  3. Need Help In Reading Energy Meter
need help in reading energy meter
By rahul p , 24 September, 2020
sir
I want to read data from the ER300P energy meter using RJ11 port through arduino micro controller .
can you please help me with this how to go above ?
rahul p
5 years 10 months ago
can you please me sir in this
can you please me sir in this ?
I believe that the best way to start is if you download GXDLMSDirector and read your meter with it first.
In this way, you get an idea from DLMS meters. After that you can download client example for Arduino.
rahul p
okay .
okay .
sir can you help me with hardware interfacing of meters RJ11 port with Arduino ?
I am using STM32 blue pill Arduino board .
5 years 9 months ago
You can use the Arduino client example as a template to read your meter. You need only to change the correct parameters. If values are wrong, the meter doesn't reply anything.
  • brainstormkale…
  • Vegazone-au
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
