  3. Read DLMS Profile Generic
By gkrishna , 21 August, 2020
One more query about the DLMS(C code), The sample client and server I got it and build it, -g is the option to pass obis code, How do I get the profile Generic and by default what I have to pass and also do I need to change server to do the profile generic because by default I dont see anything please help that how can we read profile generic with some Ex. If required I will do the changes in server and client.
Gopi Krishna M
6 years ago
If you want to read profile generic buffer you also have to read capture objects.
Reading profile generic buffer with -g parameter is not implemented to client example at the moment and you need to modify the source code. If you run the client without -g it will first read capture objects and then buffer.
gkrishna
6 years ago
Thanks for the info, how about the server(C code), is that fully supports profile generic, or do we need to make changes in server to support profile generic?
Gopi Krishna M
6 years ago
You can do it as it is. We are improving server-side support for Profile generics to make it easier to use.
