  3. Daisy Chaining Over IEC
Daisy chaining over IEC
By James_21 , 22 August, 2021
is it possible to read energy meters through a transparent gateway over IEC protocol?
if yes , may i know the steps.
regards,
James
5 years ago
Hi James,
Hi James,
You can read meters with daisy chain using DLMS, but not with IEC. IEC is a simple protocol and there is no meter information the frame that is needed to read values using daisy chain
James_21
4 years 11 months ago
HI Kurumi,
HI Kurumi,
thank you for response.
is it possible to connect a single meter (not daisy chain) with transparent GW over RS485 interface with IEC protocol and perform time sync operation/or set desired time and date
regards,
It should be possible. You can't change the baud rate during the initialization because GW usually can't handle it.
James_21
i am surprised and thankful
i am surprised and thankful for swift responses.
baud rate during initialization; Does it mean starting baud rate 300 to default baud rate 9600?
Im sorry didnt get this... baud rate on Device as per IEC protocol must be;
300 or 9600..
Parity: Even or Odd
Data Bit: 7 or 8
regards
James
Hi James,
Hi James,
It is a configurable parameter. :-)
When you communicate with an optical probe it's usually 300, but if you are operating with a serial port (RS-232 or RS-485), it can be anything. It's usually 9600.
Common optical probe default settings are: 300 7E1
Common serial port settings are 9600 8None1.
James_21
Hi Kurumi,
Hi Kurumi,
May u share me ISKRA MT372 meter RS485 setting for IEC protocol,so i can test it with transparent GW.
regards,
James
Hi James,
Hi James,
There are a lot of changes between IEC meters. You should check this. It's for Elster meters, but you can
try to read your meter in Mode A (readout mode) if you send "/?!\r\n"
https://www.gurux.fi/node/5415
