  3. Arduino Disconnect Control Failed
Arduino disconnect control failed
By elvandry13 , 15 June, 2021
hello,
I want to disconnect and reconnect electricity meter using Arduino client code. Here is my code snippet for disconnect control:
gxDisconnectControl dc;
dlmsVARIANT params;
cosem_init(BASE(dc), DLMS_OBJECT_TYPE_DISCONNECT_CONTROL, "0.0.96.3.10.255");
com_method(BASE(dc), 1, &params);
com_read(BASE(dc), 2);
obj_toString(BASE(dc), &data);
GXTRACE(PSTR("Disconnect : "), data);
obj_clear(BASE(dc));
free(data);
after flash the program, I got the error :
:com_method failed. 258
Is there anything I missed? How should I use the method?
Thank you...
5 years 3 months ago
Parameter value must be zero with data type Int8. Try with this:
dlmsVARIANT params;
var_init(&params);
var_setInt8(&params, 0);
elvandry13
thank you for the fast
thank you for the fast response.
I have updated the disconnect code with this :
dlmsVARIANT params;
var_init(&params);
free(data);
now I got this error :
:com_method failed. -2147483645
Stack smashing protect failure!
abort() was called at PC 0x4010562b on core 1
ELF file SHA256: 0000000000000000
Backtrace: 0x40086eac:0x3ffb1c30 0x40087129:0x3ffb1c50 0x4010562b:0x3ffb1c70 0x400d1699:0x3ffb1c90 0x400d1a9a:0x3ffb1cc0 0x400d1b49:0x3ffb1d60 0x400d1d26:0x3ffb1f90 0x400ec589:0x3ffb1fb0 0x4008813a:0x3ffb1fd0
Rebooting...
ets Jun 8 2016 00:22:57
I'm using ESP32 microcontroller and EDMI MK7MI meter.
I did try this with and it worked without problems. Do you have disconnect control with logical name 0.0.96.3.10.255? Can you disconnect it with GXDLMSDirector?
Stack protect failure is strange and that should not happen.
Can you get a list of bytes that you are transporting between the client and the meter?
Check the authentication level and that you have enough access rights for the meter.
elvandry13
okay, I will be back after I try disconnecting using GXDLMS Director
elvandry13
5 years 2 months ago
Finally I have tried disconnecting using GXDLMS Director and success! Previously, I used LOW authentication so I failed to disconnecting the meter. After I changed the authentication level to HIGH GMAC, I have succeeded to disconnecting the meter.
Next, I want to implement that to my arduino's firmware. Before that, how to implement the HIGH GMAC auth in client init? Where should I put the Block Cipher Key and Authentication Key in Arduino Client code?
Client example is updated to handle System title, block cipher key and authentication key. Get the latest version and set correct parameters in setup.
elvandry13
5 years 1 month ago
I have updated to the latest version and set the parameters in setup :
Client.init(true, 4, Client.GetServerAddress(1, 0x23, 1), DLMS_AUTHENTICATION_HIGH_GMAC, NULL, DLMS_INTERFACE_TYPE_HDLC);
//Un-comment this if you want to set system title, block cipher key or authentication key.
gxByteBuffer bb;
bb_Init(&bb);
bb_addHexString(&bb, "");
Client.SetSystemTitle(&bb);
bb_clear(&bb);
Client.SetAuthenticationKey(&bb);
bb_clear(&bb);
Client.SetBlockCipherKey(&bb);
bb_clear(&bb);
but I still get the same error :
:Start reading :com_initializeConnection failed -2147483645
abort() was called at PC 0x4010559b on core 1
Backtrace: 0x40086eac:0x3ffb1d00 0x40087129:0x3ffb1d20 0x4010559b:0x3ffb1d40 0x400d16f1:0x3ffb1d60 0x400d1b05:0x3ffb1d90 0x400d1d1e:0x3ffb1f90 0x400ec4f9:0x3ffb1fb0 0x4008813a:0x3ffb1fd0
Rebooting...
rst:0xc (SW_CPU_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5828
entry 0x400806a8
here I attached the screenshot of parameters I tested in GXDLMS Director
elvandry13
Sceenshot of device settings
elvandry13
Screenshot of secured
Screenshot of secured connection tab
Your authentication and block cipher keys are wrong. You try to give ASCII values and you should set hex values. Try with this:
bb_addHexString(&bb, "41 42 43 44 45 46 47 48");
bb_clear(&bb);
bb_addHexString(&bb, "46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46");
bb_clear(&bb);
elvandry13
5 years 1 month ago
I have edited my authentication and block cipher keys following your suggestion :
gxByteBuffer bb;
// bb_init(&bb);
bb_Init(&bb);
bb_clear(&bb);
bb_clear(&bb);
bb_clear(&bb);
Rebooting...
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400806a8
I was thinking maybe it was caused by the ESP32 board, so I tried using different board, I used Arduino Mega 2560. When I'm using the Arduino Mega 2560 board, I got different error :
:Start reading :com_initializeConnection failed 3
Additional notes :
- for ESP32, I changed bb_init(&bb); to bb_Init(&bb);
We can't repeat this. I have ordered an ESP32 board so we can check if this can be repeated with different HW. Let's wait a few days and get back to this after we have the ESP32 board.
elvandry13
May I know what HW do you use usually for testing Arduino client firmware? Maybe I will try in same environment.
There are a few different Arduino boards that are used to read the meters, but all tests are run with ATmega328.
elvandry13
I have tried using Arduino Uno and Arduino Nano (which use ATmega328) but it doesnt compile. I used Serial0 for flash and send trace / debugging, and Arduino Uno doesnt have Serial1 or Serial2 so I used software serial for communicate with meter. Here is the reference : https://www.arduino.cc/reference/en/language/functions/communication/se…
When I compile the program, I got this error :
/home/elvandry13/arduino-1.8.13/hardware/tools/avr/bin/../lib/gcc/avr/7.3.0/../../../../avr/bin/ld: /tmp/arduino_build_389754/modem-pln.ino.elf section `.text' will not fit in region `text'
/home/elvandry13/arduino-1.8.13/hardware/tools/avr/bin/../lib/gcc/avr/7.3.0/../../../../avr/bin/ld: region `text' overflowed by 32474 bytes
/tmp/ccbN18q9.ltrans0.ltrans.o: In function `GetTe':
/tmp/arduino_build_389754/sketch/src/ciphering.c:223: undefined reference to `pgm_read_dword_far'
/tmp/ccbN18q9.ltrans0.ltrans.o: In function `GetRcon':
/tmp/arduino_build_389754/sketch/src/ciphering.c:214: undefined reference to `pgm_read_dword_far'
collect2: error: ld returned 1 exit status
Using library SoftwareSerial at version 1.0 in folder: /home/elvandry13/arduino-1.8.13/hardware/arduino/avr/libraries/SoftwareSerial
exit status 1
Error compiling for board Arduino Uno.
Do you use custom HW which have ATmega328 and multiple hardware serial? And do you have try with ESP32?
hattareza
Hi Mr Mikko Kurunsaari
i have same problem about this, is there any suggestion related to programming languages or library and board. for example board like raspberry pi, 1SJ,arduino and programming language like java , c# ,c. if i try the code possible running well and establish ?
Thanks and Best Regards
Your error message says that you don't have enough memory on your board. You need a bigger flash to save this. DLMS is not an easy protocol.
elvandry13
I have tried with Arduino Uno, Nano and Pro Mini (with ATMega328) but didn't work, what board should I use? Do you have any recommendation? Do you have try with ESP32?
I have order ESP32 and we'll make an example for that after it arrives. You can use any bard that has enough memory.
elvandry13
Thank you very much
Thank you very much
5 years 1 month ago
In reply to Hi, by elvandry13
Can you add the send and received bytes as hex to here so I can try to check what is causing this?
elvandry13
5 years 1 month ago
This case solved after you fixed it in latest commit in github. Thanks a lot!
