  3. C # Client Error Get GetAssociationView
C # client error get GetAssociationView
By Ingvar , 31 May, 2020
I trying to interrogate a C # device by a client. I setted startup parameters - COM port, password.
Immediately after starting, after several requests, an error falls out. Judging by the code, this happens when execute method GetAssociation. Gurux Server-simulator is read normally (port 4061).
At the same time, I am interrogating the same device with a C ++ client - reading is done there normally. What can be wrong?
Log C#:
TX: 10:23:46 7E A0 07 03 03 93 8C 11 7E
RX: 10:23:46 7E A0 20 03 03 73 F0 2E 81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01 CE 6A 7E
TX: 10:23:46 7E A0 44 03 03 10 65 94 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 33 33 33 33 33 33 33 33 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 0F 0E FF FF 3E 1A 7E
RX: 10:23:46 7E A0 37 03 03 30 EF CA E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 08 0E 00 AC 00 07 BE 8D 7E
TX: 10:23:48 7E A0 19 03 03 32 EC C8 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E
RX: 10:23:48 7E A0 23 03 03 52 B6 3B E6 E7 00 2E 15 30 0E 00 00 00 1C D9 AD 77 A0 47 4E 85 4C 85 84 86 DD C1 34 5E C4 EB 7E
TX: 10:23:48 7E A0 07 03 03 53 80 D7 7E
RX: 10:23:48 7E A0 07 03 03 73 82 F6 7E
Erroon in Widnow:
Standard: DLMS
Invalid Command.
System.ArgumentException: Invalid Command.
в Gurux.DLMS.Reader.GXDLMSReader.ReadDLMSPacket(Byte[] data, GXReplyData reply) в d:\Project\MS4\MainProjects\Gurux.DLMS.Net-master\Gurux.DLMS.Client.Example.Net\GXDLMSReader.cs:line 1036
в Gurux.DLMS.Reader.GXDLMSReader.ReadDataBlock(Byte[] data, GXReplyData reply) в d:\Project\MainProjects\Gurux.DLMS.Net-master\Gurux.DLMS.Client.Example.Net\GXDLMSReader.cs:line 1083
в Gurux.DLMS.Reader.GXDLMSReader.GetAssociationView(String outputFile) в d:\Project\MainProjects\Gurux.DLMS.Net-master\Gurux.DLMS.Client.Example.Net\GXDLMSReader.cs:line 597
в Gurux.DLMS.Reader.GXDLMSReader.ReadAll(String outputFile) в d:\Project\MainProjects\Gurux.DLMS.Net-master\Gurux.DLMS.Client.Example.Net\GXDLMSReader.cs:line 94
в Gurux.DLMS.Client.Example.Program.Main(String[] args) в d:\Project\MainProjects\Gurux.DLMS.Net-master\Gurux.DLMS.Client.Example.Net\Program.cs:line 138
6 years ago
Hi Ingvar,
Hi Ingvar,
I'm sorry. We have broken this on the last released version. Get the latest version.
Ingvar
6 years ago
It's works now.
It's works now.
There is still a problem. For some reason, Description is not formed - Invalid is displayed. If I understand in code correctly, OBIS is not loading from the OBISCodes.txt file
What can be wrong?
I start with empty -d parameters (DLMS mode)
6 years ago
What OBIS code is causing problems? You must define correct sub standard. Ex:
-d India
Ingvar
6 years ago
Considered Association,
Considered Association, Scales, Units. I want to save this in xml so that later it will be easier to debug the display of the read variables.
I call the method:
MyGXDLMSObjectCollectiond.Save ("output.txt", null);
The file is saved.
Then I try to download it:
GXDLMSObjectCollection LoadCollection = GXDLMSObjectCollection.Load ("output.txt");
An error appears while reading.
What can be wrong?
File:
https://drive.google.com/file/d/178N4NJUxfBBcfbKNyUt22q-dC4aqIcEI/view?…
6 years ago
Hi Ingvar,
Hi Ingvar,
Please, don't paste images. They are compressed and on your PC it looks good, but I can't read it or you if you try in different PC.
I can't access this link. You haven't given access rights to it.
Ingvar
6 years ago
Sorry - I did not check.
Image removed. Corrected the link.
6 years ago
Can you try to run this with client example? Add -o parameter and check is description correct.
Where should be no any reason why the description is not set.
Ingvar
6 years ago
I d'not understand. What
I d'not understand. What should I see as a result in the client?
I will explain. My task is to get GXDLMSObjectCollection using the load from the generated file (so that you do not have to read data from the device each time, when debugging a GUI my application). It can be done? Calling the Load method as I pointed out leads to an error.
6 years ago
Hi Ingvar,
Hi Ingvar,
I tested this with client example and descriptions are correct, not invalid. Are you sure that Something is not changed in the source code?
Are you using Gurux.DLMS.dll from nuget.org? Try with that. Is the result the same?
Ingvar
6 years ago
Did so:
Did so:
1. I getted the latest source .Net client from GitHub
2. Compiled. I put output1.txt (rename file) in the Debug folder.
3. In Program.cs added line 56:
GXDLMSObjectCollection res12 = GXDLMSObjectCollection.Load ("output1.txt");
I launched the application - it crashed.
Am I doing the right thing? Can I load GXDLMSObjectCollection from a file like this?
Attached the file Program.cs
https://drive.google.com/file/d/1sxqCudb2QyuDKnZDcRJ8oGteWkPkzXsV/view?…
6 years ago
Now I know the reason. All objects are sterilized as GXDLMSData, but your objects are registers, etc.
You need to save this file using GXDLMSObjectCollection.save method.
Then you can use GXDLMSObjectCollection.load to load it.
Collect data from the meter and then save it with GXDLMSObjectCollection.save.
Ingvar
6 years ago
I do so.
That's exactly what I do.
GXDLMSObjectCollection res = reader.GetAssociation (StopToken);
res.Save ("output1.txt", null);
GetAssociation code:
public GXDLMSObjectCollection GetAssociation (System.Threading.CancellationTokenSource Token)
try
InitializeConnection ();
if (GetAssociationView (Token))
GetScalersAndUnits (Token);
GetProfileGenericColumns (Token);
finally
Close ();
return Client.Objects;
6 years ago
Is this a real meter or simulator? OBIS codes and object types don't match.
Can you read your meter with client example and save trace to the google.
I can check the reason on Monday.
Ingvar
6 years ago
This is a real device -
This is a real device - chinese aMeter100.
By link logs in verbose mode.
https://drive.google.com/file/d/1d82XXpID7daoVQqKChGXpb_cPGXVOfsM/view?…
If you want, I can give access through the TCP tunnel using AnyDesk.
5 years 12 months ago
XML serializer fails with meter's null data. This is now fixed. Get the latest version.
https://www.gurux.fi/node/16091
Ingvar
I downloaded and updated the
I downloaded and updated the Development folder. Rebilded. I re-read the entire file again from device. Wrote a line:
GXDLMSObjectCollection res12 = GXDLMSObjectCollection.Load ("output.txt");
The application has crashed. Read file and screenshot in application
https://drive.google.com/file/d/1j1CaTs0idpR4gecPdQ6TiLduv9-nAcbK/view?…
5 years 11 months ago
This is improved. Get the latest version.
Ingvar
Now everything is fine. One
Now everything is fine. One more question.
After I read the counter variables and received the GXDLMSObjectCollection, I need to perform a specific sorting of the elements.
So far, I've changed the protected List <GXDLMSObject> Items to public List <GXDLMSObject> Items in the GXDLMSObjectCollections.cs file and did CompareTo for GXDLMSObject. This works, but I would not want to change the standard code.
Maybe there is a better solution?
GXDLMSObjectCollections is derived from IList. You can do it like this:
List<GXDLMSObject> tmp = client.Objects.ToList();
tmp.Sort();
Ingvar
5 years 10 months ago
Found another error. Added a
Found another error. Added a line like this:
Client.Objects.Save (@ "c: \ 1 \ 1.xml", null);
Into the ReadAll method (screenshot below).
The startup line of such a client is as follows:
-h 127.0.0.1 -p 4061 -a HighGmac -C AuthenticationEncryption -t Verbose
The server is your Gurux.
If there is no output.txt file, then an error occurs on the ip4Setup object due to the fact that the IP address is Null
Screenshots
https://drive.google.com/uc?export=download&id=1LOTNj1ti6ZTfm8-R1lvDIYy…
https://drive.google.com/uc?export=download&id=1GLGZbZrZ6tF-pM_qdoqd5Td…
I can't access your Goole account. Is this GXDLMSIp4Setup or GXDLMSIp6Setup?
Ingvar
damn google...I am sorry.
GXDLMSIp4Setup
No worries. This is fixed and new version is released on next week.
Ingvar
You have uploaded the fixed
You have uploaded the fixed version to GitHub?
It's now updated.
