  3. Segmentation With Action Request
Segmentation with Action request
By aoudumbarpawar , 4 October, 2021
Hii,
I want to import the certificate in meter with action with block transfer method but gurux always requested with segmentation i.e 0xA8 event if meter negotiate conformance with action with block transfer.
Tx/Rx buffere size negotiated : 150 bytes
Negotiated conformance : GeneralBlockTransfer, BlockTransferWithGetOrRead, BlockTransferWithSetOrWrite, BlockTransferWithAction, DataNotification, Get, Set, SelectiveAccess, Action
My queries are:
1. How to do setting by which gurux will initiated action with block transfer?
2. can please provide Examples of segmentation request/response frames one for each i.e get,set,action
Best Regars,
Aoudumbar Pawar
5 years 1 month ago
THis should work but I can test this. What are your PDU sizes and HDLC frame sizes?
aoudumbarpawar
5 years 1 month ago
Hii,
Hii,
PDU Suze : 116 bytes
HDLC Frame size : 150bytes
Frame : 7E A8 94 00 02 BA 69 61 54 BA D5 E6 E6 00 C3 01 C1 00 40 00 00 2B 00 01 FF 06 01 09 82 01 E6 30 82 01 E2 30 82 01 89 A0 03 02 01 02 02 03 0F 48 5A 30 0A 06 08 2A 86 48 CE 3D 04 03 02 30 4E 31 14 30 12 06 03 55 04 03 0C 0B 52 6F 6F 74 20 43 41 20 32 35 36 31 17 30 15 06 03 55 04 0A 0C 0E 47 75 72 75 78 20 53 65 63 75 72 69 74 79 31 10 30 0E 06 03 55 04 07 0C 07 54 61 6D 70 65 72 65 31 0B 30 09 06 03 55 04 06 13 02 46 49 30 1E 17 0D 32 31 94 AE 7E
AP
5 years ago
This is checked and it works without problems. Make sure that GeneralBlockTransfer is enabled on the client and the server-side. You can see Negotiated conformance if you select the meter and establish the connection to the meter. If GeneralBlockTransfer is not Negotiated, it's not used.
aoudumbarpawar
5 years ago
Hii,
Hii,
Good Morning!!!
GeneralBlock transfer is enabled on both sides, even if gurux requested with segmentation frame type for import certificate method with buffer size 150.
Following are the proposed and negotiated conformance:
Proposed:
GeneralProtection, GeneralBlockTransfer, BlockTransferWithGetOrRead, BlockTransferWithSetOrWrite, BlockTransferWithAction, MultipleReferences, Access, Get, Set, SelectiveAccess, Action
Negotiated:
AP
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
