  3. Connect To Sagem Meter With FLAG
Connect to sagem meter with FLAG
By sahbi said , 12 April, 2021
you find in attachement file all pdu changed log to connect with sagemcom
with FLAG (snipher wtih other limited app) .
i want to do the same work with GWDLMSDirecotr but we have not the same name
of parameteres :
for exemple:
sap_logical_addr_dest : 1
physical_addr_dest : 16
sap_logical_addr_src : 2
dlms_number_version : 6
dlms_conformance : 00381d
client_max_receive_pdu_size : 1024
acse_protocol_version : 1
application_context_name : 60857405080101
security_mecanism_name : 60857405080202
calling_authentification_value : f50ab847e31d96c2a5f6b3e901e24a18
service_class : TRUE
quality_of_service : 2
pre_established_association : FALSE
thanks a lot,
SAID Sahbi
5 years 5 months ago
Please, don't add images in the future. It's a pain to read the bytes. Add plain text.
Set parameters:
client address: 2
physical server: 0x10
Logical server: 1
Set also max payload size in transmit and receive to 1024 in "Frame" tab.
Set also challenge to f50ab847e31d96c2a5f6b3e901e24a18. This should be random number, but try first with the static value.
Thanks for your reply,
Where can i add this parameter in GXDLMSDirecor
You can give the challenge on the "Secured Connections" page.
i have error message when i say to connect to meter : "Manufacturer type does not match .Manufacturer is SAG and it should be SET"
i am sure that tha manufacturer is SAG.
this is XML Parameters Form:
You have selected SET as a manufacturer but the meter is from SAG.
Settings file for SAG is not there, but you can add a new meter settings file as described here:
https://www.gurux.fi/GXDLMSDirector.Manufacturers
or you can copy set.obx to sag.obx in C:\ProgramData\Gurux\OBIS
Then change the Identification tag (SET to SAG) and other parameters that are different.
If you send a working version from SEG settings to me by email we can release it and it will come automatically with GXDLMSDirector.
Exactly,I create a new manufacturer like SagemCom with SAG FLAG_ID and i can to succed in Association LogicalName and Data Field.
Next Step :i cant associate with meter (i dont have many ideas to use GXDLMSDirectory)
Rq: Differents parameters to set
how can i decode and insert in GXDLMSDirectory
Try with those settings:
Physical Server: 1
Client address: 1
Authntication: Low
Challence should be dynamic, but you can try to use this is connection fails. f50ab847e31d96c2a5f6b3e901e24a18
I don't know your password, but it should be on the meter documentation.
