  3. AARQ Failed In Suite 1
AARQ failed in suite 1
By aoudumbarpawar , 10 March, 2021
Hii,
My meter is in suite 1 and i want to communicate with the meter in suite 1 mode.
I have successfully shared the certificates of each other (Gurux client and meter) using certificate attributes and methods in suite 0.
Now i have changed the settings from "Secured Connections" tab which snap is attached here with this post.
When i click on connect button i found that Gurux send AARQ frame request in which No signing tag and no signature is there in the frame:
Log :
13:12:56 Send SNRM request.
TX: 7E A0 23 00 02 BA 69 C1 93 05 72 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
13:13:06 Failed to receive reply from the device in given time.
13:13:06 Send Disconnect request.
TX: 7E A0 0A 00 02 BA 69 C1 53 B3 96 7E
13:13:16 Failed to receive reply from the device in given time.
AARQ plain data : 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF
Can please suggest where i am doing mistack in settings?
Best Regards,
Aoudumbar Pawar
5 years 4 months ago
The meter is not answering for SNRM message. Check your server and client addresses.
aoudumbarpawar
Hii,
Hii,
Sorry!!! wrong log was mentioned
Please find the below log:
14:52:24 Send SNRM request.
TX: 7E A0 23 00 02 BA 69 61 93 FA DD 81 80 14 05 02 01 F5 06 02 01 F2 07 04 00 00 00 01 08 04 00 00 00 01 2C 01 7E
14:52:24
RX: 7E A0 23 61 00 02 BA 69 73 09 85 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
14:52:24 Send AARQ request.
TX: 7E A0 6E 00 02 BA 69 61 10 20 82 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 45 64 41 16 14 21 49 76 27 22 27 77 23 5F 0D 6A BE 23 04 21 21 1F 31 00 00 00 00 77 D6 3D C5 1C ED 11 35 27 29 A1 4C 2B 00 A1 00 5B 26 AC 59 BD B4 9C 85 1D 5D 46 C4 7E
14:52:34 Failed to receive reply from the device in given time.
Connect to the device and read Security setup. Check that Suite is Ecdsa256 and not GMac or Ecdsa384.
http://gurux.fi/PublicKeyCryptography
Change suite to Ecdsa256 if it's GMAC.
aoudumbarpawar
Hii,
Hii,
I have set the suite to ecdsa256, but problem remains same.
Please find the attached snaps
Log:
15:54:39 Send SNRM request.
15:54:39
15:54:39 Send AARQ request.
TX: 7E A0 6E 00 02 BA 69 61 10 20 82 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 26 37 2A 12 31 51 1F 5D 04 07 53 4D 25 29 59 5E BE 23 04 21 21 1F 31 00 00 00 00 8E 91 A5 76 70 B8 F3 EF 2A D9 34 56 84 50 9D 86 AC 9C 58 CE 2E 61 13 0B CA 1D 51 04 7E
15:54:49 Failed to receive reply from the device in given time.
In the pic your server system title is not correct. Is the meter our example meters or is it the real meter?
aoudumbarpawar
Hii,
Hii,
This is my testing meter and i have put server meter system title to 12345678
What programming language you are using? I believe that example servers don't handle ECDSA yet.
aoudumbarpawar
Hii,
Hii,
Below is the difference between our suite0 AARQ and gurux suite1 AARQ,
Our Suite 0 AARQ frame suite0 7E A0 6E 0 2 BA 69 61 10 20 82 E6 E6 0 60 5D A1 9 6 7 60 85 74 5 8 1 3 A6 0A 4 8 31 32 33 34 35 36 37 38 8A 2 7 80 8B 7 60 85 74 5 8 2 2 AC 12 80 10 31 32 33 34 35 36 37 38 39 31 32 33 34 35 36 37 BE 23 4 21 21 1F 30 0 0 0 12 26 DB C6 A8 76 30 7 79 0D 9F 4F 4 0E 2D 51 36 4D 4A 9A 11 34 10 5E B6 D0 6 EF 7F 7E
gurux suite 1 frame suite 1 7E A0 6E 0 2 BA 69 61 10 20 82 E6 E6 0 60 5D A1 9 6 7 60 85 74 5 8 1 3 A6 0A 4 8 31 32 33 34 35 36 37 38 8A 2 7 80 8B 7 60 85 74 5 8 2 2 AC 12 80 10 5B 65 23 2A 5 21 0E 46 6A 4C 72 11 34 0E 6B 36 BE 23 4 21 21 1F 31 0 0 0 0 8E 91 A5 76 70 B8 F3 EF 2A D9 34 56 84 50 9B 60 CC AD 0F 1E 7F E6 F4 E7 E3 D5 D0 96 7E
as per observations, there is no signing tag and signature in gurux suite 1 frame , only getting IV as 31
aoudumbarpawar
Hii,
Hii,
I am not using any testing meter, it is a real meter which supports the ECDSA (Tested with CTT tool).
To verify that meter is supporting or not supporting ECDSA, first client must have to sent AARQ (suite1) to the meter.
Aoudumbar
ECDSA is started to use after the connection is made for the meter.
It's not sent in AARQ or AARE messages. It's not possible to update the ephemeral key pair in Ephemeral Unified Model before the connection is established.
aoudumbarpawar
hii,
hii,
Please find below log:
17:14:01 Send SNRM request.
17:14:02
17:14:02 Send AARQ request.
TX: 7E A0 6E 00 02 BA 69 61 10 20 82 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 45 3B 2C 02 51 30 07 43 74 0E 48 15 40 2A 4D 28 BE 23 04 21 21 1F 31 00 00 00 00 8E 91 A5 76 70 B8 F3 EF 2A D9 34 56 84 50 9B 60 CC AD 0F 1E 7F E6 F4 E7 E3 D5 1C F9 7E
17:14:02
RX: 7E A0 7A 61 00 02 BA 69 30 60 C6 E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 31 32 33 34 35 36 37 38 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 61 62 63 64 65 66 67 68 69 6A 6B 6C 00 00 05 35 BE 23 04 21 28 1F 30 00 00 00 00 87 91 A3 29 69 E3 EC EB 3A C4 28 4B 7B A8 1A 82 08 C5 AB 04 C2 F3 FD B5 07 05 A3 90 7E
17:14:02 Authenticating.
TX: 7E A0 E4 00 02 BA 69 61 32 7A EF E6 E6 00 DD 08 00 00 00 00 00 00 00 01 08 31 32 33 34 35 36 37 38 08 31 32 33 34 35 36 37 38 00 00 01 02 01 01 81 80 95 2D C0 AF C4 41 D3 36 80 AF E0 29 51 69 C6 34 A8 CC 79 3D 66 FB 7C 63 8B CF 2C CF 90 7A 35 D4 FB FE 76 4F 70 3C 1F F2 CD F4 7A 62 21 72 2C 21 4E E1 88 08 19 21 2C C0 1B 6E 7D DD E8 22 14 25 FF D4 08 33 D3 A2 C8 7A 17 B9 6B 3F 66 DE 90 58 F9 0B 2D AE 14 92 8C 75 EC 83 09 C9 0F 4F 24 1C CA 36 F5 AC 20 99 87 C0 7D 8F 3C 42 AE 97 1B 40 08 15 A1 4F 89 A8 54 F9 86 CE D4 57 F6 8A AD B7 30 31 00 00 00 00 14 BD 5C C6 35 B3 BF 83 D3 84 2A 7D E8 E5 6A FA EF 9B A0 BC EC BF 51 C9 98 97 2D 3A 13 B8 F3 AF 81 98 5A 8E 4C 00 5D 35 0F CE 11 0E 40 7E
17:14:03
RX: 7E A0 7D 61 00 02 BA 69 52 6C 41 E6 E7 00 00 6C 31 00 00 00 00 50 91 AD 47 44 D4 D8 DE 1C EE 12 43 4A 9D 71 6B C6 C5 AF 5E 4C 32 7E 67 6B EB BD 19 08 8E 07 2A 97 ED 57 E6 C8 61 D5 5B 9F 4F 7A 6D C6 36 CB CF 4A 8F 3E 45 F1 36 81 D5 74 15 57 93 50 94 F8 8E 40 46 7B 86 8F AC 25 2C 03 F6 08 CD D2 92 D9 10 CD 46 00 BA C2 A5 D4 48 3E 29 FA 0C 16 91 24 27 16 32 27 A3 54 12 AC 2D FE 7E
Client added DD (general signing tag), also msg is not encrypted and no signature
aoudumbarpawar
Hii,
Hii,
How to setsetting to General signing(0xdf) in gurux?
In my mind message is encrypted with One-Pass Diffie-Hellman. Why do you think that it's not encryted or there is no signature?
<HDLC len="E3" >
<!-- Logical address:1, Physical address:11956 -->
<TargetAddress Value="6EB4" />
<SourceAddress Value="30" />
<FrameType Value="32" />
<PDU>
<GeneralCiphering>
<TransactionId Value="0000000000000001" />
<OriginatorSystemTitle Value="3132333435363738" />
<RecipientSystemTitle Value="3132333435363738" />
<DateTime Value="" />
<OtherInformation Value="" />
<KeyInfo>
<AgreedKey>
<KeyParameters Value="01" />
<KeyCipheredData Value="952DC0AFC441D33680AFE0295169C634A8CC793D66FB7C638BCF2CCF907A35D4FBFE764F703C1FF2CDF47A6221722C214EE1880819212CC01B6E7DDDE8221425FFD40833D3A2C87A17B96B3F66DE9058F90B2DAE14928C75EC8309C90F4F241CCA36F5AC209987C07D8F3C42AE971B400815A14F89A854F986CED457F68AADB7" />
</AgreedKey>
</KeyInfo>
<CipheredContent Value="310000000014BD5CC635B3BF83D3842A7DE8E56AFAEF9BA0BCECBF51C998972D3A13B8F3AF81985A8E4C005D350FCE11" />
</GeneralCiphering>
</PDU>
</HDLC>
In reply to Hii, by aoudumbarpawar
Check "General Protection" from "Supported Services" -tab.
aoudumbarpawar
Hii,
Hii,
Our meter supports general signing, how can we set gurux to support general signing ?
We are implementing the general signing at the moment.
aoudumbarpawar
Hii,
Hii,
Thank you very much for such a great support.
Will wait for next release which supports general signing
Best Regards,
Aoudumbar Pawar
  • oLtbbWaRQMvErs…
  • Rolling Slots
  • Vegazone-Australia
  • Mathewgon
  • MichaelCab
