  3. Finding Problem In Installing GuruxDLMSDirector
Finding Problem in installing GuruxDLMSDirector
By pandere.nisha1… , 1 June, 2021
I wanted to install GuruxDLMSDirector on my Laptop. I have already installed .NET 6.1, still while installing Gurux I am getting the error
"Application can not be started. Contact the application vendor"
I am attaching an error screenshot for your reference.
5 years ago
We'll install the .NET 6.1 and try to repeat this problem. I'll let you know more as soon as I have more info on this.
5 years ago
This can't be repeated and because .Net 6.0 is a preview state try to Install .Net 5.0.
pandere.nisha1…
5 years ago
Thank you for the reply. I will install the .Net 5.0 and let you is the issue is resolved or not.
pandere.nisha1…
5 years ago
I have tried installing .Net 5.0 and .Net 4.6
but still getting the same problem.
5 years ago
What Windows version you are using and what the language settings?
pandere.nisha1…
5 years ago
Windows 7 professional
language setting: English
5 years ago
There is a new version. Let me know if you have still any problems.
pandere.nisha1…
5 years ago
Are you talking about this application version?
Download Gurux DLMS Director for .Net 4.6.
Version: 8.2.2103.2201
Released: 02/22/2021
I am not finding any difference in this "Application can not be started. Contact the application vendor" problem remains constant.
As the released date is not updated, am I downloading the correct application version or not?
5 years ago
That is the correct version. Can you run this:
dotnet --version
What is the result that you get? Mine is: 5.0.203
pandere.nisha1…
5 years ago
Hi Sir,
Hi Sir,
As suggested by you I installed the "Microsoft.NETSDK5.0.203(x86)"
But still, I am getting the same error, and these are the details of the error.
PLATFORM VERSION INFO
Windows : 6.1.7601.65536 (Win32NT)
Common Language Runtime : 4.0.30319.42000
System.Deployment.dll : 4.8.3761.0 built by: NET48REL1
clr.dll : 4.8.4110.0 built by: NET48REL1LAST_B
dfdll.dll : 4.8.3761.0 built by: NET48REL1
dfshim.dll : 4.0.41209.0 (Main.041209-0000)
SOURCES
Deployment url : file:///E:/Nisha/Meter%20Software/documents/DLMS/softwares/GXDLMSDirector.application
Deployment Provider url : http://www.gurux.fi/Downloads/gxdlmsdirector46/GXDLMSDirector.applicati…
Server : nginx
Application url : http://www.gurux.fi/Downloads/gxdlmsdirector46/Application%20Files/GXDL…
Server : nginx
IDENTITIES
Deployment Identity : GXDLMSDirector.application, Version=8.2.2106.701, Culture=neutral, PublicKeyToken=fac3cc4fecb816b3, processorArchitecture=msil
Application Identity : GXDLMSDirector.exe, Version=8.2.2106.701, Culture=neutral, PublicKeyToken=fac3cc4fecb816b3, processorArchitecture=msil, type=win32
APPLICATION SUMMARY
* Installable application.
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
* Activation of E:\Nisha\Meter Software\documents\DLMS\softwares\GXDLMSDirector.application resulted in exception. Following failure messages were detected:
+ Culture is not supported.
Parameter name: name
la is an invalid culture identifier.
COMPONENT STORE TRANSACTION FAILURE SUMMARY
No transaction error was detected.
WARNINGS
There were no warnings during this operation.
OPERATION PROGRESS STATUS
* [08-06-2021 18:22:44] : Activation of E:\Nisha\Meter Software\documents\DLMS\softwares\GXDLMSDirector.application has started.
* [08-06-2021 18:22:44] : Processing of deployment manifest has successfully completed.
* [08-06-2021 18:22:44] : Installation of the application has started.
* [08-06-2021 18:22:46] : Processing of application manifest has successfully completed.
* [08-06-2021 18:22:48] : Found compatible runtime version 4.0.30319.
* [08-06-2021 18:22:48] : Request of trust and detection of platform is complete.
ERROR DETAILS
Following errors were detected during this operation.
* [08-06-2021 18:22:55] System.Globalization.CultureNotFoundException
- Culture is not supported.
- Source: mscorlib
- Stack trace:
at System.Globalization.CultureInfo..ctor(String name, Boolean useUserOverride)
at System.Deployment.Application.AssemblyMetaDataImport.ConstructAssemblyName(IntPtr asmMetaPtr, Char[] asmNameBuf, UInt32 asmNameLength, IntPtr pubKeyPtr, UInt32 pubKeyBytes, UInt32 flags)
at System.Deployment.Application.AssemblyMetaDataImport.ImportIdentity()
at System.Deployment.Application.AssemblyMetaDataImport.get_Name()
at System.Deployment.Application.Manifest.AssemblyManifest.LoadFromCompLibAssembly(String filePath)
at System.Deployment.Application.Manifest.AssemblyManifest.LoadFromInternalManifestFile(String filePath)
at System.Deployment.Application.DownloadManager.ProcessDownloadedFile(Object sender, DownloadEventArgs e)
at System.Deployment.Application.FileDownloader.DownloadModifiedEventHandler.Invoke(Object sender, DownloadEventArgs e)
at System.Deployment.Application.FileDownloader.OnModified()
at System.Deployment.Application.SystemNetDownloader.DownloadSingleFile(DownloadQueueItem next)
at System.Deployment.Application.SystemNetDownloader.DownloadAllFiles()
at System.Deployment.Application.FileDownloader.Download(SubscriptionState subState, X509Certificate2 clientCertificate)
at System.Deployment.Application.DownloadManager.DownloadDependencies(SubscriptionState subState, AssemblyManifest deployManifest, AssemblyManifest appManifest, Uri sourceUriBase, String targetDirectory, String group, IDownloadNotification notification, DownloadOptions options)
at System.Deployment.Application.ApplicationActivator.DownloadApplication(SubscriptionState subState, ActivationDescription actDesc, Int64 transactionId, TempDirectory& downloadTemp)
at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl, Uri& deploymentUri)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivationWithRetry(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
5 years ago
Thank you for this info. This can be repeated and it's fixed. Tests will start and a new version is released next week.
pandere.nisha1…
5 years ago
Thank you. I will be waiting for the new version.
5 years ago
Next week came faster than expected. :-)
Get the latest version and let me know if you have problems.
pandere.nisha1…
4 years 12 months ago
The below mentioned is a new version?
Version: 8.2.2106.0701
Released: 06/07/2021
The released date and version number are different.
Still, I am getting the same error as the previous one while installing the software.
4 years 11 months ago
The version should be 8.2.2106.1501. Is the error the same?
pandere.nisha1…
When I download the software yesterday. The details of the software were as follows:
And it was not the same as suggested by you. And today I am unable to get the version number.
What is the error? Is it the same or something else?
pandere.nisha1…
the error is the same as the previous one.
Can you check ERROR SUMMARY and add it here?
pandere.nisha1…
Details of Error are as follows:
SOURCES
Deployment url : file:///C:/Users/DEVELOPER-3/Downloads/GXDLMSDirector%20(3).application
Server : nginx
Server : nginx
IDENTITIES
Deployment Identity : GXDLMSDirector.application, Version=8.2.2106.1501, Culture=neutral, PublicKeyToken=fac3cc4fecb816b3, processorArchitecture=msil
Application Identity : GXDLMSDirector.exe, Version=8.2.2106.1501, Culture=neutral, PublicKeyToken=fac3cc4fecb816b3, processorArchitecture=msil, type=win32
APPLICATION SUMMARY
ERROR SUMMARY
* Activation of C:\Users\DEVELOPER-3\Downloads\GXDLMSDirector (3).application resulted in exception. Following failure messages were detected:
yi is an invalid culture identifier.
WARNINGS
* [17-06-2021 16:06:50] : Activation of C:\Users\DEVELOPER-3\Downloads\GXDLMSDirector (3).application has started.
* [17-06-2021 16:06:50] : Processing of deployment manifest has successfully completed.
* [17-06-2021 16:06:50] : Installation of the application has started.
* [17-06-2021 16:06:52] : Processing of application manifest has successfully completed.
* [17-06-2021 16:06:57] : Found compatible runtime version 4.0.30319.
* [17-06-2021 16:06:57] : Request of trust and detection of platform is complete.
ERROR DETAILS
* [17-06-2021 16:07:09] System.Globalization.CultureNotFoundException
- Source: mscorlib
- Stack trace:
This is a different error. Your Windows doesn't support Yiddish and that is causing the problem.
Windows 7 support has ended so I believe that the easiest way is if this is removed from the next version of GXDLMSDirector.
pandere.nisha1…
Okay, Then should I upgrade my windows version?
Or else will have an option of GuruxDLMS to support this version of windows.
The fastest way is if you download the GXDLMSDirector and build it with Visual Studio. The next version is released next week.
