  3. HLS Not Working In GXDLMS-Director Version 8.2.2008.2701
HLS not working in GXDLMS-Director version 8.2.2008.2701
By Chintan Patel , 30 August, 2020
HLS is not working with the latest version of Gurux director 8.2.2008.2701.
With the same project file, we can connect with an older version 8.1.2006.2302.
We are facing this issue with HDLC over a serial port.
Kindly let me know if you need more information.
Thanks & Regards,
Chintan Patel
6 years ago
Hi Chintan,
Hi Chintan,
Can you first select "Supported Services" tab and check that Get" and "Action" services are selected.
If they are selected can you add trace from the messages so I can check it?
RiteshNaik
6 years ago
HI,
HI,
With latest version of Gurux director 8.2.2008.2701; Association with HighGMAC is not connecting for HDLC over local port, with older version it is working fine.
HDLC Logs:
15:35:48 Send SNRM request.
TX: 7E A0 08 02 23 23 93 0D 57 7E
15:35:48
RX: 7E A0 1F 23 02 23 73 90 FE 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
15:35:48 Send AARQ request.
TX: 7E A0 6C 02 23 23 10 3D 6D E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 45 4C 53 67 10 00 00 01 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 57 44 5A 3D 2A 52 23 5A 5B 15 1A 20 4E 02 55 69 BE 23 04 21 21 1F 30 00 00 01 F4 93 A4 B7 11 54 3C 26 CF 52 D8 CC F0 B7 28 47 16 08 B2 24 5E 89 10 9E 1C 85 E1 D8 44 7E
15:35:48
RX: 7E A0 47 23 02 23 30 4D A1 E6 E7 00 61 38 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 A4 0A 04 08 45 4C 53 67 10 00 00 00 88 02 07 80 89 07 60 85 74 05 08 02 05 BE 06 04 04 0E 01 06 04 DE B2 7E
15:35:48
6 years ago
Hi Ritesh ,
Hi Ritesh ,
Did you read the frame counter? Can you add a trace from it also to the new topic?
RiteshNaik
6 years ago
Thanks, New topic open @http:
Thanks, New topic open @http://gurux.fi/node/16649
