  3. How To Set Passive Relay Time
How to set Passive Relay Time
By Shruti Singh , 6 May, 2020
How do I set the values for Activation -date time?
Setting the values for lockout period , auto-connection re-attempts.
Please provide code set for setting the value for passive relay time
6 years 4 months ago
Hi Shruti,
Hi Shruti,
I need more info from for question. What you exactly want to do or what COSEM do you want to use?
Shruti Singh
In reply to Hi Shruti, by Kurumi
1.0.96.128.30.255 - Passive
1.0.96.128.30.255 - Passive Relay Time ,
I need a code sample for Set of Passive Relay
in Gurux dlms smart meters in java
This is the data object. You can do it like this:
GXDLMDData prt = new GXDLMDData("1.0.96.128.30.255");
prt.setDataType(DataType.DATETIME);
GXDateTime dt = new GXDateTime(...);
prt.setValue(dt);
writeObject(pet, 2);
Try to read the value from the meter first to get an idea of what kind of data you need to write back.
Shruti Singh
1. OBIS used to Write relay
1. OBIS used to Write relay configurations
2. OBIS used to Read existing relay configurations until it activate
4. Default time interval is 300 sec, Lock out time 1800 Sec and number of reconnection attmepts are 04 counts
5. Activation date-time is upcoming date by which relay configuration will activate
This is my requirement .
Can you briefly explain how the functionality of passive relay works.
How Do i set the value in
Time interval between auto-reconnection attempt
Lockout time
Number of auto-reconnection attempts
according to the activation date time . Kindly give a brief in explaining this functionality Passive Relay along with the code.
We have not used lockout time or number of auto-reconnection attempts. You need to ask from meter manufacturer how to config them.
I can check from the IS specification if you know the OBIS codes.
Shruti Singh
1.0.96.128.30.255 this is the
1.0.96.128.30.255 this is the Obis Code for Passive Time Relay. Will this help?
Shruti Singh
Kindly explain what this
Kindly explain what this Passive Relay actually means?
I mean what it actually does?
Hi Shruti ,
Hi Shruti ,
You need to ask this from the meter manufacturer. This is an Indian standard 15959 specific topics.
I don't know this Passive Relay so well.
