  3. Update Online Manufacturer Is Not Working
Update Online Manufacturer is not working
By Sajjad khan pathan , 1 August, 2020
the manufacturer update from Online is not working for very long. we have to add the manufacturer manually when installing GUrux on a new system as if there is no manufacturer defined, Gurux DLMSDirector does not load properly.
It seems an internet error, a TLS/SSL version error comes generally. Tried to change the TLS and SSL versions on my system to 1.0, 2.0, etc. but did not work.
6 years 1 month ago
What Windows version you are using?
Sajjad khan pathan
6 years 1 month ago
using windows 7.
using windows 7.
But this works in some older versions I have saved in my debug folder.
6 years 1 month ago
Try to re-install it from Gurux downloads. There must be something in your PC because we haven't receive any other reports from this problem.
