  3. Javascript
Javascript
By jcf , 13 October, 2021
Hi all,
I'm investigating your solution for reading data from the meters in Portugal. The software we will use to read data from the meters only support javascript library. Do you have any libraries that we can use in our software ?
Thanks in advance,
Joana
4 years 11 months ago
I believe that the best way to handle this is if you create a server that handles the reading part and you call this server from the javascript with REST. The server can be made with python or java.
jcf
Sounds good! We can use a server script with your solution and call it using JS. We can try it and give feedback later.
Thanks again,
Joana
  • lh
