  3. Checking DLMS Standards In Gurux
Checking DLMS Standards in Gurux
By hhkx , 1 September, 2020
I have been using Gurux for DLMS test developments. One of my customer wants to check if my app is compatible with DLMS standards.
Is there a tool in Gurux that accredits data exchange standards in DLMS reading to check compliance? Or if there is a solution that we can use as a third party for this process, can you share it?
Thank you,
Hasan
6 years ago
Hi Hasan,
Hi Hasan,
If you are implementing the meter you need to apply the certificate from DLMS UA.
https://www.dlms.com/certification-scheme/conformance-test-tool
If you are implementing the client-side, there is no certificate for that.
