  3. Access of Meter
access of meter
By mohamadop , 25 June, 2020
Hi ,
how we can access to the meter ? with its ip address or via ip of gateway .
otherwise , the meter have an ip address or not ?
6 years 4 months ago
It depends from the meter. If meter is supporting TCP/IP you can connect using IP address if it's using static IP address. You need to ask from the meter vendor is TCP/IP supported.
mohamadop
Ah ok , so the meter could
Ah ok , so the meter could have an address ip ?
Yes, if meter is using TCP/IP connection it will have an IP address.
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
