  3. Ivy Meters DLMS
Ivy Meters DLMS
By beliy , 8 February, 2021
We bought several meters to check "Ivy Metering". For me, dlms is a new protocol (we mainly work with "modbus" and have not yet figured out how to work with it. I can not connect to the meter. Can you help me please?
I try connect with this configuration:
Authentintication level: Low
Interface type: WRAPPER
Client address: 0x10
Server address: 0x10
Password: 12345678
But it isn't work...
0:05:50 Initializing serial connection.
10:05:51 AM Send SNRM request.
7E A0 08 20 21 21 93 20 67 7E
10:05:56 AM Failed to receive reply from the device in given time.
10:05:56 Disconnect request
10:05:56 AM Send Disconnect request.
7E A0 08 20 21 21 53 2C A1 7E
10:06:01 AM Failed to receive reply from the device in given time.
at GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, Int32 multiplier, Int32 tryCount, GXReplyData reply)
5 years 7 months ago
Is your meter connected to the serial port or do you try to connect using TCP/IP connection?
beliy
Hi Mikko
Hi Mikko
I'm connecting with rs485
beliy
com config
com config
beliy
config
config
I checked the documents that you sent to me. I'm not sure if you can connect with DLMS using the serial port. You need to ask is it possible from the meter vendor. In the documents there communication with DLMS is shown only between TCP/IP server and GPRS meter.
