  3. ProfileGeneric - Error While Reading
ProfileGeneric - error while reading
By MNN , 1 March, 2021
Hello.
When I try to read the event log, an error occurs: "Not enough memory to continue running the program" and "Unacceptable frame".
18:39:31 Access Request
TX: 7E A0 56 03 0F 32 02 C5 E6 E6 00 D9 C0 00 00 01 00 06 01 00 07 00 01 63 62 04 FF 04 01 00 07 00 01 63 62 04 FF 05 01 00 07 00 01 63 62 04 FF 06 01 00 07 00 01 63 62 04 FF 02 01 00 07 00 01 63 62 04 FF 07 01 00 07 00 01 63 62 04 FF 08 06 00 00 00 00 00 00 20 92 7E
18:39:36 Data send failed. Try to resend 1/3
5 years 6 months ago
I believe that your meter is not supporting Access-service. Try to un-check it from the "Supported services" tab.
MNN
Thank you!
Thank you!
