  3. Push Set Up Class
Push Set Up Class
By deepaks , 4 June, 2020
I would like to know the interpretation of "destination: octet-string" parameter of structure
send_destination_and_method ::= structure
transport_service: transport_service_type,
destination: octet-string,
message: message_type
Example if the destination ip is 10.10.109.178 Port 4059, then how to pack it in octet string.
Any ready made example will be appreciated.
Thanks in advance
6 years ago
It's a string as byte array if transport_service is TCP/IP. Like this:
10.10.109.178:4059
As Hex:
31 30 2E 31 30 2E 31 30 39 2E 31 37 38 3A 34 30 35 39
deepaks
6 years ago
Thanks Mikko for the prompt
Thanks Mikko for the prompt response.
By the way is there any documented example in any of the specification document as for interoperability every product has to do same encoding and decoding.
Thanks in Advance
6 years ago
That is defined on IDIS, but it's not defined on DLMS standard or India standards.
This is just what most of the meters are using, but there might be meters that are using own custom solutions here.
