  3. 1.0.99.2.0.255
1.0.99.2.0.255
By MrSupe , 12 February, 2020
When I changed or added capture object I cannot read this Profile on Iskraemeco MT880.
Do you have some sugestion?
Peter.
6 years 4 months ago
HI,
HI,
If you modify capture objects you need to refresh that profile generic.
Select profile generic what you have modified and select "Refresh" from "File" menu.
MrSupe
Thanks Mikko,
Thanks Mikko,
I did it. It helped on meter where I added capture registers, but id didnt helped on meter where I changed them.
Peter.
What kind of error you are getting? How you change them? Is meter profile generic buffer reset when you change capture objects?
MrSupe
I didnt see any error... Just
I didnt see any error... Just dont read. After communication Director is ready.
This is trace:
13:34:53 Read object type ProfileGeneric index: 4
TX: 7E A0 1A 02 85 03 32 7B BB E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 04 00 48 C0 7E
13:34:53
RX: 7E A0 16 03 02 85 52 03 EB E6 E7 00 C4 01 C1 00 06 00 01 51 80 86 0C 7E
13:34:53 Read object type ProfileGeneric index: 5
TX: 7E A0 1A 02 85 03 54 4B BD E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 05 00 90 D9 7E
13:34:53
RX: 7E A0 13 03 02 85 74 63 89 E6 E7 00 C4 01 C1 00 16 01 9A 11 7E
13:34:53 Read object type ProfileGeneric index: 6
TX: 7E A0 1A 02 85 03 76 5B BF E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 06 00 F8 F3 7E
13:34:53
RX: 7E A0 23 03 02 85 96 AE 99 E6 E7 00 C4 01 C1 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 BE 7F 7E
13:34:53 Read object type ProfileGeneric index: 7
TX: 7E A0 1A 02 85 03 98 2B B1 E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 07 00 20 EA 7E
13:34:53
RX: 7E A0 16 03 02 85 B8 57 A3 E6 E7 00 C4 01 C1 00 06 00 00 00 06 4B 7D 7E
13:34:53 Read object type ProfileGeneric index: 8
TX: 7E A0 1A 02 85 03 BA 3B B3 E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 08 00 E8 69 7E
13:34:53
RX: 7E A0 16 03 02 85 DA 43 E3 E6 E7 00 C4 01 C1 00 06 00 00 03 E8 53 59 7E
MrSupe
This is trace:
13:34:53
13:34:53
13:34:53
13:34:53
13:34:53
Buffer is not read at all. Select Profile generic and select "Access rights" tab.
Check what are access rights for "Buffer" and "Capture objects".
Change them if they are "No Access".
MrSupe
Done...Thanks.
Done...Thanks.
Big Koskenkorva for you.
Peter.
MrSupe
5 years 10 months ago
Hello Mikko,
Hello Mikko,
I changed captured data 1.0.99.2.0.255 (added). I could not read data after that. I changed it back and I still read nothing... Here is the trace:
01:39:54 Read object type ProfileGeneric index: 1
TX: 7E A0 1A 02 85 03 94 47 7B E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 01 00 F0 BE 7E
01:39:54
RX: 7E A0 19 03 02 85 78 A7 0F E6 E7 00 C4 01 C1 00 09 06 01 00 63 02 00 FF 87 09 7E
01:39:54 Read object type ProfileGeneric index: 4
TX: 7E A0 1A 02 85 03 B6 57 79 E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 04 00 48 C0 7E
01:39:54
RX: 7E A0 16 03 02 85 9A 47 A1 E6 E7 00 C4 01 C1 00 06 00 01 51 80 86 0C 7E
01:39:54 Read object type ProfileGeneric index: 5
TX: 7E A0 1A 02 85 03 D8 2F F3 E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 05 00 90 D9 7E
01:39:54
RX: 7E A0 13 03 02 85 BC 27 C3 E6 E7 00 C4 01 C1 00 16 01 9A 11 7E
01:39:54 Read object type ProfileGeneric index: 6
TX: 7E A0 1A 02 85 03 FA 3F F1 E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 06 00 F8 F3 7E
01:39:54
RX: 7E A0 23 03 02 85 DE E2 57 E6 E7 00 C4 01 C1 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 BE 7F 7E
01:39:54 Reading profile generic data
TX: 7E A0 4D 02 85 03 1C B9 36 E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 02 01 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E4 07 14 FF 17 3B 00 FF FF 88 80 09 0C 07 E4 07 15 FF 00 00 00 FF FF 88 80 01 00 3B C1 7E
01:39:55
RX: 7E A0 13 03 02 85 F0 4F 4B E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
01:39:55 Read object type ProfileGeneric index: 7
TX: 7E A0 1A 02 85 03 3E 17 71 E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 07 00 20 EA 7E
01:39:55
RX: 7E A0 16 03 02 85 12 07 A9 E6 E7 00 C4 01 C1 00 06 00 00 00 00 7D 18 7E
01:39:55 Read object type ProfileGeneric index: 8
TX: 7E A0 1A 02 85 03 50 6F FB E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 08 00 E8 69 7E
01:39:55
RX: 7E A0 16 03 02 85 34 33 ED E6 E7 00 C4 01 C1 00 06 00 00 03 E8 53 59 7E
BR
Peter.
Buffer is empty. There is no data. The reason is start and end times.
Start time: 21.7.2020 0.59.00
End time: 21.7.2020 1.00.00
Change them. Try to read last day.
MrSupe
I have it right (check
I have it right (check attachment)...I extended it for one day more:
11:24:29 Read object type ProfileGeneric index: 1
TX: 7E A0 1A 02 85 03 32 7B BB E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 01 00 F0 BE 7E
11:24:29
RX: 7E A0 19 03 02 85 52 FF 81 E6 E7 00 C4 01 C1 00 09 06 01 00 63 02 00 FF 87 09 7E
11:24:29 Read object type ProfileGeneric index: 4
TX: 7E A0 1A 02 85 03 54 4B BD E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 04 00 48 C0 7E
11:24:29
RX: 7E A0 16 03 02 85 74 37 AF E6 E7 00 C4 01 C1 00 06 00 01 51 80 86 0C 7E
11:24:29 Read object type ProfileGeneric index: 5
TX: 7E A0 1A 02 85 03 76 5B BF E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 05 00 90 D9 7E
11:24:29
RX: 7E A0 13 03 02 85 96 7F 4D E6 E7 00 C4 01 C1 00 16 01 9A 11 7E
11:24:29 Read object type ProfileGeneric index: 6
TX: 7E A0 1A 02 85 03 98 2B B1 E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 06 00 F8 F3 7E
11:24:29
RX: 7E A0 23 03 02 85 B8 D2 51 E6 E7 00 C4 01 C1 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 BE 7F 7E
11:24:29 Reading profile generic data
TX: 7E A0 4D 02 85 03 BA 85 F6 E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 02 01 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E4 07 13 FF 17 3B 00 FF FF 88 80 09 0C 07 E4 07 15 FF 00 00 00 FF FF 88 80 01 00 5A DC 7E
11:24:29
RX: 7E A0 13 03 02 85 DA 17 C5 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:24:29 Read object type ProfileGeneric index: 7
TX: 7E A0 1A 02 85 03 DC 0B B5 E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 07 00 20 EA 7E
11:24:30
RX: 7E A0 16 03 02 85 FC 77 A7 E6 E7 00 C4 01 C1 00 06 00 00 00 00 7D 18 7E
11:24:30 Read object type ProfileGeneric index: 8
TX: 7E A0 1A 02 85 03 FE 1B B7 E6 E6 00 C0 01 C1 00 07 01 00 63 02 00 FF 08 00 E8 69 7E
11:24:30
RX: 7E A0 16 03 02 85 1E 6B 63 E6 E7 00 C4 01 C1 00 06 00 00 03 E8 53 59 7E
Buffer is still empty. Some meters expect that seconds and minutes are zero. What if you read the latest day? Is that working? Try to read values where start time is 1.00.00 and end time is 11.0.0. Is that working?
BR
MrSupe
I did it with same result. I
I did it with same result. I have more Iskraemeco MT880 meters and Gurux works perfectly with them...
It happened when I tried to change (add) capture registers:
- I added 1.0.3.8.0.255, 1.0.4.8.255
- I put command WRITE
- I tried to read (But I forgot for Refresh)
- When it didnt work I Removed added registers, put WRITE command and Refresh.
- Still not work
P.
I'm not sure because the pic is bad, but if I see correctly the amount of entries is zero.
Press "Capture" button and read again.
Buffer is usually clear when you modify capture objects.
MrSupe
I tried everything. I also
I tried everything. I also read from my java application. All the meters I have Ia reading in the same way - no problem. Only this one, when I tried to change capture registers.
Is it possible that capture register records were damaged. What will happened when I push Reset button in CaptureObject tab?
P.
The reset will clear the buffer. It doesn't affect capture objects.
If you have several meters, check the firmware versions.
MrSupe
All have the same FW number..
All have the same FW number... 1.0.0.2.0.255: ISKACMT880100500
It worked fine until I tried change capture objects :-(
I even can read other ProfileGeneric data ...
P.
It might be that meter can't handle if you change capture objects. Can you reset the meter? You will lose all you collected data if you do this.
You can do Global Meter Reset if you find Script Table 0.0.10.0.0.255 and read scripts and execute script #1. NOTE! All meter settings are reset to factory defaults and usually all data is lost.
MrSupe
Mikko I got it...
Mikko I got it...
These ProfileGeneric data (if I change capture registers) will react correctly after period has elapsed (in my case 86400s). I dont know if it is MT880 feature only or it is general feature. But immediately after midnight it start to read correctly (not empty buffer).
P.
You are right. This profile generic is saving data once/day. Period is 24 hours (86400s).
I did try to check it from the pic, but it's compressed and I can't read it.
