  3. Multi Objects Reading From Itron SL7000 With BlockTransferWithGetOrRead?
Multi objects reading from Itron SL7000 with BlockTransferWithGetOrRead?
By kepurlaukis , 27 August, 2021
Is it possible to read multi objects from Itron meter?
Meter conformance supports BlockTransferWithGetOrRead
<AssociationResponse>
<AssociationResult Value="00" />
<ResultSourceDiagnostic>
<ACSEServiceUser Value="00" />
</ResultSourceDiagnostic>
<MechanismName Value="LOW_SECURITY" />
<RespondingAuthenticationValue Value="\ABCDEFGH" />
<InitiateResponse>
<NegotiatedConformance>
<ConformanceBit Name="Set" />
<ConformanceBit Name="Get" />
<ConformanceBit Name="Attribute0SupportedWithGet" />
</NegotiatedConformance>
<NegotiatedMaxPduSize Value="2134" />
<VaaName Value="0007" />
</InitiateResponse>
</AssociationResponse>
How to set up DLMS director to read many objects in one request?
Or it's not possible. According to PDU syntax from https://cyamon.com/Syntax/pdu_syntax.html
only _SetRequest has _SetRequestWithDataBlock,
but _GetRequest do not have something like _GetRequestWithDataBlock
very very strange... maybe I'm missing something?
5 years ago
I don't know if "Multiple references" is set for the client-side, but it's not set for the negotiated conformance. This means that you can read only one value at the time.
https://www.gurux.fi/Gurux.DLMS.Conformance#MultipleReferences
Check that "Access" and "Multiple references" are checked on the "Supported Services" tab.
