  3. Is There Any Example Xml File For Load Obj?
Is there any example xml file for load obj?
By 953313493@qq.com , 27 May, 2020
in cpp version ,I found
int CGXDLMSObjectCollection::Load(const char* fileName)
Is there any example file?
6 years 2 months ago
It depends from the meter. All the meters are different. If you don't have a real meter, you can run the client against the example server and save the file.
Add -o parameter
Like this:
GuruxDLMSClientExample.exe -h localhost -p 4061 -o result.xml
953313493@qq.com
ok, thank you.
ok, thank you.
alexav
5 years 1 month ago
Hi, Mikko!
Hi, Mikko!
Gurux.DLMS.cpp doesn't load GenericProfile CaptureObjects from xml file. see CGXDLMSObjectCollection::Load at https://github.com/Gurux/Gurux.DLMS.cpp/blob/master/development/src/GXD…
Andrei
5 years 1 month ago
In reply to Hi, Mikko! by alexav
Hi Andrei,
Hi Andrei,
You are right. Load only creates objects. Only Save is used at the moment, but load might be handy in future projects. I have added this to the work list and created an issue from this.
http://www.gurux.fi/node/18716
  • KadokTen
  • xMjAupjsfUDybB…
  • GWcVnqgDuqbcJvFIAoke
  • Lewisnon
  • kxyxJyMJlzhuzi…
