  3. GXDLMSDirector CTT Issue
GXDLMSDirector CTT issue
By rajacms , 26 February, 2021
Dear Mikko,
GXDLMSDirector issue for CTT testing - please check it
it is showing - Object reference not set to an instance of an object.
10:47:11 Send SNRM request.
10:47:11
10:47:11
10:47:11 Disconnect request
10:47:11
5 years 8 months ago
What test is causing this?
rajacms
Dear Mikko,
Dear Mikko,
when i start running GXDLMSDirector->CTT it will coming like that. previous version not given this issue
Starting to execute test for PC.
Object reference not set to an instance of an object.System.NullReferenceException: Object reference not set to an instance of an object.
at GXDLMSDirector.GXConformanceTests.ReadXmlMeter(Object data)
I can repeat the issue. I created an issue from this.
https://www.gurux.fi/node/17980
This is fixed ASAP.
This is fixed and a new version is released.
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
