  3. Service Not Allowed. Ciphering Failed
Service not allowed. Ciphering failed
By hridendra27 , 7 December, 2021
Hi I am able to read two days before from this.
But when I try to read today found the following error kindly help.
java -jar gurux.dlms.client.example.java-0.0.1-SNAPSHOT.jar -h XXXXX -p 4059 -i WRAPPER -c 48 -a High -P XXXX -C AuthenticationEncryption -T XXX -A XXXX -B XXXXXX -v 0.0.43.1.3.255 -d India -t Verbose
Connect using network connection gurux.net.GXNet@3af49f1c
Authentication: High
ClientAddress: 0x30
Standard: INDIA
Security: AUTHENTICATION_ENCRYPTION
System title: 49 48 4D 31 32 33 34 35
Authentication key: 31 32 33 34 35 36 37 38 31 32 33 34 35 36 37 38
Block cipher key 31 32 33 34 35 36 37 38 31 32 33 34 35 36 37 38
TX: 11:57:45.131 00 01 00 10 00 01 00 1F 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 42 1E 5D FF FF
RX: 11:57:47.249 00 01 00 01 00 10 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 01 F4 00 07
TX: 11:57:47.252 00 01 00 10 00 01 00 0D C0 01 C1 00 01 00 00 2B 01 03 FF 02 00
RX: 11:57:47.967 00 01 00 01 00 10 00 09 C4 01 81 00 06 00 00 00 09
Invocation counter: 10
TX: 11:57:47.971 00 01 00 10 00 01 00 05 62 03 80 01 00
RX: 11:57:48.691 00 01 00 01 00 10 00 17 63 15 80 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 01 F4 00 07
TX: 11:57:49.420 00 01 00 30 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 49 48 4D 31 32 33 34 35 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 18 4C 6F 05 18 37 6F 1F 0D 4F 74 6D 74 17 35 3A BE 23 04 21 21 1F 30 00 00 00 0A 3C 48 71 57 35 7D 6A 51 0C 7D BF F6 49 15 DA 9C A9 10 7D FC AA 86 A5 B4 70 52
RX: 11:57:50.050 00 01 00 01 00 30 00 03 D8 01 05
4 years 9 months ago
You have selected only Get-service. I believe it's the cause for this. You need to add at least the Action service. It might be that your meter wants also the General protection -service.
