  3. Change Host Name, Port and DLMS Settings
Change Host name, port and DLMS settings
By meru , 24 November, 2021
Hello Marco,
I'm running gurux.dlms.c on linux but i dont know on which file i should make modifications to change Host name, Port and DLMS settings. Can you please advice?
Thanks in advance
4 years 8 months ago
Add command line parameters
-h YOUR_HOSN_NAME -p YOUR_METER_PORN_NUMBER
meru
Here's the out put of the
Here's the out put of the command:
~/GuruxDLMS.c-master/GuruxDLMSClientExample/bin$ sudo ./gurux.dlms.client.bin -h 192.168.1.17 -p 4062 -c 16 -s 1 -r SN
Connecting to 192.168.1.17:4062
InitializeConnection
SNRMRequest failed Data receive failed.
I dont know what's wrong
Hi Meru,
Hi Meru,
I believe that one of your settings is wrong and the meter doesn't reply because of that.
What meter do you try to read?
Try to connect with GXDLMSDirector. After you can establish the connection select the meter and you can see the correct command line parameters.
meru
I"m using Gurux serverexample on windows pc . I tried another command and here is the result:
sudo ./gurux.dlms.client.bin -h 192.168.1.17 -s 1 -p 4060 -r SN -c 16
Connecting to 192.168.1.17:4060
GetAssociationView
-------- Reading Object AssociationShortName 0.0.40.0.0.255
ReadObject failed AssociationShortName 0.0.40.0.0.255:2 Invalid response
munmap_chunk(): invalid pointer
Aborted
You are right. I was able to make the same error. Everything seems to work with Logical Name referencing, but Short Name referencing is causing an exception in Linux. This seems to work in Windows. I'll let you know as soon as I have more info.
Thank you for pointing this out. This is now fixed. Get the latest version from GitHub.
  • CorwXGlcWwyuiJawypxb
  • Vegazone-Casin…
  • VegaZone-lBit
  • Vegazone-Sverige-Fug
  • UIRlLOZQoyTZHC…
