050000000005000000000500000004020A000000000500005693050000569D0500005698050000000005000000000500000004020A0000000005000056AA05000056B405000056B0050000000005000000000500000004020A0000000005000056B905000056297C7E7EA88C0300028A7F325ACFC405000056BF050000000005000000000500000004020A000000000500005703050000570D0500005709050000000005000000000500000004020A000000000500005824050000582E0500005829050000000005000000000500000004020A000000000500005894050000589E0500005899050000000005000000000500000046037E
7ea02100028a7f03931aa38180120
7ea02100028a7f03931aa3818012050180060180070400000001080400000007655e7e
7ea0230300028a7f73014d818014050200800602008007040000000708040000000103327e
7ea04700028a7f0310c1e9e6e6006036a1090607608574050801018a0207808b0760857405080201ac0a80084142434445464748be10040e01000000065f1f04001c1c3d00009c0b7e
7ea0530300028a7f30d22ce6e7006142a109060760857405080101a203020100a305a10302010088020780890760857405080201aa0a80084142434445464748be10040e0800065f1f040000101d213400079ac77e
7ea01c00028a7f03329cefe6e600c0018100110000290000ff0200febe7e
7ea0430300028a7f520fd9e6e700c40181000102020212000109104143453738314d41333730303838393502021200110910414345373831454c3337303038383935ae4a7e
7ea01c00028a7f0354ace9e6e600c00181000100008e0101ff020086ca7e
7ea01e0300028a7f74bbc1e6e700c40181000a0930312e3032422e303169037e
7ea01c00028a7f0376bcebe6e600c0018100010000940600ff02005f8d7e
7ea0150300028a7f962573e6e700c4018100030104ec7e
7ea01c00028a7f0398cce5e6e600c00181000100005e5682ff020058c27e
7ea01b0300028a7fb8783de6e700c40181000906000000000001b74b7e
7ea02600028a7f03bac1d8e6e600c1018100010000600c04ff02000a084d414e41474552207dc87e
7ea0130300028a7fda80a3e6e700c501810036cf7e
7ea00a00028a7f03d10dd77e
7ea00a0300028a7fd1a3e97e
7ea00a00028a7f035317707e
7ea00a0300028a7f73bb6f7e
7ea01c00028a7f03329cefe6e600c0018100010000600100ff02008c6d7e
7ea01d0300028a7f52e12de6e700c40181000a0833373030383839354ffa7e
7ea01c00028a7f0354ace9e6e600c0018100010000880002ff0200f5fc7e
7ea88c0300028a7f64e9f8e6e700c401810001080207115a0ffe112303001100110011200207115b0ffe112303001100110011340207115c0ffe11230300110011001148020711570ffd1121030011001100111f020711580ffd11210300110011001133020711590ffd11210300110011001147020711ff0f0011ff0300110111ff11ff020711ff0f00113f077e
7ea0150300028a7f762b94ff0300110111ff11ff32ee7e
7ea01c00028a7f0396b20ce6e600c0018100010000880102ff0200b1f77e
7ea88c0300028a7f888bd5e6e700c40181000108020711030f03111e0300110111001101020711070f03111e03001101110011020207110b0f03112003001101110011030207110f0f0311200300110111001104020711030f03111e030011021100118d020711070f03111e030011021100118e0207115e0f0011ff0300110011001160020711ff0f0011603c7e
7ea0150300028a7f9a49b9ff0300110111ff11ff32ee7e
7ea01c00028a7f03d8c8a7e6e600c00181000100008e0002ff02000fe47e
7ea01b0300028a7fbc5c7be6e700c40181000906020404060104b1847e
7ea01c00028a7f03fad8a5e6e600c0018100010000940101ff020038a17e
7ea01a0300028a7fde9da4e6e700c4018100020211041213880d187e
7ea00a00028a7f031101117e
7ea02100228a7f03938bc3818012050180060180070400000001080400000007655e7e
7ea0230300228a7f7352c2818014050200800602008007040000000708040000000103327e
7ea04700228a7f03105089e6e6006036a1090607608574050801018a0207808b0760857405080201ac0a80084142434445464748be10040e01000000065f1f04001c1c3d00009c0b7e
7ea0530300228a7f3081a3e6e7006142a109060760857405080101a203020100a305a10302010088020780890760857405080201aa0a80084142434445464748be10040e0800065f1f040000101d213400079ac77e
7ea01c00228a7f03320d8fe6e600c0018100070000638001ff020044587e
7ea0870300228a7f523178e6e700c40181000101020e09060101201b00ff02020ffe162309060101341b00ff02020ffe162309060101481b00ff02020ffe1623090601011f1b00ff02020ffd162109060101331b00ff02020ffd162109060101471b00ff02020ffd1621090c07e60112ff101e00ff800000090c07e60208ff0f2d00ff80000021a77e
7ea01c00228a7f03543d89e6e600c0018100070000638101ff020000537e
7ea88c0300228a7f64ba77e6e700c40181000101021009060101011d00ff02020f03161e09060101021d00ff02020f03161e09060101031d00ff02020f03162009060101041d00ff02020f031620090601018d1c00ff02020f03161e090601018e1c00ff02020f03161e09060101601b00ff02020f0016ff090c07e60112ff101e00ff800000090c07e602219e7e
7ea0150300228a7f76781b08ff0f2d00ff80000042e27e
7ea00a00228a7f039198f57e
7ea00a0300228a7f71fac37e
7ea01c00228a7f0396236ce6e600c0018100070000638101ff020000537e
7ea88c0300228a7f88d85ae6e700c40181000101021009060101011d00ff02020f03161e09060101021d00ff02020f03161e09060101031d00ff02020f03162009060101041d00ff02020f031620090601018d1c00ff02020f03161e090601018e1c00ff02020f03161e09060101601b00ff02020f0016ff090c07e60112ff101e00ff800000090c07e602219e7e
7ea0150300228a7f9a1a3608ff0f2d00ff80000042e27e
7ea88c00228a7f03d831d9e6e600c0018100070000630200ff020101020400090c07e60205ffffffffffffffff090cffffffffffffffffffffffff010b020412000109060000603801ff0f02120000020412000109060000603802ff0f02120000020412000109060000603803ff0f02120000020412000109060000603804ff0f021200000204120003097b787e
7ea00a0300228a7fb1f6057e
7ea08400228a7f03da7309060101011d00ff0f02120000020412000309060101021d00ff0f02120000020412000309060101031d00ff0f02120000020412000309060101041d00ff0f021200000204120003090601018d1c00ff0f021200000204120003090601018e1c00ff0f02120000020412000309060101601b00ff0f02120000aeb97e
7ea88c0300228a7fccf85ee6e700c40281000000000100820f760182015f020b0202090c07e60205ffffffffff8000ff040600000000050000000305000000000500000000050000000005068378ea0536fb99b70500005000020b00000000050000000305000000000500000000050000000005068378ed0536fb99b70500005000020b000000000500008b157e
7ea88c0300228a7fceea7d000305000000000500000000050000000005068378f00536fb99b70500005000020b00000000050000000305000000000500000000050000000005068378f40536fb99b70500005000020b00000000050000000305000000000500000000050000000005068378f70536fb99b70500005000020b0000000005000000030500007d037e
7ea88c0300228a7fc0949400000500000000050000000005068378fa0536fb99b70500005000020b00000000050000000305000000000500000000050000000005068378fd0536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379000536fb99b70500005000020b0000000005000000030500000000050000f5c37e
7ea88c0300228a7fc286b70000050000000005068379030536fb99b70500005000020b00000000050000000405000000000500000000050000000005068379060536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379090536fb99b70500005000020b00000000050000000305000000000500000000050000414d7e
7ea88c0300228a7fc4b0d20000050683790d0536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379100536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379130536fb99b70500005000020b000000000500000003050000000005000000000500000000050683ac157e
7ea88c0300228a7fd623e179160536fb99b70500005000020b00000000050000000405000000000500000000050000000005068379190536fb99b70500005000020b000000000500000003050000000005000000000500000000050683791c0536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379200536fbba267e
7ea88c0300228a7fc8dc1899b70500005000020b00000000050000000305000000000500000000050000000005068379230536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379260536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379290536fb99b705000071f57e
7ea88c0300228a7fcace3b5000020b000000000500000003050000000005000000000500000000050683792c0536fb99b70500005000020b000000000500000004050000000005000000000500000000050683792f0536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379320536fb99b70500005000020b0021dc7e
7ea88c0300228a7fccf85e000000050000000305000000000500000000050000000005068379360536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379390536fb99b70500005000020b000000000500000003050000000005000000000500000000050683793c0536fb99b70500005000020b00000000050033387e
7ea88c0300228a7fceea7d000003050000000005000000000500000000050683793f0536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379420536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379450536fb99b70500005000020b000000000500000003050063a37e
7ea88c0300228a7fc094940000000500000000050000000005068379480536fb99b70500005000020b000000000500000003050000000005000000000500000000050683794b0536fb99b70500005000020b000000000500000003050000000005000000000500000000050683794e0536fb99b70500005000020b000000000500000003050000000005002a727e
7ea88c0300228a7fc286b7000000050000000005068379510536fb99b70500005000020b00000000050000000405000000000500000000050000000005068379540536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379570536fb99b70500005000020b00000000050000000305000000000500000000050062d17e
7ea88c0300228a7fd431c2000000050683795b0536fb99b70500005000020b000000000500000003050000000005000000000500000000050683795e0536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379610536fb99b70500005000020b0000000005000000030500000000050000000005000000000506d24b7e
7ea00a00228a7f037196127e
7ea88c0300228a7fc6a2f18379640536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379670536fb99b70500005000020b000000000500000003050000000005000000000500000000050683796a0536fb99b70500005000020b000000000500000003050000000005000000000500000000050683796d0536fc637e
7ea88c0300228a7fc8dc18fb99b70500005000020b00000000050000000305000000000500000000050000000005068379700536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379730536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379760536fb99b705002ed97e
7ea88c0300228a7fcace3b005000020b00000000050000000405000000000500000000050000000005068379790536fb99b70500005000020b000000000500000003050000000005000000000500000000050683797c0536fb99b70500005000020b000000000500000003050000000005000000000500000000050683797f0536fb99b70500005000020ba9d57e
7ea88c0300228a7fccf85e00000000050000000305000000000500000000050000000005068379820536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379850536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379880536fb99b70500005000020b000000000597167e
7ea88c0300228a7fceea7d00000003050000000005000000000500000000050683798c0536fb99b70500005000020b000000000500000003050000000005000000000500000000050683798f0536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379920536fb99b70500005000020b000000000500000003059ecb7e
7ea88c0300228a7fc09494000000000500000000050000000005068379950536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379980536fb99b70500005000020b000000000500000003050000000005000000000500000000050683799b0536fb99b70500005000020b000000000500000003050000000005ce177e
7ea88c0300228a7fd207a7000000000500000000050683799e0536fb99b70500005000020b00000000050000000405000000000500000000050000000005068379a10536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379a40536fb99b70500005000020b0000000005000000030500000000050000000005a49c7e
7ea00a00228a7f035194337e
7ea88c0300228a7fc4b0d20000000005068379a70536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379ab0536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379ae0536fb99b70500005000020b0000000005000000030500000000050000000005000000000529267e
7ea88c0300228a7fc6a2f1068379b10536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379b40536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379b70536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379ba055b4c7e
7ea88c0300228a7fc8dc1836fb99b70500005000020b00000000050000000305000000000500000000050000000005068379bd0536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379c00536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379c30536fb99b70533287e
7ea88c0300228a7fcace3b00005000020b00000000050000000305000000000500000000050000000005068379c60536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379c90536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379cc0536fb99b705000050000266507e
7ea88c0300228a7fccf85e0b00000000050000000305000000000500000000050000000005068379cf0536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379d20536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379d50536fb99b70500005000020b00000000ed527e
7ea88c0300228a7fceea7d050000000305000000000500000000050000000005068379d80536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379db0536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379de0536fb99b70500005000020b000000000500000003aef57e
7ea88c0300228a7fd0158405000000000500000000050000000005068379e10536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379e40536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379e70536fb99b70500005000020b0000000005000000030500000000e9a57e
7ea00a00228a7f033192507e
7ea88c0300228a7fc286b70500000000050000000005068379ea0536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379ed0536fb99b70500005000020b00000000050000000405000000000500000000050000000005068379f00536fb99b70500005000020b000000000500000003050000000005000000001f657e
7ea88c0300228a7fc4b0d2050000000005068379f30536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379f70536fb99b70500005000020b00000000050000000305000000000500000000050000000005068379fa0536fb99b70500005000020b000000000500000003050000000005000000000500000000e1337e
7ea88c0300228a7fc6a2f105068379fd0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a000536fb99b70500005000020b0000000005000000040500000000050000000005000000000506837a030536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a061cd77e
7ea88c0300228a7fc8dc180536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a090536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a0d0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a100536fb99b751ae7e
7ea0110300228a7fda681b0500005000d3797e
7ea01600228a7f03dc2a68e6e600c0028100000001737f7e
7ea88c0300228a7fecfa7fe6e700c40281000000000200820f72020b0202090c07e60206ffffffffff8000ff04060000000005000000030500000000050000000005000000000506837a130536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a160536fb99b70500005000020b000000000500000003050056757e
7ea88c0300228a7feee85c000000050000000005000000000506837a190536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a1c0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a1f0536fb99b70500005000020b000000000500000003050000000005000da47e
7ea88c0300228a7ff017a500000005000000000506837a220536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a250536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a280536fb99b70500005000020b0000000005000000040500000000050000000005002caf7e
7ea88c0300228a7fe284960000000506837a2b0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a2e0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a310536fb99b70500005000020b000000000500000003050000000005000000000500000000050696117e
7ea88c0300228a7fe4b2f3837a350536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a380536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a3b0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a3e0536a8857e
7ea88c0300228a7fe6a0d0fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a410536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a440536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a470536fb99b70500abd57e
7ea88c0300228a7fe8de39005000020b0000000005000000040500000000050000000005000000000506837a4a0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a4d0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a510536fb99b70500005000020b7a4c7e
7ea88c0300228a7feacc1a0000000005000000030500000000050000000005000000000506837a540536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a570536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a5a0536fb99b70500005000020b0000000005c6987e
7ea88c0300228a7fecfa7f000000030500000000050000000005000000000506837a5d0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a600536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a630536fb99b70500005000020b000000000500000003050bef7e
7ea88c0300228a7ffe694c00000000050000000005000000000506837a660536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a690536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a6c0536fb99b70500005000020b00000000050000000305000000000521737e
7ea00a00228a7f031190717e
7ea88c0300228a7fe096b50000000005000000000506837a6f0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a720536fb99b70500005000020b0000000005000000040500000000050000000005000000000506837a750536fb99b70500005000020b000000000500000003050000000005000000000514bf7e
7ea88c0300228a7fe28496000000000506837a780536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a7b0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a7f0536fb99b70500005000020b00000000050000000305000000000500000000050000000005905a7e
7ea88c0300228a7fe4b2f306837a820536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a850536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a880536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a8b0556d17e
7ea88c0300228a7fe6a0d036fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a8e0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a910536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a940536fb99b7057c107e
7ea88c0300228a7fe8de3900005000020b0000000005000000030500000000050000000005000000000506837a970536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a9a0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837a9d0536fb99b70500005000029fb77e
7ea88c0300228a7feacc1a0b0000000005000000030500000000050000000005000000000506837aa00536fb99b70500005000020b0000000005000000040500000000050000000005000000000506837aa30536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837aa60536fb99b70500005000020b00000000ba777e
7ea88c0300228a7ffc7b6f05000000030500000000050000000005000000000506837aa90536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837aac0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837aaf0536fb99b70500005000020b00000000050000000330c77e
7ea00a00228a7f03f19e967e
7ea88c0300228a7feee85c0500000000050000000005000000000506837ab20536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ab60536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ab90536fb99b70500005000020b00000000050000000305000000007f557e
7ea88c0300228a7fe096b5050000000005000000000506837abc0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837abf0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ac20536fb99b70500005000020b0000000005000000030500000000050000000072217e
7ea88c0300228a7fe2849605000000000506837ac50536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ac80536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837acb0536fb99b70500005000020b000000000500000003050000000005000000000500000000cc617e
7ea88c0300228a7fe4b2f30506837ace0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ad10536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ad40536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ad7724d7e
7ea88c0300228a7fe6a0d00536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ada0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837add0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ae00536fb99b710497e
7ea88c0300228a7fe8de390500005000020b0000000005000000030500000000050000000005000000000506837ae30536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ae60536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ae90536fb99b705000050002ad07e
7ea88c0300228a7ffa4d0a020b0000000005000000030500000000050000000005000000000506837aec0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837aef0536fb99b70500005000020b0000000005000000040500000000050000000005000000000506837af20536fb99b70500005000020b000000d0487e
7ea00a00228a7f03d19cb77e
7ea88c0300228a7fecfa7f0005000000030500000000050000000005000000000506837af50536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837af80536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837afb0536fb99b70500005000020b00000000050000008f9c7e
7ea88c0300228a7feee85c030500000000050000000005000000000506837afe0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b010536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b050536fb99b70500005000020b00000000050000000305000000b25d7e
7ea88c0300228a7fe096b500050000000005000000000506837b080536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b0b0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b0e0536fb99b70500005000020b000000000500000003050000000005000000d5067e
7ea88c0300228a7fe284960005000000000506837b110536fb99b70500005000020b0000000005000000040500000000050000000005000000000506837b140536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b170536fb99b70500005000020b0000000005000000030500000000050000000005000000b8197e
7ea88c0300228a7fe4b2f3000506837b1b0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b1e0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b210536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b3f4a7e
7ea88c0300228a7fe6a0d0240536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b270536fb99b70500005000020b0000000005000000040500000000050000000005000000000506837b2a0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b2d0536fb990e367e
7ea88c0300228a7ff85f29b70500005000020b0000000005000000030500000000050000000005000000000506837b300536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b330536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b370536fb99b705000050a9107e
7ea00a00228a7f03b19ad47e
7ea00d0300228a7ffa393e00ccc67e
7ea01600228a7f03de384be6e600c0028100000002e84d7e
7ea88c0300228a7f0cf498e6e700c40281000000000300820f72020b0202090c07e60207ffffffffff8000ff04060000000005000000030500000000050000000005000000000506837b3a0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b3d0536fb99b70500005000020b000000000500000003050034467e
7ea88c0300228a7f0ee6bb000000050000000005000000000506837b400536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b430536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b460536fb99b70500005000020b00000000050000000305000000000500f28e7e
7ea88c0300228a7f00985200000005000000000506837b490536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b4c0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b4f0536fb99b70500005000020b000000000500000003050000000005000000000500dc507e
7ea88c0300228a7f028a710000000506837b520536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b550536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b580536fb99b70500005000020b0000000005000000030500000000050000000005000000000506133d7e
7ea88c0300228a7f04bc14837b5b0536fb99b70500005000020b0000000005000000040500000000050000000005000000000506837b5e0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b610536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b650536f2997e
7ea88c0300228a7f06ae37fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b680536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b6b0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b6e0536fb99b705004c257e
7ea88c0300228a7f1851ce005000020b0000000005000000030500000000050000000005000000000506837b710536fb99b70500005000020b0000000005000000040500000000050000000005000000000506837b740536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b770536fb99b70500005000020be1617e
7ea88c0300228a7f0ac2fd0000000005000000030500000000050000000005000000000506837b7b0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b7e0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b810536fb99b70500005000020b00000000055bfe7e
7ea88c0300228a7f0cf498000000030500000000050000000005000000000506837b840536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b870536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b8a0536fb99b70500005000020b0000000005000000030500b67e
7ea88c0300228a7f0ee6bb00000000050000000005000000000506837b8d0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b900536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837b930536fb99b70500005000020b0000000005000000010500000000050af47e
7ea88c0300228a7f0098520000000005000000000506837b940536fb99b70500005000020b0000000005000000020500000000050000000005000000000506837b960536fb99b70500005000020b0000000005000000040500000000050000000005000000000506837b990536fb99b70500005000020b0000000005000000020500000000050000000005f9b47e
7ea88c0300228a7f028a71000000000506837b9c0536fb99b70500005000020b0000000005000000040500000000050000000005000000000506837b9f0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ba20536fb99b70500005000020b00000000050000000305000000000500000000050000000005d0317e
7ea88c0300228a7f04bc1406837ba60536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ba90536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837bac0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837baf0554d47e
7ea88c0300228a7f162f2736fb99b70500005000020b0000000005000000030500000000050000000005000000000506837bb20536fb99b70500005000020b0000000005000000040500000000050000000005000000000506837bb50536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837bb80536fb99b705f5bf7e
7ea88c0300228a7f08d0de00005000020b0000000005000000030500000000050000000005000000000506837bbc0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837bbf0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837bc20536fb99b70500005000027fe57e
7ea88c0300228a7f0ac2fd0b0000000005000000030500000000050000000005000000000506837bc50536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837bc80536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837bcb0536fb99b70500005000020b00000000aa027e
7ea88c0300228a7f0cf49805000000030500000000050000000005000000000506837bce0536fb99b70500005000020b0000000005000000040500000000050000000005000000000506837bd10536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837bd40536fb99b70500005000020b000000000500000003948c7e
7ea88c0300228a7f0ee6bb0500000000050000000005000000000506837bd80536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837bdb0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837bde0536fb99b70500005000020b0000000005000000030500000000dd7b7e
7ea88c0300228a7f009852050000000005000000000506837be10536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837be40536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837be70536fb99b70500005000020b0000000005000000030500000000050000000084c07e
7ea88c0300228a7f028a7105000000000506837bea0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837bed0536fb99b70500005000020b0000000005000000040500000000050000000005000000000506837bf00536fb99b70500005000020b000000000500000003050000000005000000000500000000b19f7e
7ea88c0300228a7f143d040506837bf30536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837bf60536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837bfa0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837bfd5fb27e
7ea88c0300228a7f06ae370536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c000536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c030536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c060536fb99b75bb37e
7ea88c0300228a7f08d0de0500005000020b0000000005000000030500000000050000000005000000000506837c090536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c0c0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c0f0536fb99b7050000500073d77e
7ea88c0300228a7f0ac2fd020b0000000005000000030500000000050000000005000000000506837c120536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c150536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c180536fb99b70500005000020b00000048a57e
7ea88c0300228a7f0cf4980005000000030500000000050000000005000000000506837c1b0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c1e0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c210536fb99b70500005000020b00000000050000006d7b7e
7ea88c0300228a7f0ee6bb040500000000050000000005000000000506837c240536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c270536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c2b0536fb99b70500005000020b00000000050000000305000000fe797e
7ea88c0300228a7f00985200050000000005000000000506837c2e0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c310536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c340536fb99b70500005000020b00000000050000000405000000000500000043f27e
7ea88c0300228a7f120b610005000000000506837c370536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c3a0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c3e0536fb99b70500005000020b0000000005000000030500000000050000000005000000ad4b7e
7ea88c0300228a7f04bc14000506837c410536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c440536fb99b70500005000020b0000000005000000040500000000050000000005000000000506837c470536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c30aa7e
7ea88c0300228a7f06ae374b0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c4e0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c510536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c540536fb9931267e
7ea88c0300228a7f08d0deb70500005000020b0000000005000000030500000000050000000005000000000506837c570536fb99b70500005000020b0000000005000000040500000000050000000005000000000506837c5a0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c5d0536fb99b70500005076ea7e
7ea00d0300228a7f1a37d900ccc67e
7ea01600228a7f03d046a2e6e600c0028100000003615c7e
7ea88c0300228a7f2cf6b9e6e700c40281010000000400820a29020b0202090c07e60208ffffffffff8000ff04060000000005000000030500000000050000000005000000000506837c610536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c640536fb99b70500005000020b0000000005000000030500197f7e
7ea88c0300228a7f2ee49a000000050000000005000000000506837c670536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c6a0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c6d0536fb99b70500005000020b0000000005000000030500000000050086607e
7ea88c0300228a7f209a7300000005000000000506837c700536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c730536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c760536fb99b70500005000020b0000000005000000040500000000050000000005004af97e
7ea88c0300228a7f3209400000000506837c790536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c7c0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c800536fb99b70500005000020b00000000050000000305000000000500000000050000000005069d157e
7ea88c0300228a7f24be35837c830536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c860536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c890536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c8c0536a8bd7e
7ea88c0300228a7f26ac16fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c8f0536fb99b70500005000020b0000000005000000040500000000050000000005000000000506837c920536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c950536fb99b705000f7c7e
7ea88c0300228a7f28d2ff005000020b0000000005000000030500000000050000000005000000000506837c990536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c9c0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837c9f0536fb99b70500005000020baa547e
7ea88c0300228a7f2ac0dc0000000005000000030500000000050000000005000000000506837ca20536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ca50536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ca80536fb99b70500005000020b0000000005fc757e
7ea88c0300228a7f2cf6b9000000040500000000050000000005000000000506837cab0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837cae0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837cb10536fb99b70500005000020b00000000050000000305094b7e
7ea88c0300228a7f2ee49a00000000050000000005000000000506837cb50536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837cb80536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837cbb0536fb99b70500005000020b00000000050000000405000000000505f77e
7ea88c0300228a7f301b630000000005000000000506837cbe0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837cc10536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837cc40536fb99b70500005000020b0000000005000000030500000000050000000005970f7e
7ea88c0300228a7f228850000000000506837cc80536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ccb0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837cce0536fb99b70500005000020b0000000005000000030500000000050000000005000000000597e37e
7ea88c0300228a7f24be3506837cd10536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837cd40536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837cd70536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837cda0568467e
7ea88c0300228a7f26ac1636fb99b70500005000020b0000000005000000040500000000050000000005000000000506837cdd0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ce00536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ce30536fb99b7058e977e
7ea88c0300228a7f28d2ff00005000020b0000000005000000030500000000050000000005000000000506837ce60536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837cea0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837ced0536fb99b7050000500002dfcd7e
7ea88c0300228a7f2ac0dc0b0000000005000000030500000000050000000005000000000506837cf00536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837cf30536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837cf60536fb99b70500005000020b0000000080627e
7ea88c0300228a7f2cf6b905000000030500000000050000000005000000000506837cf90536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837cfc0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837cff0536fb99b70500005000020b00000000050000000395df7e
7ea88c0300228a7f3e658a0500000000050000000005000000000506837d020536fb99b70500005000020b0000000005000000040500000000050000000005000000000506837d050536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837d080536fb99b70500005000020b000000000500000003050000000098667e
7ea88c0300228a7f209a73050000000005000000000506837d0b0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837d0e0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837d110536fb99b70500005000020b0000000005000000030500000000050000000060db7e
7ea88c0300228a7f22885005000000000506837d140536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837d180536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837d1b0536fb99b70500005000020b00000000050000000305000000000500000000050000000043517e
7ea0440300228a7f3474970506837d1e0536fb99b70500005000020b0000000005000000030500000000050000000005000000000506837d210536fb99b70500005000a3567e
7ea01c00228a7f037209cde6e600c0018100010000880101ff02007cd27e
7ea0200300228a7f56931ce6e700c4018100020512000f110111011100030027667e
7ea00a0300228a7f51f8e27e
7ea00a00228a7f035386107e
7ea00a0300228a7f73e8e07e
7ea00a00028a7f033103307e
7ea00a0300028a7f31ad0e7e
is there any progress in this
is there any progress in this matter ?
for hint, if you use GXDLMSDirector to read sl7000 or ace6000 meters with attach setting,
you will receive "invalid frame type" or "unable to cast object type system.int32 to type system.collection.generic.ienumerable`1[system.object]" errors in this meters respectively.
Those errors are coming because the content of the data is not valid.
When client reads 0.0.99.129.1.255 the meter reply this.
7E A8 8C 03 00 22 8A...
This is correct and the client waits for the next reply from the meter. The next reply is this that tells that all the frames are received:
7E A0 15 03 00 22 8A 7F 76 78 1B 08 FF 0F 2D 00 FF 80 00 00 42 E2 7E
Next your client ask next frame and this is wrong because all the frames are already received. Window size is 7 so meter should send all the frames and not stop after sending two frames.
7E A0 0A 00 22 8A 7F 03 91 98 F5 7E
This meter is working differently than the standard says and I propose that you use Windows size 1 to read the meter.
Hi, thank you for your reply.
But I think there is a missing part in your code. When we use meter own software to read it, it's send A8 after 7th packet and correctly does it.
But when we use gurux, this happens
I added meter own software packets also.
