  3. ISKRA ME382 and Kamstrup DK - 8660 Communication With DLMS
ISKRA ME382 and Kamstrup DK - 8660 communication with DLMS
By gokhantaysi , 14 October, 2021
I have ISKRA ME382 and Kamstrup DK - 8660 smart meter and it has a internal gsm module. GSM module has static IP sim card.
I want communication this smart meter with DLMS.
How we can do it???
Thanks.
4 years 11 months ago
You should download GXDLMSDirecrtor and try to connect with that. ISKRA ME382 should be easy if you know TCP/IP address and port number.
Select Iskra and change the interface to WRAPPER.
You can also read Kamstrup, but there might be a few settings that you need to change.
Try to read them with GXDLMSDirector first.
gokhantaysi
I know IP address. Port number should be 4059, isn't it?
What other settings should I do?
The port number can be anything. You need to connect with the optical probe or serial port to verify it if it's not a meter manual.
Set the host name (IP address) and give it a try.
