  3. Smart Meter AM550 Auslesen. (Python)
Smart Meter AM550 auslesen. (Python)
By UnknownExe , 21 July, 2020
Hello I am new here at GURUX and would have a question about the software.
I would like to read the AM550 electricity meter in Python. I get the data from the customer interface on a USB adapter that is connected to a Raspberry Pi.
Now I want to read out the data record using a Python script and save it in a variable for further processing.
Can you help me with a simple example code?
Thanks in advance
UnknownExe
6 years 1 month ago
Check the video from YouTube first:
https://youtu.be/OcmYvcsgjz4
Then use client example to read data from the meter:
Client example comman line parameters are something like:
python main.py -S COM_PORT -t Verbose
UnknownExe
6 years 1 month ago
Hello and thanks for your
Hello and thanks for your quick reply
I've already tried it, but unfortunately it didn't work. (Photo is attached). With the command: sudo screen -l / dev / ttyUSB0 -s 115200 --parity = none: So I get a terminal where I get data sent every second.
My current electricity provider told me that this character is encrypted with AES 128 and that you can only make it readable with GURUX later, for example.
In addition, I know that the electricity meter can only send and not receive. How can I now write a script where the data is omitted, decrypted and processed.
Unfortunately, I cannot say how to do it. I hope you can help me
Sincerely, UnknownExe
6 years 1 month ago
If I understand correctly, the meter is sending push messages once per second and you want to convert send data to XML? Is this correct? Do you have encryption keys? You need them if data is encrypted.
UnknownExe
6 years 1 month ago
Hello and thanks for the
Hello and thanks for the quick reply
Yes, that's exactly what I want. I want to get the data in my script and do calculations, for example. I have already received encryption and the key from my electricity provider.
UnknownExe
6 years 1 month ago
In this case, you don't use the client example. It'll make a connection to the meter and reads data from it.
You need to use Gurux.DLMS.Push.Listener.Example.python
Try something like:
python main.py -S /dev/ttyUSB0:115200 -t Verbose
Then you need to set the authentication and block cipher keys.
UnknownExe
6 years 1 month ago
Hello and thx,
something did not work during the attempt. Picture attached.
What do you mean by (Then you need to set the authentication and block cipher keys.) Or how can I do that?
UnknownExe
6 years 1 month ago
My mistake- The parameter is:
python main.py -S /dev/ttyUSB0:115200:8None1 -t Verbose
You need authentication and block cipher key from the meter company. Without those keys, you can't decrypt the data. Keys are 16 bytes long keys.
UnknownExe
6 years 1 month ago
Hi and thanks
Hii and thanks,
Yeah it worked so I'm getting data now. I already have the key. The key consists of 32 characters. Where do I write the key so that I can read the data clearly.
I would be very grateful if you could help me with the key.
Best regards
UnknownExe
UnknownExe
6 years 1 month ago
Can it be that I have to
Can it be that I have to write my key somewhere in the code?
Do I need two keys for decryption or did I get it wrong?
6 years 1 month ago
If you have only one key I believe that your meter is using the same key for authentication and block ciphering.
Add parameter like this:
-A YOUR_KEY -B YOUR_KEY
Please, don't paste images. It's easier to get bytes if you paste them as text.
UnknownExe
6 years 1 month ago
Hello and thanks
Hello and thanks
Have I made a mistake while entering? Or I don't find the mistake.
Have I understood that correctly? So I should not post pictures, just the command?
6 years 1 month ago
Yes, don't post the images.
I just checked and command line support for ciphering is missing from the push listener. We'll add command line parameters today.
UnknownExe
6 years 1 month ago
Hello and thanks
Hello and thanks
Oki I will no longer post pictures, just the commands and the errors!
What would you really do for me today !!! Thank you, thank you, I am indebted to you.
If it works afterwards I would like to ask you how I can save the data I get in a script in a variable?
So how could I make a script where every 5 min for example Gurux provides me with all the data from the electricity meter and stores it in a variable.
Thanks again you really help me
Kind regards UnknownExe
6 years 1 month ago
Changes are in GitHub. Get the latest version. Check onReceived method. There is a printData that prints received values. You can modify this for your needs.
UnknownExe
6 years 1 month ago
Hello and thanks that went
Hello and thanks that went quickly
Now this command goes: python main.py -S / dev / ttyUSB0: 115200: 8None1 -t Verbose -A AAAABBBBCCCCDDDDEEEEFFFFGGGGHHHH -B AAAABBBBCCCCDDDDEEEEFFFFGGGGHHHH
But the values I get look like this: New data is received. / dev / ttyUSB0: 1C 73 76
trace: 10: 40: 28 2 9B 9C A6
New data is received. / dev / ttyUSB0: 9B 9C A6
trace: 10: 40: 28 2 98
How can I read this now?
UnknownExe
6 years 1 month ago
I've been thinking but I can
I've been thinking but I can't figure out what that could mean
6 years 1 month ago
Check your baud rate. The first (and last) char should be 7E when your serial port settings are correct.
UnknownExe
6 years 1 month ago
Hello and thanks!
539/5000
Hello and thanks!
The baud rate 115200 should be correct for the ISKRA AM550. But that doesn't work for me yet! I don't see 7E. The activation key offered by my electricity is correct. My command is: python main.py -S / dev / ttyUSB0: 9600: 8None1 -t Verbose -A AAAABBBBCCCCDDDDEEEEFFFFGGGGHHHH -B AAAABBBBCCCCDDDDEEEEFFFFGGGGHHHH
Why could that be, please help me!
Another little question! The values are HEX and I have to convert them to ASCII by hand right?
Best regards!
UnknownExe
UnknownExe
6 years 1 month ago
Could it be that I don't need
Could it be that I don't need the authentication key! But only the decryption key?
6 years 1 month ago
Keys are given as hex. The keys are not the problem here. Check your serial port settings. You should see 0x7e in the trace. Try with different baud rates.
UnknownExe
6 years 1 month ago
I'm confused! It shouldn't matter whether it's a key or not! a 7E should always come! But no matter what baud rate I enter, there is simply no 7E. Now I'm even at the end of my Latin I hope you can still help me or give me a tip! The baud rate for the AM550 is 115200 on the internet but I have no success with that either.
6 years 1 month ago
I asked from this and it seems that some meters are configured to send ASCII data and not DLMS. This depends from the metering company, etc.
Try to connect using 115200 8None1. Is your data ASCII?
UnknownExe
6 years 1 month ago
When I was experimenting, I
When I was experimenting, I got a thing with 7e, the same thing, but I can't convert it into clear signs either.
Command: python main.py -S /dev/ttyUSB0:9600:7even1 -t Verbose -A KEY-B KEY
7E 1B 5C 18 2B 18 1E 5B 5E 58 47 1B 5C 1F 3E 1F 7B 1B 1C 46 1B 2B 1C 1D 1A 33 79 1B 1C 66 5D 37 1B 5E 1E 78 1B 3C 1E 5D 56 33 2B 1C 18 57 3B 2B 5C 5A 73 1B 1E 46 06 5F 18 5E 5F 1F 7F 1B 5C 1E 1B 19 47 1B 1C 18 1B 59 1B 1C 1C 53 1C 5F 1B 1B 5C 19 5F 1C 19 18 1E 18 1E 37 1B 1E 38 58 53 5E 03 5A 46 1B 5C 27 13 7F 1B 1C 1A 19 6B 1B 1C 5D 2B 77 1B 3C 58 1A 18 1B 1C 1F 7F 1B 5C 1D 5E 3B 58 5E 38 5E 57 5C 1B 1C 1D 5D 5C 7B 1B 2B 5E 63 7E
with this command: python main.py -S /dev/ttyUSB0:115200:8None1 -t Verbose -A KEY-B KEY
Unfortunately I don't get a 7E!
My data comes in the DLMS from binary
6 years 1 month ago
Now there is 7E in the beginning and in the end, but data in the middle is not correct. Can you ask from the metering company what serial port settings you should use?
UnknownExe
6 years 1 month ago
The electricity meter company
The electricity meter company says that the settings should be 115200 8None1! But they said it's probably an electrical problem for me. Do I have to build a RJ11 or Rj12 to usb cable myself? Or can I buy?
6 years 1 month ago
Have you connected to the serial port or P1? Can you connect using 115200 8None1 and post received bytes here as plain text? I'll check one thing.
UnknownExe
6 years 1 month ago
hello, should i send the
hello, should i send the original output of the console window? or should I summarize it on the hex characters. best regards UnknownExe
UnknownExe
6 years 1 month ago
My Output;
My Output;
GURUX with KEY
Commend: python main.py -S /dev/ttyUSB0:115200:8None1 -t Verbose -A KEY -B KEY
Try 1 Output:
00 1B 58 1B 58 63 5A 1B 58 6B 1E 5F 3B 2B 58 5E 1E 73 1B 18 33 5C 58 7B 1B 58 77 38 58 59 1E 1C 18 58 5E 7B 5A 19 1B 18 5F 5F 19 1B 58 5C 19 47 1B 58 5F 1E 7F 1B 58 1B 1F 1C 1B 78 47 58 1A 00 63 5A 7F 1B 30 5C 1F 1B 1B 18 1B 18 1F 5E 5C 2B 73 1B 58 16 5C 0B 1F 1B 58 57 5B 1B 58 5A 7D 1B 58 18 5B 1D 58 59 5B 63 1B 18 6C 18 5C 1B 18 1F 47 1B 58 5F 59 18 18 1D 5F 18 58 1B 58 5F 00 1A 58 7E 1B 58 1F 1B 1C 1C 18 58 19 7E 1B 18 1B 30 59 2B 5B 1B 30 3F 1D 5E 7F 33 2B 58 1D 5E 5E 1B 18 1C 7A 1B 2B 18 1C 5F 1B 58 5A 18 1B 18 66 7D 18 58 27 1B 58 1B 1B 18 33 37 1C 1B 1C 00 63 1F 18 47 1B 18 5D 19 7C 1B 18 5C 67 1B 5C 18 3B 1B 58 5C 0F 1B 58 5E 5F 7F 1B 5C 1F 5D 1B 5C 18 5B 1F 7E 1B 18 5E 1F 1B 58 5D 3C 5B 5A 53 18 4B 7E 1B 18 1F 7F 7F 1B 58 5B 1F 18 18 5C 00 23 1C 7F 18 58 27 47 53 37
Try 2 Output:
9B 1C DA 9B 5C 1E 1A 59 66 9B DC 46 1F 59 9B 9C DD 9E 18 53 D8 5F 9B 5C 19 DE DE FF 9B DC FB B7 FF 9B 9C 66 B1 3B 98 18 59 4B 36 F8 9B 1C B7 37 FE BB AB 1C 9B 5C 66 FF 9B 18 83 9F 9A FF 9B 1C 9A 5E 5D DA 9B DC 5B 1F 9B DC F3 9B 98 DE D9 B3 AB 58 9A DD 37 9B DC 1E 4E FE 9B 1C D8 9B 1C DE 6B DB 9B 9B DC 5A DC 18 9B 5C 9A 9B 1C 5F 9B 1C D9 1D DC 36 9B 9C 6F 58 DB 98 DC 98 9F 9B 5C 59 1B 9B DC E7 F9 9B 9C 1F FE FB 9B 1C DF DD 5E 9B 1C 5A FF 9B 1C 9B 1C 5C 57 BF 9B 58 D3 3F 98 9C 19 9C 9B 5C 5C 1F 38 98 DC 1C DC D6 57 9B 5C 9F D6 98 5C 5C FB 98 5C 9B 98 9B DC 73 B3 AB 1C 5A 46 03 9B 3C 9D 1A BB AB 5C DB 57 9B 5C 9C 5E BB AB 5C DA 1F FF 98 9C F7 1B FF
Try 3 Output:
00 98 5C 9E 1B B1 DF 1C 9A 1F 9B 1C 39 FF 9B 9C 5F 1B 3B 9F B3 AB DC 5D FC 98 5C 5E 5A F3 BB AB 9C 5B D9 9B DC 17 06 9B 9C 3F 56 C7 FF 1C 7B 9B AB 1C DA DE 17 DF 9B 9C DF 9B 5C 86 9A D6 9B 00 9C 06 DB 9B 5C 27 2E 98 9C D9 DB C6 9B DC 76 19 9B 98 DC DC 66 DA 5B 9B 9C 1F B9 9B DD 98 5C 98 9E 9B 5C 18 FF 9B 5C A6 9B 9B 9C 5F 47 9B D8 23 FB 9B 5C 56 5B 1A 9B DC 99 99 9B DC CB DD 00 A7 9B 1C C3 1B 9B D8 5A 39 DB DD DD 58 6B E7 9B 5C B3 DB D7 D9 9B DC BC 9D 9F 9B DC 57 A6 1A FF 9B 5C 1D A3 5C BB AB BC 58 5F 1A 98 DC 99 5B 9B 1C 19 DF 9A 9B 9C 0B 1D 86 5F 17 9B DC BE 00 9B DC FF 77 FC 9B 5C DF 9C 53 18 5D AB 59 9B DC F7 3F DF 9B 98 DB 23 5F 9B D8 ED 5E 9B 58 87 9B 3C DB B1 FB 9C 9B 9F 5A 9B 5C 43 E3 9B 5C 9B 9B F9 9B D8 FB 19 9B 58 DB FF FF 18 9B DC 3E 00 DE 9B 98 5C 76 98 58 5F 1F
GURUX without KEY
Output over a longer period:
9B 1C 9C 9E 9B 9C 9B 57 BB DD 5C DE 9D B7 9B 9C 97 77 A6 9A 9B 5C D8 57 DD 9B 5C DF 1C 9B 5C 47 9A 18 9B DC DC 1C DF 7B 9B 9C 9B 1C 9E 9F 03 53 9C EF 86 7F 9B 9C 98 DA 9B 5C B8 9E 9B 1C DA 5C BE 9B AB DC 98 9E DB D9 9B 1C 9C 5E 26 9B 5C 1A DF 9B 3C 9C DE 5E D8 9B DC 5B DB 1F 1C EB 38 DA D7 D6 BB AB DC DC C7 9B 1C 5E 5B 9B AB DC 9B 9B 5C 47 C6 9B 9C 07 53 DC 5C DD 7B 3A 53 9C C7 B9 F6 98 1C 1B 16 18 9B DC CB 1B 99 9B 5C 19 F6 9B 1C 9B 9C 3A 9B 1C 9F DC 5B FF 9B 1C 1A E3 9B 1C 47 9B 9C F7 27 9B 5C 03 98 5C 18 DC 53 3C 9A DE 7F 9F 9B 5C FF FF 98 1C 1F 5F 9B AB 5C 5C 46 98 DC 9E 5A B7 9B 9C FB 43 1F 9B DC 1D 9B 38 5B BB DE 98 58 A7 5B 5A 98 1C BB 98 D8 57 18 98 9B 1C DF 19 9B D8 46 DD 9B 1C 1C D7 B3 9B 5C BE 58 19 53 18 5C 9B 5E 98 98 06 9B D8 1C 5D 9B 9C F6 FF 53 18 DF FA 9B D8 DD 5B D8 98 58 A7 43 66 9B 18 9A 1C 9B 9C DF 9F 9B 1C 1F 99 86 9B 5C 7F 98 58 E6 07 9F 9B DC B8 5B E7 9B DC 4B DC FF 9B 9C 1F DB 63 9B 5C 9B 1C 1A 5D C6 BB 9B 9C D9 16 9B 5C B7 76 DF FD 9B 9C 93 9D 9B DC 1C 9B DC DF 9E DF 26 9B 5C 9D 9F 9E 98 58 FE 9B DC DE 9E 9B 9C 5F D8 A6 9B 18 5F 1E 9E 9B 9B DC 3C B7 66 FF 9B 9C B8 9B D8 67 5D 5A 9B 34 1A 17 F7 9B 1C 46 FB FD 9B 5C 5F BF 98 5C D6 B3 9B 1C D6 39 FB 98 5C DA 9C 5C 9B 58 3B 5B C7 98 18 5B 9D 57 FB 53 18 9D 9C F9 9B 58 DF 1E 1D 98 1C DF FF 5D 9B 18 FF 9B 5C DD 5A 98 9B 58 5B 13 59 9B 5C 9A DE 7F 9B 1C 18 26 A7 9B 1C A6 5C FD 9B 5C FF 1D 6B 9B 1C 1B 5B FF 98 9C 5A 9E 66 47 53 98 73 43 1A A7 9B 9C 23 73 9F 9B 5C EB 5A FF 9B DC F3 B3 FE 9B 1C 96 59 99 9B DC 46 9B 9C D8 DD 9B 9C 66 46 9E D9 9B 9C DD 9B 58 1A FF 9B DC DD 9B 9B 9C 9F 1B 1B 9B DC A3 9C 98 18 57 DB 9B 9C 1B 9B DC DE DE B7 B3 AB 9C 77 33 9B 9C D3 5E 9B 5C 9F D3 D9 9B 5C 5E B3 DC 9B DC 5D 9B DC DD 3E 0B 98 18 DB 5A 1D 5F 9B 9C C6 1F 5D 9E 9B 1C 9E 77 DF 9B 5C FF 5B 98 98 D9 DB 1B 9B DC 1F 33 EB 5B 5C 98 18 9A D6 98 DC 5C C3 36 9B 1C 5B 9D 98 58 1F 67 DD 9B 58 DF 1F 1C 98 9C 18 13 58 9B 5C 1C F8 9B DC DA 5B DE 9B 5C 1E 9C 27 9B 5C 53 19 9B DC 53 58 99 9D 97 FE 9B 5C 06 5B 9B DC 93 DF 1A 9B 5C 8B 9D 99 BB AB 98 DA 1F 06 9B 1C 06 1C FE FE 98 1C 5D A3 7D 1E 9B 9C 9F 9A 9B 58 9B 59 9B 58 87 19 9B 1C E6 5F 98 D8 18 5D 1C 9E 9B D8 5B 98 5C 5B 5F 1E 9B 9C B7 DC 1A 9B 9C 3A E6 3B 9B 9C 99 DB 3B 5D 9B DC FB 9B 9B 9C D8 1E 9B DC FC 9B DC DE 9B 9C 86 1E 9B DC 1C BF 9B 1C 9E 9B D8 23 76 9B DC 35 1A E7 FB 9B 5C 76 1D 98 DC 9B 5C 59 DB E3 FF 9B 9C 58 DD A6 9B DC DD D9 99 5F 38 9C E7 1E E3 9B 5C 36 D9 9B DC 9D 1F 9B DC 58 9A 9B 5C 1D 03 9B DC DA DD 59 5B 3B 53 5C 58 5B 57 B7 9B DC C7 9E 18 5F 9B 5C 76 DF 83 98 DC E6 58 33 9B 9C 1B 5A 9B 1C 1D 76 9E 9B 1C 5D 9B 1C BB FB B1 AB 9C 18 9F 9B DC DB 9B 5C 4B 2B DD 9B 9C C3 5F 9B DC 5E 7B C6 9B DC 9A DA DB BB AB 9C DB 9B DC 5D 1F D9 9B 5C 9B 9C 9D 5E D3 BB AB DC C7 1A 9B DC 5C D9 9B 1C EF 9E 9B DC 9A F9 9B 9C 5A 5C FE 9B 5C 9D 58 98 1C C6 07 76 9B 1C 1E 58 9F 9F E6 9B 5C 5E B7 9F 9B 9C 5C 1D 5D F8 9B DC 5A F9 53 5C FB DD A6 53 5C BB 9B 1C 1C 59 BB AB 1C DE 9B 9C 5A A7 FB 98 9C 99 DE 9B 1C 46 9B 1C BF 98 DC 58 98 1C 19 59 1E 33 9B DC 7D DB 9A 9B DC B6 5C 33 9B B1 AB 9C 18 26 FF 9B 9C D3 FF F6 5B 9B 9C 5C 03 9B 5C B6 9F 17 98 1C 26 9B 9B 98 5C DC E6 9B 98 DC 5D 5B 1B BB AB 9C 0B F8 9B 9C 99 DC E3 9B DC DF 1D 9B 5C FE 9B 1C 96 5A 9B 9C 57 DB 9B DC 3A D8 F8 9B 1C 5F 59 9B 1C B9 9B 98 BC E7 9F 9D 53 1C 07 5D 9B 1C AF 13 5B 9B 1C 1A DF 18 9B BC 87 2B 35 5C D9 97 5B 99 9B 9C 9B 9C 9B 9E AB 9B 1C 5E 1C 9D 99 9B 5C 9B DC D8 87 9B AB 5C 1B 9E 98 BB AB DC BD DD 19 87 9A 9B DC 1D 1E 1C 9B DC DB C7 D8 9B BC 98 A7 1B 9B 5C FF 9B 1C 18 98 9C 9C 5F B7 B6 9B 9C 3B 9B 9C 7F 19 53 9C 1A 5F 9B 9B 9C D9 DF 1A 9B FF 9B BC DE DD 9B 9C 2B C7 9B DC D9 9F FF 9B 1C DB 5E EB 9B 1C DA
Output from my Python Script Code --> image
b'\x00\xfe`\xf7\xcf\x02c3{\xc5\xe6\xe7\x00\xfb\x08\xc9\xf3\xcb\xe9\xf4\xc6~\xce\xff`\x00\n\xee2\xfb\x02\xf0\xc3\xf8\xed6\xeaa\xc8\xf0\xe0?\x0cu\xca\xf4\xfe\x06s\xc2\xf0\xf1j\x0b\xf9\xe5el:\xc0\xfe\xc3\xf0\x00h\xfc\xc5\xfd\xe4}\xc4\x05\xea4\xeb;\x04\xfb\xf3\x0b\xc9l\x0e\xc2ob5\x03\xc0\xfc\xe5vx\xef=\xf9\x01\x00d\x08\x0c\xc7\xf1\xf8d\xfa\xe1\xf1\xf69exz\xf6\xea\nw\xf1\xf2\xc6n\xec\xfe\xfe`\xf7\x00\xcf\x02c3{\xc5\xe6\xe7\x00\xfb\x08\xc9\xf3\xcb\xe9\xf4\xc6~\xce\xff`\x00\n\xee3\xff\xf6\x00\xfc\xf2\xcf\xfe\xf91\xcb\xf2mq\xf0du\xea\xf30u\xca\xffm|f\x05\xc3a`\xf9dh:z\xf75\xf9\x000\xea\xf0\x06\x0e\t\x0b}kt\rj\xcawc\xf8\xfdy\xec7\x00\x07o\xc0\xe1\xe2\xef\xc3\xcai\xce\xfb\xe0f\xc6y7\xf0\x03\xff\xfe:\xf3u{\xc5\xf9\x02y\xeaqf\xf7\x018\xfe\xfe`\xf7\xcf\x02c\x003{\xc5\xe6\xe7\x00\xfb\x08\xfe\xfe`\xf7\xcf\x02c3{\xc5\xe6\xe7\x00\xfb\x08\xc9\xf3\xcb\xe9\xf4\xc6~\xce\xff`\x00\n\xeey>\xe1c\xf8p2\x01d\xe1\xfa874\xf4\xf3\x02\xefm6t\xf8e\xf7\xca\x04\xe0\xe9\xc0\xfd\x07:\xf9\xf38\x06\xc6u\xca\xe0\xf6\xf03h{4\xf4r\xfbs\xf3i\xfa\x04\xe3\xea\xc0n<\xe9\xc1k\xf6~g\xfb\xc76\xff9\xf8|\xf0\xf1\xe2\xf9\xea:\xf4\x01\x0frt\xe4\xc4=\xf4\xe8\xc8\xc3\x04\xefb\xfe'
UnknownExe
6 years 1 month ago
I hope the data can help you
6 years 1 month ago
Can you print data in hex and add it here?
UnknownExe
6 years 1 month ago
What do you mean exactly? So the original output from Gurux or from my Python script?
So I get this output again from my Python script:
0x7ea077cf022313bb45e6e700db0849534b6974463e4e5f2000113c343fd6fc45ce3e85f848a3e8ce0a8daaf470a7f4b0cfad6371cee20ca337664a57356b5a78f341c7605f98b5b7807bf3c03da942e2fedacdd760a891ce10c30680a3e2c1575ca7f2741308bf6ca8e86d197bafa2c6238a66fc5ad791a67e
0x7ea077cf022313bb45e6e700db0849534b6974463e4e5f2000113cba00ca8f26f58af24b1b6365b8aee52886eb94f23727f1fc15cc6f0117b07ffccfd723fa29b3074d37fa21c180d567744ad94c0085031a2bcc069e7fb5f7a3a6f9b021bb745ee0a4a42f2b27651179456d6e3480c1a6637bc8d55f6b747e
0x7ea077cf022313bb45e6e700db0849534b6974463e4e5f2000113cd13153d5bee8baf72650d67088ec149b8be8ee7b5eeeddffa16353e376d635840cb267cb19f1e1d2e026dcd9a0353989ee15ef83c623fb86215ce8e7414f418b5ab51594d1f74d616691538df0ba0edb4e21b3f6db7b8b66b99db744527e
And from the Gurux I get this output (original):
python main.py -S /dev/ttyUSB1:115200:8None1 -t Verbose
gurux_dlms version: 1.0.83
gurux_net version: 1.0.17
gurux_serial version: 1.0.14
/dev/ttyUSB1:115200 8NONE1
Press any key to close the application.
Media state changed. MediaState.OPENING
trace:13:47:16 2 9B
New data is received. /dev/ttyUSB1:9B
trace:13:47:16 2 1C 5B 13 1E DF
New data is received. /dev/ttyUSB1:1C 5B 13 1E DF
trace:13:47:17 2 98 DC
New data is received. /dev/ttyUSB1:98 DC
trace:13:47:17 2 7F 9F 1C
New data is received. /dev/ttyUSB1:7F 9F 1C
trace:13:47:18 2 9B 9C DF 1E
New data is received. /dev/ttyUSB1:9B 9C DF 1E
trace:13:47:19 2 9B
trace:13:47:19 2 1C BD 16 D3 1B
New data is received. /dev/ttyUSB1:1C BD 16 D3 1B
trace:13:47:20 2 BB
New data is received. /dev/ttyUSB1:BB
trace:13:47:20 2 AB 9C 9F
New data is received. /dev/ttyUSB1:AB 9C 9F
trace:13:47:21 2 98 1C 1F 07
New data is received. /dev/ttyUSB1:98 1C 1F 07
trace:13:47:22 2 98 1C
trace:13:47:22 2 B7
New data is received. /dev/ttyUSB1:B7
trace:13:47:23 2 9B 5C 5A 7B
New data is received. /dev/ttyUSB1:9B 5C 5A 7B
trace:13:47:23 2 DC
New data is received. /dev/ttyUSB1:DC
trace:13:47:24 2 9B
trace:13:47:24 2 9C 26 1C 93
New data is received. /dev/ttyUSB1:9C 26 1C 93
trace:13:47:25 2 9B 5C DC
New data is received. /dev/ttyUSB1:9B 5C DC
trace:13:47:25 2 9A
New data is received. /dev/ttyUSB1:9A
trace:13:47:26 2 9B
trace:13:47:26 2 DC 9E D9
New data is received. /dev/ttyUSB1:DC 9E D9
trace:13:47:27 2 9B
trace:13:47:27 2 5C
New data is received. /dev/ttyUSB1:5C
trace:13:47:28 2 9B 1C 1C 1E
New data is received. /dev/ttyUSB1:9B 1C 1C 1E
trace:13:47:28 2 DB D9
New data is received. /dev/ttyUSB1:DB D9
trace:13:47:29 2 9B
trace:13:47:29 2 5C DB
New data is received. /dev/ttyUSB1:5C DB
trace:13:47:30 2 9B 9C 5A DB
New data is received. /dev/ttyUSB1:9B 9C 5A DB
trace:13:47:30 2 4B
New data is received. /dev/ttyUSB1:4B
trace:13:47:31 2 9B
trace:13:47:31 2 5C 7F 73 53
New data is received. /dev/ttyUSB1:5C 7F 73 53
trace:13:47:32 2 9B
trace:13:47:32 2 BC 5E 47
New data is received. /dev/ttyUSB1:BC 5E 47
trace:13:47:33 2 9B DC
New data is received. /dev/ttyUSB1:9B DC
trace:13:47:33 2 CB 5B
New data is received. /dev/ttyUSB1:CB 5B
trace:13:47:34 2 98 5C 5A 9F F7
New data is received. /dev/ttyUSB1:98 5C 5A 9F F7
trace:13:47:35 2 9B
trace:13:47:35 2 DC D9
New data is received. /dev/ttyUSB1:DC D9
trace:13:47:36 2 9B
trace:13:47:36 2 9C C6 1D
New data is received. /dev/ttyUSB1:9C C6 1D
trace:13:47:37 2 9B 3C 0B
New data is received. /dev/ttyUSB1:9B 3C 0B
trace:13:47:38 2 9B
trace:13:47:38 2 3E DA 1F DC 4B
New data is received. /dev/ttyUSB1:3E DA 1F DC 4B
trace:13:47:39 2 9B DC 18 1F 1A
New data is received. /dev/ttyUSB1:9B DC 18 1F 1A
trace:13:47:39 2 1D
New data is received. /dev/ttyUSB1:1D
trace:13:47:40 2 9B
trace:13:47:40 2 9C AB 1B
New data is received. /dev/ttyUSB1:9C AB 1B
trace:13:47:41 2 9B
trace:13:47:41 2 5C 1D D8
New data is received. /dev/ttyUSB1:5C 1D D8
trace:13:47:42 2 9B
trace:13:47:42 2 1C 5A
New data is received. /dev/ttyUSB1:1C 5A
trace:13:47:43 2 98 1C
trace:13:47:43 2 16 5F D7 9B
New data is received. /dev/ttyUSB1:16 5F D7 9B
trace:13:47:44 2 9B
trace:13:47:44 2 5C DD 9D DD
New data is received. /dev/ttyUSB1:5C DD 9D DD
trace:13:47:45 2 9B
trace:13:47:45 2 1C 1B
New data is received. /dev/ttyUSB1:1C 1B
trace:13:47:46 2 9B 1C B7 C6
New data is received. /dev/ttyUSB1:9B 1C B7 C6
trace:13:47:46 2 FD
New data is received. /dev/ttyUSB1:FD
trace:13:47:47 2 9B
trace:13:47:47 2 9C 59 5B 58
New data is received. /dev/ttyUSB1:9C 59 5B 58
trace:13:47:48 2 9B 9C 38 DE
New data is received. /dev/ttyUSB1:9B 9C 38 DE
trace:13:47:48 2 3F
New data is received. /dev/ttyUSB1:3F
trace:13:47:49 2 9B
trace:13:47:49 2 5C DD 1C 1A 1F
New data is received. /dev/ttyUSB1:5C DD 1C 1A 1F
trace:13:47:50 2 38 DC
New data is received. /dev/ttyUSB1:38 DC
trace:13:47:50 2 1C
^C
Media state changed. MediaState.CLOSING
Media state changed. MediaState.CLOSED
Unknown
UnknownExe
6 years 1 month ago
Hello as I see I get nice
Hello as I see I get nice values in my Python script and a complete nonsense in the Grurux Script. How can I change this so that Grurux gets the same values?
6 years 1 month ago
You are right. Your Python returns correct bytes. We are checking why the serial port component returns wrong bytes, but we don't have an answer yet.
UnknownExe
6 years 1 month ago
Hello and thanks for the knowledge.
I am looking forward to your answer once you have resolved this problem. I have sent you an email with my private email regarding this. you can ignore this or we can continue communicating there. Thanks again. I hope to get back to you soon :)
UnknownExe
6 years 1 month ago
Hallo,
I write it in my post the code of my Python script maybe it will help you to fix the problem.
Code:
import serial
ser = serial.Serial(
port="/dev/ttyUSB0",
baudrate=115200,
parity=serial.PARITY_NONE,
stopbits=serial.STOPBITS_ONE,
bytesize=serial.EIGHTBITS,
timeout=1
in_bin = ser.read(1000)
in_hex = hex(int.from_bytes(in_bin,byteorder='big'))
print(in_hex)
ser.close()
Best regards
UnknownExe
6 years 1 month ago
This is fixed. Update gurux-serial to the version 1.0.15. There was a typo and because most of the meters are using 9600 this was not recognized before.
UnknownExe
6 years 1 month ago
Hello, and THX
Hello, and THX
I think the problem has not yet been resolved.
My output still looks strange. I also don't find a 7E A0. Also, I only get so few characters there should normally be more data per second?
I hope you can help me with this.
Command and Output:
/dev/ttyUSB0:115200 8NONE1
trace:12:55:34 2 9B
New data is received. /dev/ttyUSB0:9B
trace:12:55:34 2 58 9D
New data is received. /dev/ttyUSB0:58 9D
trace:12:55:35 2 98 58 9A
New data is received. /dev/ttyUSB0:98 58 9A
trace:12:55:35 2 E6 DF
New data is received. /dev/ttyUSB0:E6 DF
trace:12:55:36 2 98 D8
New data is received. /dev/ttyUSB0:98 D8
trace:12:55:36 2 9B 13
New data is received. /dev/ttyUSB0:9B 13
trace:12:55:37 2 9B D8 96 9B
New data is received. /dev/ttyUSB0:9B D8 96 9B
trace:12:55:37 2 59
New data is received. /dev/ttyUSB0:59
trace:12:55:38 2 9B
trace:12:55:38 2 D8 DC
New data is received. /dev/ttyUSB0:D8 DC
trace:12:55:39 2 9B
trace:12:55:39 2 B8 66 DD
New data is received. /dev/ttyUSB0:B8 66 DD
trace:12:55:40 2 BB AB 98 9B
New data is received. /dev/ttyUSB0:BB AB 98 9B
trace:12:55:41 2 9B 9C DD DE 59
New data is received. /dev/ttyUSB0:9B 9C DD DE 59
trace:12:55:42 2 9B
trace:12:55:42 2 18 18 37
New data is received. /dev/ttyUSB0:18 18 37
trace:12:55:43 2 9B
trace:12:55:43 2 58 A3 9B
New data is received. /dev/ttyUSB0:58 A3 9B
trace:12:55:44 2 9B
trace:12:55:44 2 D8
trace:12:55:45 2 9B
trace:12:55:45 2 98 1E AB 1F
New data is received. /dev/ttyUSB0:98 1E AB 1F
trace:12:55:46 2 9B D8 D9
New data is received. /dev/ttyUSB0:9B D8 D9
trace:12:55:47 2 98 18
New data is received. /dev/ttyUSB0:98 18
trace:12:55:47 2 9E 9A
New data is received. /dev/ttyUSB0:9E 9A
trace:12:55:48 2 9B
trace:12:55:48 2 98 DB 9E DB
New data is received. /dev/ttyUSB0:98 DB 9E DB
trace:12:55:49 2 9B
trace:12:55:49 2 18 98 5A
New data is received. /dev/ttyUSB0:18 98 5A
trace:12:55:50 2 9B 18 0B 7E 8F
New data is received. /dev/ttyUSB0:9B 18 0B 7E 8F
trace:12:55:51 2 9B D8 FB 86 86
New data is received. /dev/ttyUSB0:9B D8 FB 86 86
trace:12:55:52 2 9B
trace:12:55:52 2 98 98 F8
New data is received. /dev/ttyUSB0:98 98 F8
trace:12:55:53 2 9B
trace:12:55:53 2 D8 D8 5F 3B
New data is received. /dev/ttyUSB0:D8 D8 5F 3B
trace:12:55:54 2 B3 AB 5C FB 67
New data is received. /dev/ttyUSB0:B3 AB 5C FB 67
trace:12:55:54 2 3B
New data is received. /dev/ttyUSB0:3B
trace:12:55:55 2 B1
New data is received. /dev/ttyUSB0:B1
trace:12:55:55 2 AB D8 1E 18 47 FF
New data is received. /dev/ttyUSB0:AB D8 1E 18 47 FF
^C
6 years 1 month ago
You are using old version. Run this in app folder.
pip install --upgrade -r requirements.txt
UnknownExe
6 years 1 month ago
Hello and thank you 1000
Hello and thank you 1000 times
It works now the question is how do I get this data in readable characters?
Can you help me there too?
6 years 1 month ago
You should see it in XML format. Check your key if you can't. Can you add output as text here?
UnknownExe
6 years 1 month ago
Hii and thanks
Hii and thanks
Yes, I think that's not an XML format right?
Best regards
UnknownExe
Output:
gurux_dlms version: 1.0.86
gurux_serial version: 1.0.15
trace:14:44:41 2 7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53
New data is received. /dev/ttyUSB0:7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53
trace:14:44:41 2 4B 69 74 46 3E 4E 5F 20 00 15 23 AA F4 15 E7 51 4D 5F B2 17 3B 08 0D B4 6D C4 A1 C7 94 AB D6 72 AA 97 67 CA DF E9 35 7C E3 0F 14 2C 0C 71 8C 15 99 6F 64 3D 9D 24 E6 CF 55 3A 08 01 CD 5B 5A 79 68 72 21 0D 08 62 65 25 27 8F BB F9 65 94 46 CE 5F 50 E7 AA 55 CD 91 15 92 1C B9 1B 23 D4 99 FF 7D 50 DA 23 EF 22 6D 01 7E
New data is received. /dev/ttyUSB0:4B 69 74 46 3E 4E 5F 20 00 15 23 AA F4 15 E7 51 4D 5F B2 17 3B 08 0D B4 6D C4 A1 C7 94 AB D6 72 AA 97 67 CA DF E9 35 7C E3 0F 14 2C 0C 71 8C 15 99 6F 64 3D 9D 24 E6 CF 55 3A 08 01 CD 5B 5A 79 68 72 21 0D 08 62 65 25 27 8F BB F9 65 94 46 CE 5F 50 E7 AA 55 CD 91 15 92 1C B9 1B 23 D4 99 FF 7D 50 DA 23 EF 22 6D 01 7E
trace:14:44:42 2 7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 23 AB C7 AD 71 C0 F1 8C E0 0D 97 BA 39 5B F0 3F 16 CD 14 35 8A 53 A5 12 DC 0E FF C2 32 FC 81 8A B4 D2 7A 44 3B 39 05 40 45 E8 EC EF A4 16 9E F2 F3 64 0B DE EF A0 C8 C3 BA 33 7A CF EA F4 B7 AF C6 82 E0 73 67 D2 66 D1 C0 F0 EF 95 93 05 5A 43 53 47 3B 20 B7 85 5C E1 33 6B AD 00 03 88 7E
New data is received. /dev/ttyUSB0:7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 23 AB C7 AD 71 C0 F1 8C E0 0D 97 BA 39 5B F0 3F 16 CD 14 35 8A 53 A5 12 DC 0E FF C2 32 FC 81 8A B4 D2 7A 44 3B 39 05 40 45 E8 EC EF A4 16 9E F2 F3 64 0B DE EF A0 C8 C3 BA 33 7A CF EA F4 B7 AF C6 82 E0 73 67 D2 66 D1 C0 F0 EF 95 93 05 5A 43 53 47 3B 20 B7 85 5C E1 33 6B AD 00 03 88 7E
Invalid Command.
trace:14:44:43 2 7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 23 AC F0 CE AF 29 39 DE 05 85 95 F6 95 CF 32 44 33 3A 89 84 0C F5 9D D2 4E 8D B5 16 13 D5 A0 B5 1F F0 A0 DF 8A 29 21 BD 5F FB 24 81 7F 60 E8 1C 8B 58 02 19 1A 73 9E 1D 68 9D 8F 86 02 4F 1E 74 C5 92 9D 79 8B 00 4B 19 0B A2 79 3E 05 00 04 37 AC 9C 3C A9 39 BE 21 28 C5 49 98 99 02 76 7E
New data is received. /dev/ttyUSB0:7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 23 AC F0 CE AF 29 39 DE 05 85 95 F6 95 CF 32 44 33 3A 89 84 0C F5 9D D2 4E 8D B5 16 13 D5 A0 B5 1F F0 A0 DF 8A 29 21 BD 5F FB 24 81 7F 60 E8 1C 8B 58 02 19 1A 73 9E 1D 68 9D 8F 86 02 4F 1E 74 C5 92 9D 79 8B 00 4B 19 0B A2 79 3E 05 00 04 37 AC 9C 3C A9 39 BE 21 28 C5 49 98 99 02 76 7E
Invalid Command.
trace:14:44:44 2 7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 23 AD 2A 76 BB 34 B7 9F 41 D0 9F 5B 1A C6 B0 CC 02 5E EF 25 62 96 DC 19 1E 65 AD 82 3B 80 41 99 A4 9C 61 30 E2 AF 24 F5 20 4D 8B C6 45 52 FC 47 0B 6B EF E9 15 7B 33 35 42 6C 9B 88 CF 91 11 BF E5 63 14 F7 81 19 1A EF 76 99 1C 18 B4 59 16 11 92 07 F0 77 6B A8 74 49 67 70 40 36 D1 38 7E
New data is received. /dev/ttyUSB0:7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 23 AD 2A 76 BB 34 B7 9F 41 D0 9F 5B 1A C6 B0 CC 02 5E EF 25 62 96 DC 19 1E 65 AD 82 3B 80 41 99 A4 9C 61 30 E2 AF 24 F5 20 4D 8B C6 45 52 FC 47 0B 6B EF E9 15 7B 33 35 42 6C 9B 88 CF 91 11 BF E5 63 14 F7 81 19 1A EF 76 99 1C 18 B4 59 16 11 92 07 F0 77 6B A8 74 49 67 70 40 36 D1 38 7E
Invalid Command.
trace:14:44:45 2 7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 23 AE FD 2A 72 F6 53 8F FB 99 F5 C1 96 8B 24 17 F0 A8 9D 34 5D 6C 84 46 F7 0A DA C9 CE 31 6F 08 30 C1 70 6A A5 5C 43 5C B4 A2 61 5F DD F2 3F 8F 87 6C 78 3D FE 62 C1 16 D5 D2 AB 5F D8 55 59 BE 9E F9 A7 4D 31 C7 CD F4 0A FA 11 CE DA 99 B7 80 37 75 EA 71 ED 88 03 D1 3A DE 29 11 9F 1F 7E
New data is received. /dev/ttyUSB0:7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 23 AE FD 2A 72 F6 53 8F FB 99 F5 C1 96 8B 24 17 F0 A8 9D 34 5D 6C 84 46 F7 0A DA C9 CE 31 6F 08 30 C1 70 6A A5 5C 43 5C B4 A2 61 5F DD F2 3F 8F 87 6C 78 3D FE 62 C1 16 D5 D2 AB 5F D8 55 59 BE 9E F9 A7 4D 31 C7 CD F4 0A FA 11 CE DA 99 B7 80 37 75 EA 71 ED 88 03 D1 3A DE 29 11 9F 1F 7E
Invalid Command.
trace:14:44:46 2 7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 23 AF C4 AE 69 93 7E AA 67 7F 74 E4 36 EC 32 14 12 DC FF B5 78 37 9C F7 0B 11 97 3C 07 37 85 3A DC 5A E7 AB 14 5F CA C2 32 F5 76 EA 42 74 27 E5 E4 05 C8 94 19 42 B8 8E 5E 72 0C 59 82 C3 71 70 63 2D 04 9B 45 BE E4 1F 56 D9 26 77 8A 5F A0 F1 FC 3E DB EA D6 18 F4 A7 7F 55 E1 9E 5F 90 7E
New data is received. /dev/ttyUSB0:7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 23 AF C4 AE 69 93 7E AA 67 7F 74 E4 36 EC 32 14 12 DC FF B5 78 37 9C F7 0B 11 97 3C 07 37 85 3A DC 5A E7 AB 14 5F CA C2 32 F5 76 EA 42 74 27 E5 E4 05 C8 94 19 42 B8 8E 5E 72 0C 59 82 C3 71 70 63 2D 04 9B 45 BE E4 1F 56 D9 26 77 8A 5F A0 F1 FC 3E DB EA D6 18 F4 A7 7F 55 E1 9E 5F 90 7E
Invalid Command.
trace:14:44:47 2 7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 23 B0 B9 16 34 F9 86 EF 74 25 F6 6F 09 7B 67 AF E7 3F 4C AF 2D E0 5D 0C 91 D9 FF 3C 71 D4 7A CC 8D 21 88 9A 0D 56 9A 18 41 3E 2E C2 71 E5 0F 2C 5D 08 83 EA E7 C1 63 1A 23 F1 12 EF B2 AE DE 1A 1C F5 85 32 72 BE 11 50 8F 0A F9 19 18 48 6A 30 B4 48 CD 76 AD 9F BD 43 FB 6E 84 37 35 EE 7E
New data is received. /dev/ttyUSB0:7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 23 B0 B9 16 34 F9 86 EF 74 25 F6 6F 09 7B 67 AF E7 3F 4C AF 2D E0 5D 0C 91 D9 FF 3C 71 D4 7A CC 8D 21 88 9A 0D 56 9A 18 41 3E 2E C2 71 E5 0F 2C 5D 08 83 EA E7 C1 63 1A 23 F1 12 EF B2 AE DE 1A 1C F5 85 32 72 BE 11 50 8F 0A F9 19 18 48 6A 30 B4 48 CD 76 AD 9F BD 43 FB 6E 84 37 35 EE 7E
Invalid Command.
trace:14:44:48 2 7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 23 B1 12 08 C3 C8 3B 1E A3 EB 53 F5 75 FA 40 76 4B AA DD 54 E3 42 DA 64 83 0D 9F 37 61 3F 29 78 91 CB 80 8C CD A9 22 2E 4E 9A 5A 9A 11 4E D8 E6 A8 5B 94 20 D8 78 8F 2B 45 C5 D7 BA 07 F4 AD E8 54 DD FB 13 CA BC 39 6F 49 B7 1F 57 98 4D 70 FE F7 CE 5E 8A 62 73 2B 2F 94 BE E2 EE BC 72 7E
New data is received. /dev/ttyUSB0:7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 23 B1 12 08 C3 C8 3B 1E A3 EB 53 F5 75 FA 40 76 4B AA DD 54 E3 42 DA 64 83 0D 9F 37 61 3F 29 78 91 CB 80 8C CD A9 22 2E 4E 9A 5A 9A 11 4E D8 E6 A8 5B 94 20 D8 78 8F 2B 45 C5 D7 BA 07 F4 AD E8 54 DD FB 13 CA BC 39 6F 49 B7 1F 57 98 4D 70 FE F7 CE 5E 8A 62 73 2B 2F 94 BE E2 EE BC 72 7E
Decrypt failed. Invalid security suite.
^C
UnknownExe
6 years 1 month ago
Hello and UPDATE
Hello and UPDATE
If I add the key I get a structure just one that says nothing to me, you can help me understand it. Can it be that the structure is broken? Because of 'int' object has no attribute '__getitem__'
python main.py -S /dev/ttyUSB0:115200:8None1 -t Verbose -B KEY
trace:12:21:51 2 7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 31 2B 42 F5 37 2A E4 08 C3 DA 51 3D B6 56 0B D4 FA 19 80 B0 10 AE E3 E2 F3 C6 D4 38 07 ED 9C D7 4C 81 0D 04 77 84 DC A2 8C B2 E9 C0 5E 95 AD A5 CD 3C E5 E0 66 DF 46 A0 E8 F7 0E EF E2 B9 E7 09 D6 04 6B 2B D8 46 3F CE 59 0F 99 03 9D 64 FF 49 05 B7 6C 0E A2 C3 75 F4 4C 2D 25 B4 29 37 7E
New data is received. /dev/ttyUSB0:7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 31 2B 42 F5 37 2A E4 08 C3 DA 51 3D B6 56 0B D4 FA 19 80 B0 10 AE E3 E2 F3 C6 D4 38 07 ED 9C D7 4C 81 0D 04 77 84 DC A2 8C B2 E9 C0 5E 95 AD A5 CD 3C E5 E0 66 DF 46 A0 E8 F7 0E EF E2 B9 E7 09 D6 04 6B 2B D8 46 3F CE 59 0F 99 03 9D 64 FF 49 05 B7 6C 0E A2 C3 75 F4 4C 2D 25 B4 29 37 7E
<Structure Qty="0C" >
<OctetString Value="0006190900FF" />
<OctetString Value="31313231323731373132333334" />
<OctetString Value="0C153100" />
<OctetString Value="07E4080A01" />
<UInt32 Value="060C700L" />
<UInt32 Value="01A0342L" />
<UInt32 Value="00DA233L" />
<UInt32 Value="0083486L" />
<UInt32 Value="0000000L" />
<UInt32 Value="0000BEEL" />
<OctetString Value="" />
</Structure>
00 06 19 09 00 FF
31 31 32 31 32 37 31 37 31 32 33 33 34
0C 15 31 00
07 E4 08 0A 01
6342400
1704770
893491
537734
0
3054
trace:12:21:52 2 7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 31 2C 01 DC C9 33 E1 51 E4 A7 8D CB 22 27 E7 BD D3 1B D0 1C E7 A9 11 14 E8 17 C6 D0 51 DC F9 72 06 64 80 2B 0E 90 27 6B 31 4D 8A B6 DC 99 F8 07 6E E0 81 0D E7 A6 F7 79 67 43 BF AA 26 4D B3 64 C7 BE FD 67 BE B5 C1 CD 2F AF 14 03 EF 06 F9 95 E2 C0 C3 F6 51 63 49 EA A0 F0 9D 84 F9 6B 7E
New data is received. /dev/ttyUSB0:7E A0 77 CF 02 23 13 BB 45 E6 E7 00 DB 08 49 53 4B 69 74 46 3E 4E 5F 20 00 15 31 2C 01 DC C9 33 E1 51 E4 A7 8D CB 22 27 E7 BD D3 1B D0 1C E7 A9 11 14 E8 17 C6 D0 51 DC F9 72 06 64 80 2B 0E 90 27 6B 31 4D 8A B6 DC 99 F8 07 6E E0 81 0D E7 A6 F7 79 67 43 BF AA 26 4D B3 64 C7 BE FD 67 BE B5 C1 CD 2F AF 14 03 EF 06 F9 95 E2 C0 C3 F6 51 63 49 EA A0 F0 9D 84 F9 6B 7E
<OctetString Value="0C153200" />
<UInt32 Value="01A0343L" />
<UInt32 Value="0000BFBL" />
</Structure>
00 06 19 09 00 FF
0C 15 32 00
07 E4 08 0A 01
6342400
1704771
893491
537734
0
3067
^C
6 years 1 month ago
Meter is not sending list of objects and parsePushObjects fails.
Uncomment or remove after this line:
#Example is sending a list of push messages in the first parameter.
Values are XML like format at first and then values are printed.
Because there are no descriptions in the Push message, you need to know what data meter is sending.
<OctetString Value="0006190900FF" /> This is OBIS code of the Push message.
<OctetString Value="31313231323731373132333334" /> Meter serial number: 1121271712334
</Structure>
UnknownExe
6 years 1 month ago
Hello and thanks
Hello and thanks
So the meter serial number is correct. So these are all the values I need. So I have to include the Gurux in my script and simply pick up the print command to get the values, right? Can you please also tell me how I can get Gurux to run in my project without calling up the command on the command line? So that the values always come.
UnkownExe
UnknownExe
6 years 1 month ago
But what I don't understand
But what I don't understand how can I translate these values?
<Structure Qty = "0C">
<OctetString Value = "0006190900FF" /> This is OBIS code of the Push message.
<OctetString Value = "31313231323731373132333334" /> Meter serial number: 1121271712334
<OctetString Value = "0C153200" />
<OctetString Value = "07E4080A01" />
<UInt32 Value = "060C700L" />
<UInt32 Value = "01A0343L" />
<UInt32 Value = "00DA233L" />
<UInt32 Value = "0083486L" />
<UInt32 Value = "0000000L" />
<UInt32 Value = "0000BFBL" />
<OctetString Value = "" />
</Structure>
or how did you do that?
6 years 1 month ago
Add gurux-dlms in your project. Then read value from the serial port. When you have bytes you can call getdata. Something like this:
translator = GXDLMSTranslator()
reply = None
data = GXReplyData()
notify = GXReplyData()
cl = GXDLMSClient...
while(true)
#Get data from the serial port.
try:
if not cl.getData(reply, data, notify):
reply.clear()
#If notify is fully received.
if notify.complete:
if not notify.isMoreData():
#Show received data as XML.
xml = translator.dataToXml(notify.data)
print(xml)
except Exception as ex:
print(ex)
self.notify.clear()
self.reply.clear()
UnknownExe
6 years 1 month ago
Hii
Hii
can you help me one last time just before the breakthrough. I have these .py files in the sync_values folder. I call the get_smartmeter_gurux method from the folder. Now, in the method, exactly one data record should come out where I read the values and store them in variables and return them. What did I do wrong there?
thank you thank you thank you
Best regards
UnknownExe
6 years 1 month ago
You need to read data from the serial port to the reply parameter. Now there is no data.
Something like:
reply = seria1.read()
UnknownExe
6 years 1 month ago
hi
hi
ich glaube ich versteh das nicht ganz. Ich bekomme einen error bei seria1 and reply.clear()
ich hoffe du kannst mir da noch helfen.
def get_smartmeter_gurux():
cl = GXDLMSClient
#while(true):
# Get data from the serial port.
try:
reply.clear()
# If notify is fully received.
if notify.complete:
# Show received data as XML.
print(xml)
print(ex)
self.notify.clear()
self.reply.clear()
return ()
aldiguru
3 years 9 months ago
sorry to dig out this old thread. I am not using gurux, but tasmota to read out my ISKRAEMECO AM550.
But you seem to know how to communicate with the smart meter. Because I did not find any manuals or resources on this online can you help me out?
I am trying to communicate on 9600 baud (300 gives me nothing) and get something like this as a response:
16:52:16.457 : 77 33 32 c2 03 4e 53 bb b4 08 a4 87 06 a8 f2 6a a5 41 3d c1 b5 3d 0e 6c 44 67 62 4e fb 78 aa 9c ab cc da 4c 53 9b 68 67
16:52:20.443 : 77 16 13 30 10 34 2f 04 4f d6 40 4f 13 86 8a 82 f8 63 ad c5 7f d0 1a 9e 85 e1 c1 6f fd 73 7c 0c 80 92 7d c7 31 02 1c cd
16:52:26.441 : 77 fe 16 98 8f bd 85 8b 11 04 57 96 06 de 8c d3 9f ec e8 7e e1 79 a0 39 ad 0b f2 c7 92 45 7a 95 6f 8c 32 78 90 ed 2d 07
16:52:39.437 : 77 d7 24 a6 bc 3f 12 62 f5 83 33 ca 5e 2e 63 86 50 45 38 52 43 09 d3 48 6a b5 56 be d6 ba 80 0b 66 e8 d7 cc 8f cf ee c2
16:52:55.442 : 77 49 cc ab 8e 70 54 30 18 26 aa e6 fc a4 6b a4 bb 14 4a cc e8 f3 76 4d 49 d5 1d c9 9e 3a ee a8 01 b0 57 00 73 36 19 a1
16:52:57.457 : 77 88 72 34 d4 4f e3 df 19 b0 45 65 4c b8 c6 a0 32 5d 6e 27 2e 01 36 f2 db 12 8b be c4 52 7d c3 45 81 4f bf 18 ba 22 44
16:53:00.483 : 77 c2 e9 88 d9 4b aa 0e be 1d 1c f5 99 6e e1 e6 55 6f 2b b3 1d 51 80 08 0e 85 02 ac 07 f3 9c 3e 44 6a e9 83 a3 ee 44 68
16:53:04.489 : 77 bf bb 45 5c 03 ba ee f2 06 76 f2 f4 61 f6 02 c3 e6 a7 a1 8c b9 58 49 2d 98 9c b2 f5 12 aa f5 fa 7e 7e a0 67 cf 02 23
16:53:05.472 : 77 5e e9 57 ef a6 65 9b 2a 09 ed 3e c2 fe 9a 71 b4 b9 0e 85 a5 75 1b cf 93 53 c8 7e 7e a0 67 cf 02 23 13 fb f1 e6 e7 00
16:53:09.443 : 77 3b 1e a9 2c 4f 84 4e a6 06 16 30 86 6d ca 22 1e 24 aa ff 47 7a 86 44 3f cf a9 5f fd a1 23 56 7b 99 ff 3b 0f 1e 4e 81
16:53:20.509 : 77 8d 4b 18 d8 87 37 02 0f 1c 39 0d 55 3c f0 5b e7 9c e8 3d e7 2f 34 4a bf d9 9a 11 af 6b b6 3d 71 3d 1c 43 98 7b 41 ae
16:53:24.466 : 77 f5 12 40 e1 31 24 7e 7e a0 67 cf 02 23 13 fb f1 e6 e7 00 db 08 49 53 4b 68 74 99 f5 08 4f 20 00 1d 46 a1 58 2d 27 07
It should be AES encrypted, but according to this gist (https://gist.github.com/pocki80/941fa090a8d6269a9b3b68c195f8750f) it should start and end with 7e.
Do I need to send an activation sequence to tell the smart meter that I am listening?
You would be a great help and have nice holidays :)
Pagination
  • Page 1
  • Page 2
  • Next page
  • Last page
