By Chris_Zhu , 20 January, 2021 Forums DLMSDirector Hi, I'm using GBT with DLMSDirector,but when reading object lists,after read finished,it says "Invalid response",I'm confused,is my GBT frame wrong? this is part of the traffic: 14:09:42 Get Next Data block. 14:09:42 Collecting objects 00 01 00 01 00 01 00 23 DB 08 59 54 4C 66 30 00 27 11 18 30 00 00 00 4A CA 10 18 1B 8F DB 54 23 72 2A A5 E1 6A 96 E0 F1 4A 1B 63 14:09:42 00 01 00 01 00 01 00 E4 E0 81 00 01 00 4A 81 DC DB 08 59 54 4C 66 30 00 27 11 81 D0 30 00 00 00 4B 43 FC A0 78 26 75 58 35 54 0A 36 7B 8F 29 2F 8D ED 6E 85 B3 6B 4F 79 8A 3D 0C C4 29 B2 F4 44 85 AE F9 3A F6 E5 35 8D C5 6C 58 58 00 F2 0A 89 68 2F 10 47 66 B1 2D AB DE AF A3 71 2B 8F 38 2D 1F F1 E4 CB F8 C3 F0 7E 9F FA FA E6 43 08 88 37 8E 74 0D D8 86 B2 63 33 87 3B B4 1A 42 CE DD C2 E0 31 35 18 C4 06 A6 E9 75 9C 55 54 86 28 47 DA 04 8C 6B 89 D9 45 9D F2 3B 02 0C DA CB C0 A7 D6 57 C8 21 33 D3 6B 7B A0 8F 5C BA 07 AB 9A 27 90 BB 99 B0 CB B4 57 7B E5 9B D5 97 F0 49 D9 91 3E 55 3B 00 87 41 F5 BA DE B5 68 7D B6 97 53 0C AD 83 BD 60 4F 2F B7 CC 85 C2 C7 28 22 2F 56 F4 22 E7 D2 54 B9 17 FC CB C2 BD B2 84 4D 14:09:42 Get Next Data block. 14:09:42 Collecting objects 00 01 00 01 00 01 00 23 DB 08 59 54 4C 66 30 00 27 11 18 30 00 00 00 4B 47 FC A0 78 26 75 11 BA A4 DF 72 68 C9 23 A2 65 DF C1 19 14:09:42 00 01 00 01 00 01 00 D4 E0 81 00 01 00 4B 81 CC DB 08 59 54 4C 66 30 00 27 11 81 C0 30 00 00 00 4C 46 F0 D2 02 7F FA 97 70 8E 1B 44 55 7E 8B E9 5F 78 48 7C 07 6C A1 FB F0 7E 8A E6 14 E4 71 01 68 23 FB FA CD F4 96 09 83 9B 96 CF 38 FD 11 19 E1 8B 59 D8 8D 92 65 AF F5 96 D1 6E 93 8F F4 20 29 DB 85 C9 C5 38 2B 6C BC E8 7E DA 69 07 26 7B 90 D3 2C B7 A4 E6 2C 00 BD 9C 26 CA C7 C8 0C F2 09 0E AA 30 28 5C 12 ED CE D5 1D 4B 39 7D 6D 70 B9 20 33 3C 39 B8 C6 8E 9D 20 9A 20 91 1F 9E 91 8D C3 12 A3 E4 2F 1E 4A 1B BB AD 25 2E E1 E5 B0 FF E8 FB 42 46 F9 56 40 9D 0C 0B BE AB D3 36 E2 85 30 39 34 4C C4 80 D2 A7 DF 47 B6 9F 2C 85 E2 CC A5 AB AB D5 AE 17 61 06 CB DD 93 Gurux.DLMS.GXDLMSException: Invalid response. Hi, Hi, Can you read the meter without ciphering? Now data is encrypted and I can't check the content of it. BR, Mikko I am reading object lists,and Hi,Mikko follow is the first two response from meter in plain text ,The GBT format I think its correct,I check the green book,it says if read long attribute with GBT,meter should response with Get-Response-Normal,so I response like below: RD:C4 01 C1 00 01 82 01 14 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 03 00 02 03 0F 04 16 01 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 03 00 02 03 0F 08 16 03 00 02 03 0F 09 16 01 00 01 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 04 02 02 0F 01 16 01 02 02 (09:27:30:808) RD:C4 01 C1 00 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 11 11 00 09 06 00 00 29 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 17 11 01 09 06 00 00 16 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 03 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 29 11 00 09 06 00 (09:27:32:531) Hi, Hi, You are sending two normal get responses and this is not correct. In GBT you add all data to one get response and then split that get response to GBT blocks. BR, Mikko BR, Mikko Hi,Mikko Hi,Mikko thanks for your reply,but I'm still having trouble now,I modified like you said,and I put the response data to the translator,it shows fine,I check Green book,there is a Additional_service_Parameter when use GBT in which the invocation_Type(COMPLETE,FIRST-PART,ONE-PART ,LAST-PART) parameter is mandatory, is it the possible reason?but I didn't find any example ,could you send me some examples about GBT and explain, appreciate !below is the data : TD:C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 RD:C4 01 C1 00 01 03 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 03 00 02 03 0F 04 16 01 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 03 00 02 03 0F 08 16 03 00 02 03 0F 09 16 01 00 01 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 (10:07:20:834) RD:16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 11 11 00 09 06 00 00 29 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 (10:07:21:227) Hi, Hi, Try to read server example with GBT. https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Server.E… It will return correct data. BR, Mikko
Hi,Mikko
Hi,Mikko
Hi,Mikko
