By MNN , 22 January, 2021 Forums Gurux.DLMS.AMI Hello. I try to write an object 0.0.19.20.0.255, but an error occurs: "Input string was not in a correct format". Image Hi, Hi, Please, don't use images. Reading bytes is pain. Can you paste plain text from the write operation so I can check this? BR, Mikko Hello. Hello. This is the text from the write operation: warn: Gurux.DLMS.AMI.Scheduler.GXSchedulerService[0] Timed Background Service is working. Send SNRM request.7E A0 07 03 0F 93 2C B8 7E TX: 03:48:51 7E A0 07 03 0F 93 2C B8 7E RX: 03:48:51 7E A0 1E 0F 03 73 E3 69 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E Parsing UA reply.81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 Parsing UA reply succeeded. Send AARQ request TX: 03:48:51 7E A0 2B 03 0F 10 D8 16 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E RX: 03:48:51 7E A0 37 0F 03 30 4C 6F E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 0 4 00 00 18 1D 03 E8 00 07 58 26 7E Parsing AARE reply61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 03 E8 00 07 Parsing AARE reply succeeded. fail: Gurux.DLMS.AMI.Reader.ReaderService[0] Failed to Write 0.0.19.20.0.255:6. Input string was not in a correct forma t. Disconnecting from the meter. TX: 03:48:51 7E A0 07 03 0F 53 20 7E 7E RX: 03:48:51 7E A0 1E 0F 03 73 E3 69 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E warn: Gurux.DLMS.AMI.Scheduler.GXSchedulerService[0] Timed Background Service is working.
Hello.
Hello.
Send AARQ request
t.
