  3. Landis+Gyr G405
Landis+Gyr G405
By mato3848 , 10 June, 2020
We tried to read the meter with default settings, but its refuse the connection, we tried with client address 0x1, 0x10, 0x11, 0x12 but the result is the same
10:36:52 Send SNRM request.
10:36:52
RX: 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
10:36:52 Send AARQ request.
TX: 7E A0 44 03 21 10 E6 84 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 30 30 30 30 30 30 30 30 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 5C FD 7E
10:36:52
RX: 7E A0 36 21 03 30 D7 60 E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0D BE 0F 04 0D 08 00 06 5F 04 00 00 02 1A 13 88 00 07 FA 8D 7E
10:36:52
do you know if we are doing someting wrong?
thanks
6 years 3 months ago
L+G G405 is new meter to me, but your meter returns authentication failure. Is your password correct? Can you connect without authentication?
mato3848
Yes. I can connect without
Yes. I can connect without authentication but the acess is limited, i can not read the generic profile.
If you can connect without authentication there are two possibilities.
1. Password is wrong.
2. client address is wrong.
Check the password first. Someone may have changed it.
