  3. Generate Push Data Payload
By Bhaumik , 30 September, 2021
I have a push data decrypted payload as below:
0F D0 00 35 26 0C 07 E5 09 1D 03 10 1D 2C FF 01 4A 00 02 0D 0A 0C AA BB CC DD 30 30 30 30 30 31 34 31 09 06 00 00 19 09 00 FF 09 0C 07 E5 09 1D 03 10 1D 2C FF 01 4A 00 17 43 66 00 00 17 00 00 00 00 17 41 F0 00 00 17 00 00 00 00 17 00 00 00 00 12 00 E1 06 00 00 00 0D 17 00 00 00 00 03 01 06 00
00 43 80
I want to generate a full wrapper frame using this payload for push data with the system title.
Can you please help me to generate the same.
5 years 1 month ago
Gurux DLMS libraries do this automatically for you.
Bhaumik
5 years 1 month ago
Yes, But I want to do a load test by sending multiple meter's push data on the listener.
So for that, I required a dummy payload with a system title.
I have generated one payload, but In that not able to set the system title. In Encrypted payload
system title comes after DB (General Glo ciphering) byte. How can I add it after data notification byte (0F)
Can you please suggest?
00 01 00 01 00 40 00 65 0F D0 00 35 26 0C 07 E5 09 1D 03 10 1D 2C FF 01 4A 00 02 0D 0A 0C AA BB CC DD 30 30 30 30 30 31 34 31 09 06 00 00 19 09 00 FF 09 0C 07 E5 09 1D 03 10 1D 2C FF 01 4A 00 17 43 66 00 00 17 00 00 00 00 17 41 F0 00 00 17 00 00 00 00 17 00 00 00 00 12 00 E1 06 00 00 00 0D 17 00 00 00 00 03 01 06 00 00 43 80
<WRAPPER len="6D" >
<TargetAddress Value="1" />
<SourceAddress Value="40" />
<PDU>
<DataNotification>
<!-- High priority. -->
<!-- Confirmed service. -->
<!-- Invoke ID: 268449062 -->
<LongInvokeIdAndPriority Value="D0003526" />
<!-- 30-09-2021 03:29:44 -->
<DateTime Value="07E5091D03101D2CFF014A00" />
<NotificationBody>
<DataValue>
<Structure Qty="0D" >
<String Value="AA BB CC DD 30 30 30 30 30 31 34 31" />
<!-- 0.0.25.9.0.255 -->
<OctetString Value="0000190900FF" />
<!-- 29-09-2021 16:29:44-05:30 -->
<OctetString Value="07E5091D03101D2CFF014A00" />
<!-- 230 -->
<Float32 Value="43660000" />
<!-- 0 -->
<Float32 Value="00000000" />
<!-- 30 -->
<Float32 Value="41F00000" />
<!-- 0 -->
<!-- 0 -->
<UInt16 Value="00E1" />
<UInt32 Value="0000000D" />
<!-- 0 -->
<Boolean Value="true" />
<UInt32 Value="00004380" />
</Structure>
</DataValue>
</NotificationBody>
</DataNotification>
</PDU>
</WRAPPER>
5 years 1 month ago
You need to set Security so data is ciphered. Now you are sending normal push messages without encryption.
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
