  3. Which Profile To Use For a Meter With a Modem 3g Integrated
Which profile to use for a meter with a modem 3g integrated
By tagmout , 23 September, 2020
Hi Mikko ,
In the case of a meter with a 3g modem integrated , the meter have it s adress ip , or the modem which have an ip adress ? And with which profile communicate the meter in this case .
Thank you
5 years 12 months ago
The modem has the IP address. The communication profile depends on the meter. Newer are used WRAPPER and older HDLC.
tagmout
Okey , when the wrapper is
Okey , when the wrapper is used , the meter will have an @ ip ?
5 years 11 months ago
Yes. If WRAPPER is used, the meter should have an IP address.
tagmout
4 years 9 months ago
so the modem have an IP
so the modem have an IP address and the meter have also another IP address !! or they have the same address ?
There is only one IP address. I don't know any meters that have several modems.
The IP address is the address of the modem. The meter doesn't have an IP address.
BR
