  3. Unable To Buld The Project Through Visual Studio
unable to buld the project through visual studio
By nishitha , 29 May, 2020
hi,
I am not able to build this project and as a result i am unable to get the .exe file , please guide me.
6 years 1 month ago
You need VS 2019 to build it. What kind of problems you have?
nishitha
6 years 1 month ago
Hii, i have downloaded the
Hii, i have downloaded the dlms director and opened it in visual studio 2019, but it when i try to build the project, i get some errors as abc.resx file.not found whichh is causing build failure
6 years 1 month ago
HI nishitha,
HI nishitha,
I just downloaded latest version from GitHub and test it. It works without problems. Where you have downloaded GXDLMSDirector?
nishitha
6 years 1 month ago
hi Mikko,
hi Mikko,
I have downloaded the code from github: https://github.com/Gurux/GXDLMSDirector.
1)unzipped files
2)opened visual studio and clicked on open from local folder
3)opened the develpoment folder. and i have selected GXDLMSDirector.sln in solution explorer and tried to build, there wont be any .exe till i build, but is it expecting .exe before build right and when i click ok , i am getting 14 errors.
nishitha
6 years 1 month ago
the error is saying cintent
the error is saying cintent is downloaded from internet so you need to remove the mark, i checked for this error in stackoverflow and checked still didnot work
6 years 1 month ago
Please, don't paste images. They are compressed and you are seeing them well, but others don't.
You need to manually change this for each file. I strongly propose that you use GitHub app.
Then you don't have this problem anymore. This is Windows security feature and there is nothing that we can do.
nishitha
6 years 1 month ago
okk. will try that
okk. will try that
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
