  3. Octet-string Manipulation
Octet-string manipulation
By lara.wakim , 3 February, 2021
Hello Mikko,
We are trying to use the octet-string as type to store date-time values but we are facing some difficulties.
In fact, we created an object of type gxData with value type octet-string:
int addTimeStampBillingPeriod1Contract1LastReset()
int ret;
const unsigned char ln[6] = { 0, 0, 94, 34, 11, 255 };
if ((ret = INIT_OBJECT(timeStampBillingPeriod1Contract1LastReset, DLMS_OBJECT_TYPE_DATA, ln)) == 0)
static char DT[12] = "012345678901";
GX_OCTET_STRING(timeStampBillingPeriod1Contract1LastReset.value, DT, sizeof(DT));
return ret;
We are reaching sometimes a value of type gxtime or uint32(epoch time) and we want to update the value of the above object (type octet-string) based on the new value (type gxtime or uint32). We didn't know which function to use and how to do it. If you please guide us.
Best Regards,
Lara Wakim
lara.wakim
5 years 7 months ago
We have another question concerning the clock object. Supposing that we enabled the daylight saving and we want to initialize either the end or the begin time to the last Sunday of a certain month (for example Date of last Sunday in October). How are we supposed to write this? is it even implemented or not yet?
We noticed that you have extra info like "DLMS_DATE_TIME_EXTRA_INFO_LAST_DAY" but this means the last day of a specified month but it didn't mean the last Sunday in this month. So maybe we should add in this enumeration this case.
Best Regards,
Lara Wakim
